Page 1 of 4 1 2 3 4
Maxium Power Through 6-Pack Induction w/500 inches #1731223
01/16/15 09:30 AM
01/16/15 09:30 AM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
friend wants to build a 500" 440, using aluminum heads w/ mild porting,2" headers,3" exhaust, 250@.050/.600 camshaft,and top it with a 6-pack.
some claim that the manifold will be the bottle neck in this build.
what do you think?
didn't Mopar Muscle do a engine challenge with a combination like this?
if so i can't find it
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 4spdana] #1731224
01/16/15 10:29 AM
01/16/15 10:29 AM
It will be like a governor on it. Also when you are just riding around remember you will be driving that 500 CI on those TWO tiny throttle bores in that center carb--not good imo
I did a back to back on a 600 HP unit like you mention--with a single four it was like a different animal--I am no six pack fan when it comes to the big cube units
Not to mention the long period of time and $$$ it will take to get it running suitable--there will be folks that stand up and say that they can/have made six packs run perfect but......most folks wind up pulling their hair out on those deals.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 4spdana] #1731225
01/16/15 10:33 AM
01/16/15 10:33 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
This a customers car.
BUT, it's 493 cu in. 735 something horse
A little to much cam IMO ( I think its near 700" lift ) , but this thing is a brute.
I know the intake had some port work but dont know how much . For that I will foward this to the cars owner and maybe he'll respond with better details.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: gtx6970] #1731226
01/16/15 12:47 PM
01/16/15 12:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think with some clean up work and a good tune on the carbs he'll be fine. I wouldn't just drop a out of the box unit on and think it will be fine. There are some tricks you can do w/ the outboards that make them run better or he can bite the bullet and get the outboard metering plates. I don't have near the build but I do enjoy getting 15mpg and running mid 11's (low 11's soon)
Coming soon!!!!
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: Mr.Yuck] #1731227
01/16/15 12:51 PM
01/16/15 12:51 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How is it that nobody makes a good single plane 6 pack intake?
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: DaytonaTurbo] #1731228
01/16/15 01:14 PM
01/16/15 01:14 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
if I was going to run a six pack I would get the weiand cross ram six pack intake. especially when big cubes are involved.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 4spdana] #1731229
01/16/15 02:00 PM
01/16/15 02:00 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Easy fix. A real Six Pack .
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 4spdana] #1731230
01/16/15 05:37 PM
01/16/15 05:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
friend wants to build a 500" 440, using aluminum heads w/ mild porting,2" headers,3" exhaust, [Email]250@.050/.600[/Email] camshaft,and top it with a 6-pack.
what do you think?
Don't beleive what you hear, especially from those that do not own or ever used a sixpak My 518 C.I. pump gas low deck stroker made a lot of power from day one with a set of mildly ported 906 iron heads, 612 HP @ 5500 RPM and 644 Ft. lbs @ 4500 with 511 C.I. I swapped the heads(CNC ported Eddy RPM ) and then swapped the crank the next year to bring the dished piston up to zero deck. The last time that motor was on the dyno with the Eddy dual plane low deck sixpak intake and stock type OEM 440 six pak carbs jetted fatter it made 720 HP and 710 Ft lbs. on 10% Ethanol Oregon pump swill Are there better intakes and carbs, yes there are Will his sixpak make good power, YOU BET it will My 3450 lb (with me in it) Duster ran a best of 10.15 at 132 MPH with the six pak, it ran 9.993 at 134.6 MPH with a set of Indy SR M.W. ports and a 1050 Holley Dominator on a Indy 400-3 intake on non ethanol Oregon pump swill with the exhaust and air cleaners on The sixpak carbs need tuning to get them perfect, have him jet the outboard carbs up to around .089 on the fuel inlet holes and leave the center carb. stock on the jetting, he will need to work on the vacume pod springs to get the carbs to open the way he likes them Have him adjust the idle mixture screws on the outboard carbs all the way in (gently) until the bottom out and then open them no more than 1/2 turn out and then start the motor up and adjust the center carb. idle mixture screws and idle speed screw to get it where he likes BB Mopars like air, the more the better Let us know what you guys do and how it runs
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: Cab_Burge] #1731231
01/16/15 05:52 PM
01/16/15 05:52 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
"alum heads/mild porting", the intake will probably flow more than the heads. go for it!
