Re: New Spectra Fuel Tank Sending Units
[Re: biggE]
#1734424
01/20/15 05:03 PM
01/20/15 05:03 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Has anyone tried the new made in Canada Spectra fuel tank sending units? I would like to know if they work correctly. I have had zero luck with all other reproduction sending units.
i just ordered one via Dixie Restoration. in an e-mail to me Randy said there have been zero issues reported over a 2 year span.
[Re: mikemee1331]
#1734425
01/20/15 08:11 PM
01/20/15 08:11 PM
Posts: 1,032 Ohio
dobie
Ohio
Interesting. I'd love an update if you could. I've tried 3 different sending units, all purchased from separate sellers, and all 3 haven't worked right.
1968 Plymouth Road Runner
383 4 speed
[Re: dobie]
#1734426
01/20/15 08:17 PM
01/20/15 08:17 PM
mikemee1331
bethlehem pa
I'll be sure to post my luck when I install it. sadly it won't be until March. my garage is not heated! ![](/ubbthreads/images/graemlins/Snowblow.gif)
[Re: wedgepower]
#1734429
01/21/15 04:45 PM
01/21/15 04:45 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Mopars are easy.First make sure the sender is grounden the strap Ma used usually is bad.Then remove the sender wire at the sender.Ground I prefer the battery and turn on the key.Gauge should go to full.Dont leave it on long just enough to see the movement toward full.If it moves and groound is good its probally the float.They get full of gas and stay down.Pull the sender and Ohm movement If good its the float that Ford has a good replacement for vans.Rocky
Chrysler Firepower
