"Hobbyists" w/ pro-level tools, equipment, etc.? #1729677
01/14/15 02:24 PM
01/14/15 02:24 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I'm looking seriously into a flowbench upgrade, like something that can pull 450+ cfm @ a real 28" H2O test pressure, instead of relying on major correction factors like I have to use w/ my current bench.
So, that got me wondering about other people are into this type of car stuff as a hobby who also have set themselves up w/ what would otherswise be considered "overkill" professional-level equipment, tools, etc.
Anybody else want to jump in to help me rationalize this more easily?
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: BradH] #1729678
01/14/15 02:41 PM
01/14/15 02:41 PM
Az
Crizila Offline
Crizila  Offline
Az
I have no problem rationalizing it - selling the wife is another story. She walks around the garage now and sez, "when's the last time you used that?" Using a correction factor can still be pretty accurate.
Fastest 300
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: Crizila] #1729679
01/14/15 02:48 PM
01/14/15 02:48 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
the only pro level anything to be used as a hobbiest I would even consider is the size of the garage. My garage is 2000sq ft and its not enough.
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: sixpackgut] #1729680
01/14/15 03:42 PM
01/14/15 03:42 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
To me, the rationalization is easy: If you want it, and CAN AFFORD it...get it!
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: cudadoug] #1729681
01/14/15 03:57 PM
01/14/15 03:57 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've got my Land&Sea dyno, it was easy, 'I wanted it, I needed it, and I deserved it!' If you want something bad enough you'll always find a way to get it and justify it.Dave
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: cudadoug] #1729682
01/14/15 03:57 PM
01/14/15 03:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just have a few machines that are above the normal..
a mill and a lathe... hand tools.. and the bore gauge
and 0-6" mic set.. and of course my welders and I
have a 4' sand blaster, sheet metal break and roller,
bead roller... I've sold off all my chassis bending
tools like the hyd bender and I sold my old flow bench..
thats about all the big stuff.... and there is always
the space issue.... LACK OF IT
EDIT
I've had this BIG desire to buy a engine dyno the
last couple of years... that might be next if I can
figure out the space
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: cudadoug] #1729683
01/14/15 04:10 PM
01/14/15 04:10 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Can you rationalize anything in this hobby?
Tools are probably one of the only things you can rationalize since they are in fact needed to perform certain tasks. If you don't have what you need, you're paying someone else to do whatever it is you need done.
How often do you need heads flowed? Can you justify the initial investment over paying someone else to do it however many times?
You could eventually make some money back and do it as a service for others if you were inclined.
When I was a tech, I had to rationalize most everything I bought from the tool trucks. This was especially true if I only used something a handful of times or just wanted the latest and greatest mousetrap. But, if I could open my tool box and get what I needed without having to borrow it, that was reason enough, .
'71 Duster
'72 Challenger
'17 Ram 1500
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: RMCHRGR] #1729684
01/14/15 04:23 PM
01/14/15 04:23 PM
BradH Offline OP
BradH  Offline OP
You can rationalize anything in this hobby!
Fixed it for ya'.
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: MR_P_BODY] #1729685
01/14/15 04:26 PM
01/14/15 04:26 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
EDIT
Space is my big issue, I need to put up a new shop of my own. Mike once you get a dyno you'll wonder why you didn't 40 years ago. You'll also lay awake at nite dreaming up crazy stuff to try on it.Dave
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: RMCHRGR] #1729686
01/14/15 04:27 PM
01/14/15 04:27 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Some people write the check, drive away in the car and are satisfied.
For others, having the knowledge and ability to envision, design, fabricate, and put all the pieces needed together is the object of the exercise.
Nothing brightens up a shop like a new piece of equipment.
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: CMcAllister] #1729687
01/14/15 04:48 PM
01/14/15 04:48 PM
BradH Offline OP
BradH  Offline OP
Too bad the pic below doesn't show the associated laptop w/ the digital readouts...
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: BradH] #1729688
01/14/15 04:54 PM
01/14/15 04:54 PM
BradH Offline OP
BradH  Offline OP
... like this:
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: BradH] #1729689
01/14/15 05:07 PM
01/14/15 05:07 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I know you said 'professional level' but have you looked into building one yourself?
I don't know what you have now, is it something like this?
http://performancetrends.com/ez_flow_system.htm
'71 Duster
'72 Challenger
'17 Ram 1500
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: BradH] #1729690
01/14/15 05:08 PM
01/14/15 05:08 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
I wanted my own flow bench 15 years ago, and as I work with industrial ventilation, I made my own bench.
Started with a single inlet fan and a 11w motor, then with a belt drive made the fan spinn 5100rpm. Sounded like a smal jet motor.
But I had to move out from that garage in 2002, and both the fan and the bench have been in a storage since.
Designed to flow any intake port at 28".
I had a 3m straight pipe with an orifice in the middle to get a good laminar flow between the fan and the bench.
Not very sophisticated and very basic.
Found a pict. of the bench behind the Coronet.
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: RMCHRGR] #1729691
01/14/15 05:23 PM
01/14/15 05:23 PM
BradH Offline OP
BradH  Offline OP
A PTS flowbench is actually a build-it-yourself bench (see flowbenchtech.com for more info).
What I have now is a SuperFlow SF-110:
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: BradH] #1729692
01/14/15 07:36 PM
01/14/15 07:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Every tool i have now is the result of not having to beg, borrow or steal from someone else. Its was always "I'll get to it next week maybe" or X number of dollars and would they do it right. Don't skimp on quality tools, human error is enough the tool doesn't need to add too, they are an investment. After almost 50 years of owning a cabinet shop you can never have enough tools.I have 4200 ft for my work and 3300 for the cars and can hardly move around in either, you can NEVER have too big a building.
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: cudaman1969] #1729693
01/14/15 08:56 PM
01/14/15 08:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I weigh the amount of use I'll get out of something and budget accordingly. Buying "used" can save you a bundle. I see a lot of guys with huge loaded tool chests and they don't do any more with their stuff than I do with much less. Maybe they can get at a nut or bolt a little easier but the end result is the same. Big expenditures need a return on the investment - my welders and metal working equipment make me money so they're easily justified. Sometimes I just treat myself. A hoist would be a "treat"!
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: MR_P_BODY] #1729694
01/14/15 09:50 PM
01/14/15 09:50 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
EDIT
I bought my dyno after realizing that no one around here had one or they would not dyno Mopars. I bought a top of the line Superflow. I will never be able to make the money back that i have in it, one reason, like Dave said i keep adding "stuff" to get more information. it adds up quick, Blowby sensor 2k, 8 O2 sensors 3k, getting BSFC number for mechanical fuel injection (worth it's weight in gold)$1500. here's a cheap deal to check on different ign boxes magnetic hysteresis.
My next purchase will be a in cylinder pressure tester in order to know when peak cylinder pressure occurs.
Joe
Without Data, you’re just another guy with an opinion.
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: Stanton] #1729695
01/14/15 10:12 PM
01/14/15 10:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a hoist now but I'm looking at a new one..
the new one goes up 8" higher.. that way I can walk
or drive under it... I bang my head on this one
Re: "Hobbyists" w/ pro-level tools, equipment, etc.? [Re: BradH] #1729696
01/14/15 10:40 PM
01/14/15 10:40 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I went digital for a number of reasons
I can flow a port in a matter of minutes. It instantly is saved in a file and can be set up in graphs or comparison reports to show gains and losses
Not only that, but I have seen guys make mistakes on manual benches when using the weather correction and conversion charts
Keith
