Head port molding. Try it, you may like it. #1734867
01/20/15 03:41 PM
01/20/15 03:41 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Working on a set of B1 heads for this years build and trying to get 10-15 more CFM out of them so I poured a port mold so I could see a nice 3D mold of where I was at this point. I rarely pour anymore but being this is for a heads-up build if its there I gotta grab it. Very easy to do at home for the home head porters and I think this would help some if you never tried it. Here is a link of the place I deal with. If you order some talk to a tech and DON"T forget to order a spray can of "mold release"
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734868
01/20/15 03:44 PM
01/20/15 03:44 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734869
01/20/15 03:46 PM
01/20/15 03:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WAY cool and even better than a probe camera.
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734870
01/20/15 03:46 PM
01/20/15 03:46 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
how much shrink does the product have after it is removed from the mold?
Could you use it to make a mold out of something else easier to shape and less expensive then a head for test porting?
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734871
01/20/15 03:48 PM
01/20/15 03:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cool how much does it take per intake port?
Re: Head port molding. Try it, you may like it. [Re: CTD5.9] #1734872
01/20/15 04:01 PM
01/20/15 04:01 PM
PA.
"Little"John
"Little"John
PA.
Zero shrinkage so you can easily take port measurements at any given point. Not sure about making a mold of something. To remove it from the port you have to slice it behind the valve guide with a razor making a nice clean cut and then PULL it out the manifold face.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: Dodgem] #1734873
01/20/15 04:07 PM
01/20/15 04:07 PM
PA.
"Little"John
"Little"John
PA.
What I did was took the approximate runner cc and then I googled a chart to change it over to ounces. I then used one of my cheap pre-marked plastic paint mixing containers. I mixed about 4 oz of each but every head would be different. I kinda messed up when I placed an order about 5 years ago and over-ordered. It took awhile but mine was going bad and I really had to work getting it out of the bottles. Next time I will order way less.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734874
01/20/15 04:10 PM
01/20/15 04:10 PM
In a house near you
Street Monkies Offline
In a house near you
Definitely cool. A lot can be figured out doing this. Thanks for the share.
Re: Head port molding. Try it, you may like it. [Re: Street Monkies] #1734875
01/20/15 04:13 PM
01/20/15 04:13 PM
PA.
"Little"John
"Little"John
PA.
Thanks. Its really nice to be able to take your work into the house and study it, flipping it in every possible position. Heck I've gotten out of bed at times to check something out.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734876
01/20/15 10:15 PM
01/20/15 10:15 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
the hole in the end looks interesting
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Head port molding. Try it, you may like it. [Re: WHITEDART] #1734877
01/20/15 10:27 PM
01/20/15 10:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
PERV.................
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734878
01/20/15 11:23 PM
01/20/15 11:23 PM
Az
Crizila Offline
Crizila  Offline
Az
by sectioning every 1/4" or so, you can easily plot the port area at 1/4" stations and pinpoint the pinch point.
Fastest 300
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734879
01/21/15 07:30 AM
01/21/15 07:30 AM
Western MA, +121 posts on old ...
sixpacstac Offline
super gas
sixpacstac  Offline
super gas
What razor do you use to reach down into the port for the slice? I started experimenting with this a couple of years ago. Have a port I poured that I had trouble removing the mold and I set it aside until I had more time for it. The razor may solve my issue.
I hope my leftover mold mix is still usable after sitting so long.
-'76 Volare, 340, 950 Holley HP, 3500 stall, 8 3/4 w/4.11's, 11.80 E.T., 113 MPH
Re: Head port molding. Try it, you may like it. [Re: sixpacstac] #1734880
01/21/15 12:02 PM
01/21/15 12:02 PM
PA.
"Little"John
"Little"John
PA.
I have a long handle craft type razor blade that I usually use but I couldn't find it yesterday so I grabbed a regular new scraper razor blade and held it in my hand. It worked GREAT on this head but might have been tricky on a smaller bowl. Just try to make one clean cut so if you want or need to super glue it together you can. I also take a small screwdriver and work it between the head and mold all the way around the port. Did you spray it with mold release compound?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734881
01/21/15 12:22 PM
01/21/15 12:22 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Why the big bow in the wall of the port? Is it to give it swirl as it enters the bowl and to help bias it away from the cylinder wall as it enters the bore?
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734882
01/21/15 05:17 PM
01/21/15 05:17 PM
sixpacstac Offline
super gas
sixpacstac  Offline
super gas
I screwed up on that one intake port and did forget the mold release which is obviously making it more difficult. I used a flat, dull butter knife and tried to work it around between the mold and the port to help release it. I also sprayed mold release a few times after the fact. I'm hoping that slicing it at the valve guide like you've mentioned will give the mold some more flexibility in order to come out. Thanks for your post.
Re: Head port molding. Try it, you may like it. [Re: sixpacstac] #1734883
01/21/15 05:30 PM
01/21/15 05:30 PM
PA.
"Little"John
"Little"John
PA.
I hope it helps.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734884
01/21/15 07:52 PM
01/21/15 07:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'll have to give that a try to get a different perspective on my own efforts.
Re: Head port molding. Try it, you may like it. [Re: BradH] #1734885
01/21/15 08:51 PM
01/21/15 08:51 PM
PA.
"Little"John
"Little"John
PA.
It really does Brad. Sure beats flipping a head over 15 times looking at the short-side from different angles. I did a set of cast iron Dart Platinum's for a Friend and I skipped going to the gym that week.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Head port molding. Try it, you may like it. [Re: pittsburghracer] #1734886
01/21/15 10:43 PM
01/21/15 10:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
We did that stuff all the time at work.. ports were
just one of the things... yeah you gotta spray mold
release agent.. its cool once you get it out... had
plenty of them laying around
