Any sealant on edge of freeze plugs? #1744968
02/02/15 04:50 PM
02/02/15 04:50 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
Do you guys put a slight skim coat of sealant on your freeze plugs before you install them in the block?
Re: Any sealant on edge of freeze plugs? [Re: Blakcharger440] #1744969
02/02/15 04:58 PM
02/02/15 04:58 PM
permatex #1, the thick brown goo in the toothpaste like tube, P #1 sets up hard. Have the block hole scraped or wire brushed clean of debris/old sealant & a quick wipe with a rag/brake kleen. light/moderate app of P on the hole and generous amt on the plug (extra ends up on the exterior). Use a large dia of socket that will fit into the plug to drive it in. Most prefer brass plugs & have good luck with them. when plug is flush I wipe a smear of P around the perimeter for a complete circle of the goo (as needed). EDIT use a brass drift on the socket (or a 1/2" drive socket/1/2" extension but it can mar the extension), do what works for you & drive it in with as few strokes as possible & keep everything in line for each hit. get the plug started in square with a medium hit then drive it home (flush) with several good solid whacks. #1 #1 you wanna keep it from tilting
Re: Any sealant on edge of freeze plugs? [Re: Blakcharger440] #1744970
02/02/15 06:29 PM
02/02/15 06:29 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
Permatex Form-A-Gasket is my weapon of choice.
"IF YOU'RE UNDER CONTROl, YOU AIN'T GOING FAST ENOUGH."
Re: Any sealant on edge of freeze plugs? [Re: Blakcharger440] #1744971
02/02/15 06:40 PM
02/02/15 06:40 PM
I use the GM brand (brown thick gooey stuf)thread sealer on them, buy it at your local GM dealer for head bolts and other fasteners that go into the cooling system GM got that stuff correct
Re: Any sealant on edge of freeze plugs? [Re: Cab_Burge] #1744972
02/02/15 07:18 PM
02/02/15 07:18 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Years ago i used to use the brown bottle of Indian Head Shellac. Haven't had to do one now for several years...
...FAFO...
Re: Any sealant on edge of freeze plugs? [Re: skicker] #1744973
02/02/15 10:48 PM
02/02/15 10:48 PM
nothing like JB Weld to ensure zero issues--I use it on all race engines never a drop leaked ever!!! I like old Permatex brown for all else but have had best luck with making sure holes are clean and no gouges from previous plug removal operations--JB and you will never leak a drop no matter what--FWIW I think the brass plug craze is silly--the brass plugs are way softer than the steel and I think the steel plugs fit much tighter and seal better--If you are going to have that car long enough for the steels to rust out then you really plan on a long life!
Re: Any sealant on edge of freeze plugs? [Re: skicker] #1744974
02/02/15 10:50 PM
02/02/15 10:50 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I use the Indian Head Shellac too. never has any issues with it.
Re: Any sealant on edge of freeze plugs? [Re: 451Mopar] #1744975
02/03/15 12:15 AM
02/03/15 12:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Same here
Re: Any sealant on edge of freeze plugs? [Re: JohnRR] #1744976
02/03/15 12:35 AM
02/03/15 12:35 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've used black RTV. Even if it's not needed to help desk, it acts as a lube when installing the new plugs
**Photobucket sucks**
Re: Any sealant on edge of freeze plugs? [Re: RapidRobert] #1744977
02/03/15 12:46 AM
02/03/15 12:46 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Another vote for Permatex #1.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Any sealant on edge of freeze plugs? [Re: GO_Fish] #1744978
02/03/15 01:20 AM
02/03/15 01:20 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Permatex+Brass!
Re: Any sealant on edge of freeze plugs? [Re: RodStRace] #1744979
02/03/15 01:47 AM
02/03/15 01:47 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Indian Head and Steel!
JB Rhinehart, Realist
A-Body's RULE!
Re: Any sealant on edge of freeze plugs? [Re: Rhinodart] #1744980
02/03/15 10:43 PM
02/03/15 10:43 PM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
During the early 1970s our school class did a tour of the local Chrysler engine plant in Adelaide South Australia and we watched the 6cyl Hemi's being assembled, when it came putting in the freeze plugs they used no sealant, went in bone dry and yet I never heard of a freeze plug leaking under warranty only many years down the track from normal corrosion. Maybe with the engine block being a new casting the freeze plug holes were nice and clean not like and old well used block.
Re: Any sealant on edge of freeze plugs? [Re: Blakcharger440] #1744981
02/03/15 11:22 PM
02/03/15 11:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Yes, to answer the question
Re: Any sealant on edge of freeze plugs? [Re: fullonmopar] #1744982
02/03/15 11:26 PM
02/03/15 11:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Some manufacturers will use their own version of sealant when filling the systems for the first time to alleviate minor leaks
Re: Any sealant on edge of freeze plugs? [Re: Blakcharger440] #1744983
02/04/15 12:05 PM
02/04/15 12:05 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Form-A-Gasket for me, too. What could be the advantage of putting them in dry? I can't imagine any down side to having a bit of sealant on them. And can certainly think of several potential problems that might be eliminated with it.
Also, keep an eye on the freeze plugs they give you. More and more of them have a very narrow sealing edge that can be more difficult to get in straight and to seal.
Master, again and still
Re: Any sealant on edge of freeze plugs? [Re: Blakcharger440] #1744984
02/04/15 12:21 PM
02/04/15 12:21 PM
an8sec70cuda Offline
I use white Teflon thread sealant on them and never had a problem.
CHIP
'06 GMC 2500HD LBZ Duramax
