Streaky glass...when Windex just doesnt work...
#1748927
02/08/15 01:31 AM
02/08/15 01:31 AM
Posts: 977 Colorado
dssaa
Colorado
I am getting ready to put in the rear window on my 68 Fastback Barracuda. The glass has what looks like streaks in it, as do the side windows. No amount of windex or glass cleaner in American can get rid of it. I tried lightly scraping a razor across it, it will not go away. Any successful suggestions? Would a buffer help? I don't want to install the rear glass only to have to throw it in the trash and ruin the new gasket I just put in. I have never came across this before. Is there an easy way to get these streaks out? Any suggestions, I will give them a try (as long as it doesn't involve a hammer and dustpan).. Dave in Colorado
Re: Streaky glass...when Windex just doesnt work...
[Re: dssaa]
#1748932
02/08/15 01:46 AM
02/08/15 01:46 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
....60 grit? Oh I asked for it..
As a last resort.
I have had good luck with the cleaner I mentioned for really grungy sorta glass in the past.
[Re: ruderunner]
#1748937
02/08/15 12:31 PM
02/08/15 12:31 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
000 steel wool with CLR (calcium lime rust remover). Curt
Oh yeah...THAT'S gonna leave a mark!
[Re: Curt]
#1748938
02/08/15 02:03 PM
02/08/15 02:03 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Buy some chromium oxide from a glass shop and polish them BEFORE you install them. None of these other methods would work on the glass I had. The chromium oxide cleaned them up like they were brand new( where I could reach AFTER I installed the glass). It requires a buffer so it makes a HUGE mess!
Driving modern convenience in classic beauty
[Re: Darius]
#1748939
02/08/15 03:16 PM
02/08/15 03:16 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I've had good luck with very fine steel wool and windex as a lubricant. Didn't have to use anything stronger (like CLR). Mine had not only a lot of dirt but also a lot of fine paint overspray. They look like new now!
[Re: Stanton]
#1748941
02/08/15 03:40 PM
02/08/15 03:40 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I had streaky glass on my 04 VW GTI so bad that it was hard to see out at night. The rubber molding that presses up against the glass to keep the water and dust out of the door over the years finely scratched the glass and made it look streaky (almost frosted in area's). I bought some the Eastwood glass polish and it polished it right out and made the glass look like new. I had hard water spots on some of the other windows on the car and it cleaned those windows real nice. I am planning on polishing all the windows on my Cuda' with the Eastwood polish before I re-install them in the car. The Eastwood system works good, but it is messy, so doing it when the glass is out of the car is the best way to do it. Here is a link to the Eastwood polish: http://www.eastwood.com/pro-glass-polishing-kit.html
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: larrymopar360]
#1748943
02/08/15 09:55 PM
02/08/15 09:55 PM
Posts: 22,719 Bitopia
jcc
Bitopia
Lots of suggestions on removal, but what is on the OP's glass in the first place? Almost sounds like the heat treat? streaks one sees sometimes with polarized sunglasses in reflected sunlight.