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: lewtot184] #1731232
01/16/15 06:11 PM
01/16/15 06:11 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Doesn't the 6 pack setup ultimately flow around 1350cfm? hard to imagine the carbs being the limiting factor on horsepower, especially when you consider how fast people are going on a single dominator.
Tunnel ram intake with removable top and and a 6 bbl adapter would be neat. anyone ever done anything like that?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: VincentVega] #1731233
01/16/15 06:52 PM
01/16/15 06:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No it really only flows about 950cfm
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: JohnRR] #1731234
01/16/15 06:56 PM
01/16/15 06:56 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I will not dispute you, however I have seen the 1350 figure from multiple sources, including Hot Rod
http://www.hotrod.com/how-to/engine/mopp-0801-mopar-six-pack-tuning/
Where did you find 950?
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: VincentVega] #1731235
01/16/15 07:00 PM
01/16/15 07:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Now I see 1030? the outboards are considered a 500 cfm carbs but they're really not.
https://board.moparts.org/ubbthreads/showflat.php?Number=7515387
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: JohnRR] #1731236
01/16/15 07:04 PM
01/16/15 07:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
John just wishes he had one..
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: Mr.Yuck] #1731237
01/16/15 07:06 PM
01/16/15 07:06 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I had always figured 2 x 500 + 350.
although, that is a pretty healthy figure for the end carbs.
I have one of those aluminum high rise 6 bbl intakes for small block, along with a set of reproduction Holley carbs for it. was a christmas present probably 15 years ago, maybe longer. never used it on anything yet!
in fact, here is my intake
I love that manifold. Would love to EFI it with 3 throttle bodies
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: VincentVega] #1731238
01/16/15 08:04 PM
01/16/15 08:04 PM
dogdays Offline
dogdays  Offline
So we go through this again: Twice in the same thread!
Two barrel carbs are rated at a 3 inch pressure drop across the carb. Four barrel carbs are rated at 1.5 inches of pressure drop. To convert from a two barrel rating to a four barrel rating you DIVIDE BY THE SQUARE ROOT OF TWO!!!
That's 1.414... for those who don't have a calculator with a square root key.
1350 / SQRT2 = 955cfm.
1150 / SQRT2 = 813cfm.
etc.
R.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: Mr.Yuck] #1731239
01/16/15 08:50 PM
01/16/15 08:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I did at one point , my first 69 RR had a 440-6pk ...
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: dogdays] #1731240
01/16/15 08:52 PM
01/16/15 08:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
etc.
R.
The thread is not done yet , we will probably go thru it a few more times.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 4spdana] #1731241
01/16/15 08:52 PM
01/16/15 08:52 PM
AndyF Offline
AndyF  Offline
The six pack intake will kill off some top end power on a big motor like that but if that is what the guy wants then who cares.
A good single plane intake with a big 4150 carb will make more power on the dyno than a six pack setup but it might not matter depending on who the guy is and how he drives the car.
I'm going to put a six pack on my low deck 512 even though it will kill some top end power. I just like the way it looks. I'm assuming that I'll be able to tune it but I'm sure it will take some work.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: dogdays] #1731242
01/16/15 09:18 PM
01/16/15 09:18 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
etc.
R.
I never knew this. Is this a holley thing only? But I don't believe it is that simple, as an engine will have a vacuum reading (draw) all over the place.
On a large enough engine, with a big enough draw, who is to say it won't pull 3 inches? or even more? If it does that, then the 1350 capacity is now reality. I would say on a big enough engine, with cam, and high rpm, it should be possible.
So what is the point of the discussion? to talk theory, or application?
Page 1 of 4 1 2 3 4
