New Spectra Fuel Tank Sending Units #1734422
01/19/15 07:31 PM
01/19/15 07:31 PM
California
biggE Offline OP
biggE  Offline OP
California
Has anyone tried the new made in Canada Spectra fuel tank sending units? I would like to know if they work correctly. I have had zero luck with all other reproduction sending units.
Re: New Spectra Fuel Tank Sending Units [Re: biggE] #1734423
01/19/15 07:35 PM
01/19/15 07:35 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Can't help but is it advertised as being better quality??
Re: New Spectra Fuel Tank Sending Units [Re: biggE] #1734424
01/20/15 05:03 PM
01/20/15 05:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i just ordered one via Dixie Restoration. in an e-mail to me Randy said there have been zero issues reported over a 2 year span.
Re: New Spectra Fuel Tank Sending Units [Re: mikemee1331] #1734425
01/20/15 08:11 PM
01/20/15 08:11 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Interesting. I'd love an update if you could. I've tried 3 different sending units, all purchased from separate sellers, and all 3 haven't worked right.
1968 Plymouth Road Runner 383 4 speed
Re: New Spectra Fuel Tank Sending Units [Re: dobie] #1734426
01/20/15 08:17 PM
01/20/15 08:17 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I'll be sure to post my luck when I install it. sadly it won't be until March. my garage is not heated!
Re: New Spectra Fuel Tank Sending Units [Re: mikemee1331] #1734427
01/21/15 01:58 PM
01/21/15 01:58 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
There is usually a ground strap from the fuel nipple on the sender to the steel fuel line that bridges the connection rubber hose.
Re: New Spectra Fuel Tank Sending Units [Re: biggE] #1734428
01/21/15 03:01 PM
01/21/15 03:01 PM
mesa,az.
wedgepower Offline
wedgepower  Offline
mesa,az.
Anybody know how to troubleshoot the gauge and wiring? My womans car does have a working system. I'd like to narrow down the problem before I start buying parts.
Re: New Spectra Fuel Tank Sending Units [Re: wedgepower] #1734429
01/21/15 04:45 PM
01/21/15 04:45 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mopars are easy.First make sure the sender is grounden the strap Ma used usually is bad.Then remove the sender wire at the sender.Ground I prefer the battery and turn on the key.Gauge should go to full.Dont leave it on long just enough to see the movement toward full.If it moves and groound is good its probally the float.They get full of gas and stay down.Pull the sender and Ohm movement If good its the float that Ford has a good replacement for vans.Rocky
Chrysler Firepower
