Streaky glass...when Windex just doesnt work... #1748927
02/08/15 01:31 AM
02/08/15 01:31 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I am getting ready to put in the rear window on my 68 Fastback Barracuda. The glass has what looks like streaks in it, as do the side windows. No amount of windex or glass cleaner in American can get rid of it. I tried lightly scraping a razor across it, it will not go away. Any successful suggestions? Would a buffer help? I don't want to install the rear glass only to have to throw it in the trash and ruin the new gasket I just put in. I have never came across this before. Is there an easy way to get these streaks out?
Any suggestions, I will give them a try (as long as it doesn't involve a hammer and dustpan)..
Dave in Colorado
Re: Streaky glass...when Windex just doesnt work... [Re: dssaa] #1748928
02/08/15 01:37 AM
02/08/15 01:37 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Did you try cleaning it with Bon Ami or similar cleaner? I have had luck with that to get a film of crud off glass cleaner didn't have much luck with.
If it is that bad, there is always an angle grinder with some 60 grit discs.
Re: Streaky glass...when Windex just doesnt work... [Re: dssaa] #1748929
02/08/15 01:38 AM
02/08/15 01:38 AM
Alberta
N
NEVjr Offline
NEVjr  Offline
N
Alberta
i dont know if it will help, but i have had better luck using 50/50 white vinegar and water wiped off with crumpled newspaper than i have with windex and papertowel.
Re: Streaky glass...when Windex just doesnt work... [Re: OzHemi] #1748930
02/08/15 01:39 AM
02/08/15 01:39 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
....60 grit? Oh I asked for it..
Re: Streaky glass...when Windex just doesnt work... [Re: dssaa] #1748931
02/08/15 01:44 AM
02/08/15 01:44 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
I still use Rain-X glass cleaner and newspaper and my glass looks crystal clear........
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Streaky glass...when Windex just doesnt work... [Re: dssaa] #1748932
02/08/15 01:46 AM
02/08/15 01:46 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
As a last resort.
I have had good luck with the cleaner I mentioned for really grungy sorta glass in the past.
Re: Streaky glass...when Windex just doesnt work... [Re: OzHemi] #1748933
02/08/15 02:47 AM
02/08/15 02:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Newspaper,the only thing to use with any cleaner, i use vinegar-lemon juice. Most of the new stuff is so watered down with non-toxic ingredients, afraid some kid will drink it.
Re: Streaky glass...when Windex just doesnt work... [Re: cudaman1969] #1748934
02/08/15 02:51 AM
02/08/15 02:51 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
https://www.youtube.com/watch?v=67rTHltSj_Q
Re: Streaky glass...when Windex just doesnt work... [Re: dssaa] #1748935
02/08/15 03:44 AM
02/08/15 03:44 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I had the same problem with some Challenger glass. It looked fine unless you caught it in the right light then you could see some coloured streaks in it. Nothing would take them out, I tried everything from lacquer thinner to cut polish. Ended up throwing the glass away.
Sheldon
Re: Streaky glass...when Windex just doesnt work... [Re: RUNCHARGER] #1748936
02/08/15 08:36 AM
02/08/15 08:36 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
SOS pads. They clean glass very well and don't scratch it. I've also used Fast Orange for nasty junkyard grunge on glass.
Re: Streaky glass...when Windex just doesnt work... [Re: ruderunner] #1748937
02/08/15 12:31 PM
02/08/15 12:31 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
000 steel wool with CLR (calcium lime rust remover).
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: Streaky glass...when Windex just doesnt work... [Re: Curt] #1748938
02/08/15 02:03 PM
02/08/15 02:03 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Buy some chromium oxide from a glass shop and polish them BEFORE you install them. None of these other methods would work on the glass I had. The chromium oxide cleaned them up like they were brand new( where I could reach AFTER I installed the glass). It requires a buffer so it makes a HUGE mess!
Driving modern convenience in classic beauty
Re: Streaky glass...when Windex just doesnt work... [Re: Darius] #1748939
02/08/15 03:16 PM
02/08/15 03:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've had good luck with very fine steel wool and windex as a lubricant. Didn't have to use anything stronger (like CLR). Mine had not only a lot of dirt but also a lot of fine paint overspray. They look like new now!
Re: Streaky glass...when Windex just doesnt work... [Re: Darius] #1748940
02/08/15 03:32 PM
02/08/15 03:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
This is the direction I would go if the news paper doesn't work.
I was going to suggest maybe taking it to a glass shop before I read this. I figured the professionals would have the right answer.
Good Luck
I have mechanical Aptitude.
I can screw up anything.
Re: Streaky glass...when Windex just doesnt work... [Re: Stanton] #1748941
02/08/15 03:40 PM
02/08/15 03:40 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
I had streaky glass on my 04 VW GTI so bad that it was hard to see out at night. The rubber molding that presses up against the glass to keep the water and dust out of the door over the years finely scratched the glass and made it look streaky (almost frosted in area's).
I bought some the Eastwood glass polish and it polished it right out and made the glass look like new. I had hard water spots on some of the other windows on the car and it cleaned those windows real nice. I am planning on polishing all the windows on my Cuda' with the Eastwood polish before I re-install them in the car.
The Eastwood system works good, but it is messy, so doing it when the glass is out of the car is the best way to do it.
Here is a link to the Eastwood polish:
http://www.eastwood.com/pro-glass-polishing-kit.html
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Streaky glass...when Windex just doesnt work... [Re: loco340cuda] #1748942
02/08/15 06:22 PM
02/08/15 06:22 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I've used Acetone (no tint of course).
Facts are stubborn things.
Re: Streaky glass...when Windex just doesnt work... [Re: larrymopar360] #1748943
02/08/15 09:55 PM
02/08/15 09:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Lots of suggestions on removal, but what is on the OP's glass in the first place? Almost sounds like the heat treat? streaks one sees sometimes with polarized sunglasses in reflected sunlight.
Re: Streaky glass...when Windex just doesnt work... [Re: jcc] #1748944
02/09/15 12:08 AM
02/09/15 12:08 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So..I used an SOS pad with a little vinegar/water spray, and they are cleaning right up. My guess is mineral deposits from sitting in a Nebraska cornfield for 15 years....thanks for all the great suggestions!
