Comp Cams pushrods bent out of the box??? #1741666
01/29/15 02:37 PM
01/29/15 02:37 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I just bought a set of these pushrods:
http://www.summitracing.com/parts/CCA-7442-16
And seems they were bent before they came out of the box.
I was setting lash on my engine and when it was all done and i was spinning em by hand I can see them wobble some....so they are a bit bent. Or maybe the cups installed a bit crooked? Anyway they DO NOT spin on center, they wobble while spinning....
Is this wrong or is it normal to see a very slight wobble even on brand new pushrods???
Id say they are defective???
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741667
01/29/15 02:42 PM
01/29/15 02:42 PM
Locomotion Offline
Locomotion  Offline
Anything is possible. Double-check by rolling them on a piece of glsss or something similar, with the cup hanging off the edge.
I got a Mopar Performance piston once that the wrist pin hole was machined about 20* off!
Re: Comp Cams pushrods bent out of the box??? [Re: Locomotion] #1741668
01/29/15 03:04 PM
01/29/15 03:04 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I did the glass test and if that was the only test I would base my opinion on....Id say the pushrods are good.
However, when I install em in my engine with last set...and I spin em with my fingers when the lifter is riding on the cam's base circle I can DEFINTELY see em wobble some when ....
So?
Has my OCD probably taken over???
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741669
01/29/15 05:02 PM
01/29/15 05:02 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Sorry but I kinda chuckled when I read the title of your post. In the late 70's my Friends and I flew down to Daytona Beach for a little vacation. My one Friend was reading a National Dragster magazine and said hey Crane Cams is nearby so he called and arranged to take a tour. We really enjoyed the tour and towards the end of it sat a little old lady hand spinning pushrods in a jig with a dial indicator and smacking them with a hammer to straighten them out. LOL at quality control at its finest.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Comp Cams pushrods bent out of the box??? [Re: pittsburghracer] #1741670
01/29/15 05:24 PM
01/29/15 05:24 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741671
01/29/15 05:26 PM
01/29/15 05:26 PM
dogdays Offline
dogdays  Offline
From a loading point of view, I believe it is more important that the body of the pushrod be straight.
R.
Re: Comp Cams pushrods bent out of the box??? [Re: dogdays] #1741672
01/29/15 05:48 PM
01/29/15 05:48 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I found some "new" bent head bolts a while back by chucking them carefully in a drill press.
Re: Comp Cams pushrods bent out of the box??? [Re: pittsburghracer] #1741673
01/29/15 06:06 PM
01/29/15 06:06 PM
USA
B3RE Offline
B3RE  Offline
USA
Sorry but I kinda chuckled when I read the title of your post. In the late 70's my Friends and I flew down to Daytona Beach for a little vacation. My one Friend was reading a National Dragster magazine and said hey Crane Cams is nearby so he called and arranged to take a tour. We really enjoyed the tour and towards the end of it sat a little old lady hand spinning pushrods in a jig with a dial indicator and smacking them with a hammer to straighten them out. LOL at quality control at its finest. [/quote
That sounds wacky, but it's not unusual. The rods may have been straight, but the heat treating process warps them. The fix is to bend them back to straight again. I would say in the OP's case, the cups are not perpendicular to the rods. Could be sloppy machining.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741674
01/29/15 06:42 PM
01/29/15 06:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So?
Do they feel like they are binding as you rotate them , does the rocker move up and down while rotating ?
Re: Comp Cams pushrods bent out of the box??? [Re: JohnRR] #1741675
01/29/15 07:51 PM
01/29/15 07:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
NO they dont feel like they are binding....
but if I take the lash off by slightly preloading the rocker arm against the pushrod and rotate it using my fingers i can see a bit of wobble as it rotates with my naked eye but that closing one eye and looking real close....some are worse, some are better. I found 6 to be "acceptable" and 10 to be "too wobbly".
but then again when i roll those 10 bad ones on a piece of glass they look ok...i can see no visible wobble with my naked eye....
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741676
01/29/15 08:24 PM
01/29/15 08:24 PM
must be the ones sent back last month
Re: Comp Cams pushrods bent out of the box??? [Re: ] #1741677
01/29/15 08:52 PM
01/29/15 08:52 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I guess Im gonna call summit and tell em these are no good....
but if I get another set like it I fear they might be just as bad???
Who makes GOOD pushrods?
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741678
01/29/15 09:05 PM
01/29/15 09:05 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Smith Brothers
If you like drag racing, support your local track.
Re: Comp Cams pushrods bent out of the box??? [Re: CHAPPER] #1741679
01/29/15 09:11 PM
01/29/15 09:11 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
what about TREND and MANTON?
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741680
01/29/15 09:31 PM
01/29/15 09:31 PM
Locomotion Offline
Locomotion  Offline
How about chucking them up in a drill and watching it from the side and from the end. Compare the results to something alse about the same length.
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741681
01/29/15 09:35 PM
01/29/15 09:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Trend makes good PRs also... I have never used Manton
so I dont know... I have used Smith Brothers and they
are good but pricey
Re: Comp Cams pushrods bent out of the box??? [Re: MR_P_BODY] #1741682
01/29/15 09:37 PM
01/29/15 09:37 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have used trend before and was satisfied with their product....I think I will use em again.
Known good is better than unkown perfect I guess....lol
Re: Comp Cams pushrods bent out of the box??? [Re: domingo] #1741683
01/29/15 09:44 PM
01/29/15 09:44 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
guys i heard trend now makes them for comp and smith and manton are their own
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Comp Cams pushrods bent out of the box??? [Re: sublimehemi] #1741684
01/29/15 10:08 PM
01/29/15 10:08 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
One thing to check is the pushrod tip the right size for the lifter cup? some have 5/16 cup some 3/8 and the same with pushrods most get the cup on top of the pushrod right and miss the lifter cup.
Something you might want to look at.
Re: Comp Cams pushrods bent out of the box??? [Re: DAYTONA540] #1741685
01/30/15 02:35 AM
01/30/15 02:35 AM
408Dust Offline
408Dust  Offline
http://stewardperformance.com/contact.html
Call Denny 386-957-3879.great service and product.
