Re: Any sealant on edge of freeze plugs?
[Re: Blakcharger440]
#1744969
02/02/15 03:58 PM
02/02/15 03:58 PM
RapidRobert
permatex #1, the thick brown goo in the toothpaste like tube, P #1 sets up hard. Have the block hole scraped or wire brushed clean of debris/old sealant & a quick wipe with a rag/brake kleen. light/moderate app of P on the hole and generous amt on the plug (extra ends up on the exterior). Use a large dia of socket that will fit into the plug to drive it in. Most prefer brass plugs & have good luck with them. when plug is flush I wipe a smear of P around the perimeter for a complete circle of the goo (as needed). EDIT use a brass drift on the socket (or a 1/2" drive socket/1/2" extension but it can mar the extension), do what works for you & drive it in with as few strokes as possible & keep everything in line for each hit. get the plug started in square with a medium hit then drive it home (flush) with several good solid whacks. #1 #1 you wanna keep it from tilting
[Re: Cab_Burge]
#1744972
02/02/15 06:18 PM
02/02/15 06:18 PM
Posts: 5,136 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Years ago i used to use the brown bottle of Indian Head Shellac. Haven't had to do one now for several years...
...FAFO...
[Re: skicker]
#1744973
02/02/15 09:48 PM
02/02/15 09:48 PM
nothing like JB Weld to ensure zero issues--I use it on all race engines never a drop leaked ever!!! I like old Permatex brown for all else but have had best luck with making sure holes are clean and no gouges from previous plug removal operations--JB and you will never leak a drop no matter what--FWIW I think the brass plug craze is silly--the brass plugs are way softer than the steel and I think the steel plugs fit much tighter and seal better--If you are going to have that car long enough for the steels to rust out then you really plan on a long life!
[Re: skicker]
#1744974
02/02/15 09:50 PM
02/02/15 09:50 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I use the Indian Head Shellac too. never has any issues with it.
[Re: 451Mopar]
#1744975
02/02/15 11:15 PM
02/02/15 11:15 PM
Posts: 75,324 A gulag near you.
JohnRR
A gulag near you.
Same here
[Re: JohnRR]
#1744976
02/02/15 11:35 PM
02/02/15 11:35 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I've used black RTV. Even if it's not needed to help desk, it acts as a lube when installing the new plugs
**Photobucket sucks**
[Re: fullonmopar]
#1744982
02/03/15 10:26 PM
02/03/15 10:26 PM
Posts: 15,993 Omaha Ne
TJP
Omaha Ne
During the early 1970s our school class did a tour of the local Chrysler engine plant in Adelaide South Australia and we watched the 6cyl Hemi's being assembled, when it came putting in the freeze plugs they used no sealant, went in bone dry and yet I never heard of a freeze plug leaking under warranty only many years down the track from normal corrosion. Maybe with the engine block being a new casting the freeze plug holes were nice and clean not like and old well used block.
Some manufacturers will use their own version of sealant when filling the systems for the first time to alleviate minor leaks
#1744983
02/04/15 11:05 AM
02/04/15 11:05 AM
Posts: 13,031 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Form-A-Gasket for me, too. What could be the advantage of putting them in dry? I can't imagine any down side to having a bit of sealant on them. And can certainly think of several potential problems that might be eliminated with it.
Also, keep an eye on the freeze plugs they give you. More and more of them have a very narrow sealing edge that can be more difficult to get in straight and to seal.
Master, again and still
#1744984
02/04/15 11:21 AM
02/04/15 11:21 AM
Posts: 13,530 Marion, South Carolina [><]
an8sec70cuda
I use white Teflon thread sealant on them and never had a problem.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
