Will it pass tech inspection? #173365
12/23/08 01:28 PM
12/23/08 01:28 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
One of my projects this winter is to upgrade my fuel system. I'm going to run 2 140gph electric fuel pumps in parallel to a Y feeding a 1/2" line up to the regulator. As this is also a street driven vehicle, I'd also like to install a couple 1/4 turn shutoff valves between the fuel cell and each pump. I'd shut one down for street driving, and have a convenient spare.
Does anyone know if this would get tossed by the tech inspector at the track?Dave
Re: Will it pass tech inspection? [Re: quickd100] #173366
12/23/08 01:35 PM
12/23/08 01:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It'll pass, if its in the proper area of the veh and
protected if hanging low
Re: Will it pass tech inspection? [Re: MR_P_BODY] #173367
12/23/08 01:39 PM
12/23/08 01:39 PM
nielsville, minn.
Q
Q
nielsville, minn.
Thanks Mike! That allI needed to know. Dave
Re: Will it pass tech inspection? [Re: quickd100] #173368
12/23/08 10:34 PM
12/23/08 10:34 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
To answer the question, I don't see why it wouldn't pass tech at the track. But, I don't think you want to run a pump if you have the fuel to it shut off. The fuel acts as a coolant and lubricant. Why not run a separate switch, relay or whatever for each pump and only run 1 pump except when you are at the track? Worked for me when I used 2 Holleys.
Post deleted by Defbob [Re: CMcAllister] #173369
12/23/08 10:44 PM
12/23/08 10:44 PM
Re: Will it pass tech inspection? #173370
12/23/08 10:57 PM
12/23/08 10:57 PM
nielsville, minn.
Q
Q
nielsville, minn.
I sorry if I wasn't real clear. I intend to run separate switches and wiring to the 2 pumps. I have no intention on running a pump without fuel in it. I just can't see running both pumps when i'm just cruising around. If I get hassled by some dumb punk in a mustwang it's easy to step out and turn a quarter turn valve on if need be. Dave
Re: Will it pass tech inspection? #173371
12/23/08 10:57 PM
12/23/08 10:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Is the OP concerned about back feeding the turned off pump, and therefore thinks he needs an inline shut-off valve?
Post deleted by Defbob [Re: quickd100] #173372
12/23/08 11:27 PM
12/23/08 11:27 PM
Re: Will it pass tech inspection? #173373
12/23/08 11:32 PM
12/23/08 11:32 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Better yet, keep it simple and install one big return-style pump and be done with it.
That's how it was done in the new car (in my sig.)
Re: Will it pass tech inspection? #173374
12/23/08 11:35 PM
12/23/08 11:35 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
One pump and a return style system with enough flow to do the job. Simpler and less expensive.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Will it pass tech inspection? [Re: fasteddie] #173375
12/23/08 11:50 PM
12/23/08 11:50 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If you do not stop the flow the pump will backfeed. The reason is the vanes will slide into the drive wheel when the pump is not spinning.
You do not have to run 1/4 turn valves. You can simply install a check ball valve in the line between race only pump and Y-block. This way when cruising the street you run one pump and the check ball valve. This will work.
I WOULD SIMPLY RUN A GOOD PUMP LIKE THE AEROMOTIVE A2000. THIS IS A RETURN STYLE PUMP THAT WILL DO WELL WITH CONTINUOUS SERVICE. THEY ARE VERY REASONABLE PUMPS. 350 GPH AND HAVE A RETURN BUILT IN AND ADJUSTABLE REGULATOR FOR DESIRED LINE PRESSURE.
Leon
Re: Will it pass tech inspection? [Re: Leon441] #173376
12/23/08 11:57 PM
12/23/08 11:57 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Even Aeromotive suggests not running an a2000 on the street without a stepdown box though...
Re: Will it pass tech inspection? [Re: quickd100] #173377
12/24/08 09:31 AM
12/24/08 09:31 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
on mine, I have 2 pumps.
Switch for each.
Works great.
I even alternate which pump I run
until I use both.
