Re: Will it pass tech inspection?
[Re: quickd100]
#173368
12/23/08 10:34 PM
12/23/08 10:34 PM
Posts: 11,655 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
To answer the question, I don't see why it wouldn't pass tech at the track. But, I don't think you want to run a pump if you have the fuel to it shut off. The fuel acts as a coolant and lubricant. Why not run a separate switch, relay or whatever for each pump and only run 1 pump except when you are at the track? Worked for me when I used 2 Holleys.
Post deleted by Defbob
[Re: CMcAllister]
#173369
12/23/08 10:44 PM
12/23/08 10:44 PM
[Re: quickd100]
#173372
12/23/08 11:27 PM
12/23/08 11:27 PM
#173373
12/23/08 11:32 PM
12/23/08 11:32 PM
Posts: 2,379 MD
Kevins493
MD
Better yet, keep it simple and install one big return-style pump and be done with it.
That's how it was done in the new car (in my sig.)
[Re: fasteddie]
#173375
12/23/08 11:50 PM
12/23/08 11:50 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
If you do not stop the flow the pump will backfeed. The reason is the vanes will slide into the drive wheel when the pump is not spinning.
You do not have to run 1/4 turn valves. You can simply install a check ball valve in the line between race only pump and Y-block. This way when cruising the street you run one pump and the check ball valve. This will work.
I WOULD SIMPLY RUN A GOOD PUMP LIKE THE AEROMOTIVE A2000. THIS IS A RETURN STYLE PUMP THAT WILL DO WELL WITH CONTINUOUS SERVICE. THEY ARE VERY REASONABLE PUMPS. 350 GPH AND HAVE A RETURN BUILT IN AND ADJUSTABLE REGULATOR FOR DESIRED LINE PRESSURE.
Leon
