What size headers tubes on your B1 combo's #1741816
01/29/15 07:45 PM
01/29/15 07:45 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
B1 heads only please but I am soon going to be having a set of headers made for my B1 headed 572. Probably going to be a stepped header type design but what are you guys running. This will be for a nitrous combo. Thanks
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What size headers tubes on your B1 combo's [Re: pittsburghracer] #1741817
01/29/15 08:11 PM
01/29/15 08:11 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
2 3/8 - 2 1/2 step x 4 1/2 collector on a 511 B1
Re: What size headers tubes on your B1 combo's [Re: pittsburghracer] #1741818
01/29/15 08:18 PM
01/29/15 08:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My 525 junker is 2 1/4 to 2 3/8 with a collector muffler.
Re: What size headers tubes on your B1 combo's [Re: pittsburghracer] #1741819
01/29/15 08:22 PM
01/29/15 08:22 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
3in. to 8in. collector.
Re: What size headers tubes on your B1 combo's [Re: Al_Alguire] #1741820
01/29/15 08:24 PM
01/29/15 08:24 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
2 1/4-2 3/8 4 1/2 collector
Re: What size headers tubes on your B1 combo's [Re: pittsburghracer] #1741821
01/29/15 08:59 PM
01/29/15 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Max RPM is also part of the equation and the amount
your gonna hit it with.. if I were home I could run
your engine through my header program to tell you
what you need.... but I cant.. its on my other puter
Re: What size headers tubes on your B1 combo's [Re: MR_P_BODY] #1741822
01/29/15 09:13 PM
01/29/15 09:13 PM
a493demon Offline
a493demon  Offline
Re: What size headers tubes on your B1 combo's [Re: a493demon] #1741823
01/29/15 09:25 PM
01/29/15 09:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
http://www.wallaceracing.com/header_length.php
I wouldnt base my headers on that.. it has a good
bit of the info needed but it sure doesnt ask all
of the data needed... I've been using the header max
program for years and have tested it on the dyno
Re: What size headers tubes on your B1 combo's [Re: MR_P_BODY] #1741824
01/29/15 09:53 PM
01/29/15 09:53 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
505 cu. in. with stainless step headers, 2" - 2-1/8" to 2-1/4" . Merge collectors. Shift at 6100, and cross the traps at 6700rpm.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: What size headers tubes on your B1 combo's [Re: Dartsport540] #1741825
01/29/15 10:24 PM
01/29/15 10:24 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
2 3/8 x 4.5 572
Re: What size headers tubes on your B1 combo's [Re: Mopar-Al] #1741826
01/29/15 11:25 PM
01/29/15 11:25 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I did 2.375" on my Coronet years ago and would never do it again . I don't care what some calculator says , it has to fit in car.A 2.25" would work just as good and it is way easier to buy and find in stainless or carbon . The B1 is only a 1.78" valve so its not fooling anybody by putting a macho pipe in it.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: What size headers tubes on your B1 combo's [Re: pittsburghracer] #1741827
01/30/15 12:08 AM
01/30/15 12:08 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Don't really Matter if you spray it hard..:)
Re: What size headers tubes on your B1 combo's [Re: fishy340] #1741828
01/30/15 12:36 AM
01/30/15 12:36 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though not a B-1 Chuck from best did a header test a while back and posted it. I believe it was an 572 -1. The smaller 2 1/8" were better until the very end of the range like 6000-6500
Doug
Re: What size headers tubes on your B1 combo's [Re: dvw] #1741829
01/30/15 12:44 AM
01/30/15 12:44 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The only 2 chassis headers I have is 2 1/8 and 2 3/8 If I had 2 1/4 I'd try them, but they just don't give them away
Re: What size headers tubes on your B1 combo's [Re: Mopar-Al] #1741830
01/30/15 01:36 AM
01/30/15 01:36 AM
PA.
"Little"John
"Little"John
PA.
Thanks guys. Just got back home from a night out with my Son. I will study this and get planning.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What size headers tubes on your B1 combo's *DELETED* [Re: dvw] #1741831
01/30/15 05:15 PM
01/30/15 05:15 PM
NC
440Jim Offline
440Jim  Offline
NC
Post deleted by 440Jim
Re: What size headers tubes on your B1 combo's [Re: 440Jim] #1741832
01/30/15 05:28 PM
01/30/15 05:28 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
i run 2.25 on my dart. i went from tti 1.125 on my engine without the blower and with and it didn't see anything on the chassis dyno
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What size headers tubes on your B1 combo's [Re: dvw] #1741833
01/30/15 05:32 PM
01/30/15 05:32 PM
NC
440Jim Offline
440Jim  Offline
NC
Doug
I think I found it with the search:
https://board.moparts.org/ubbthreads/show...rue#Post8275911
572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results
Indy Alum Block
Indy 440-1 345CNC Heads
Indy 440-3X Intake
Quick Fuel 2.125 4500 Carb Re done by Bob Book
HVH 2” Spacer
T&D Single Shaft Rockers 1.6 / 1.6
BMBBR5 Roller Cam 283 on a 115
Jesel Belt Drive
Race Tec Pistons 15 to 1 .043/.043
758 tq at 5700, 939 hp at 7400, TTI Headers 2.125 x 3.5
728 tq at 5900, 946 hp at 7100, 2.125 to 2.375 to 2.500 with a 5" collector
Re: What size headers tubes on your B1 combo's [Re: 440Jim] #1741834
01/30/15 06:20 PM
01/30/15 06:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A 5" collector that is simple Redonculous
Re: What size headers tubes on your B1 combo's [Re: Al_Alguire] #1741835
01/31/15 12:33 AM
01/31/15 12:33 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
Interesting post. Im having 622 with PSO heads built and will need headers. It is a pump gas engine with shift points around 7000ish in a 72 Barracuda. Have been told TTI 2"-2 1/8" step with 3 1/2 collector will be enough. Im kinda skeptical about them. If need be ill have custom ones made.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
