"Hobbyists" w/ pro-level tools, equipment, etc.?
#1729677
01/14/15 02:24 PM
01/14/15 02:24 PM
BradH
I'm looking seriously into a flowbench upgrade, like something that can pull 450+ cfm @ a real 28" H2O test pressure, instead of relying on major correction factors like I have to use w/ my current bench. So, that got me wondering about other people are into this type of car stuff as a hobby who also have set themselves up w/ what would otherswise be considered "overkill" professional-level equipment, tools, etc. Anybody else want to jump in to help me rationalize this more easily?
Re: "Hobbyists" w/ pro-level tools, equipment, etc.?
[Re: BradH]
#1729678
01/14/15 02:41 PM
01/14/15 02:41 PM
Posts: 7,506 Az
Crizila
Az
I have no problem rationalizing it - selling the wife is another story. She walks around the garage now and sez, "when's the last time you used that?" Using a correction factor can still be pretty accurate.
Fastest 300
[Re: Crizila]
#1729679
01/14/15 02:48 PM
01/14/15 02:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
the only pro level anything to be used as a hobbiest I would even consider is the size of the garage. My garage is 2000sq ft and its not enough.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: cudadoug]
#1729681
01/14/15 03:57 PM
01/14/15 03:57 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I've got my Land&Sea dyno, it was easy, 'I wanted it, I needed it, and I deserved it!' If you want something bad enough you'll always find a way to get it and justify it.Dave
[Re: cudadoug]
#1729682
01/14/15 03:57 PM
01/14/15 03:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just have a few machines that are above the normal.. a mill and a lathe... hand tools.. and the bore gauge and 0-6" mic set.. and of course my welders and I have a 4' sand blaster, sheet metal break and roller, bead roller... I've sold off all my chassis bending tools like the hyd bender and I sold my old flow bench.. thats about all the big stuff.... and there is always the space issue.... LACK OF IT EDIT I've had this BIG desire to buy a engine dyno the last couple of years... that might be next if I can figure out the space
[Re: cudadoug]
#1729683
01/14/15 04:10 PM
01/14/15 04:10 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Can you rationalize anything in this hobby? Tools are probably one of the only things you can rationalize since they are in fact needed to perform certain tasks. If you don't have what you need, you're paying someone else to do whatever it is you need done. How often do you need heads flowed? Can you justify the initial investment over paying someone else to do it however many times? You could eventually make some money back and do it as a service for others if you were inclined. When I was a tech, I had to rationalize most everything I bought from the tool trucks. This was especially true if I only used something a handful of times or just wanted the latest and greatest mousetrap. But, if I could open my tool box and get what I needed without having to borrow it, that was reason enough, .
'71 Duster '72 Challenger '17 Ram 1500
[Re: MR_P_BODY]
#1729685
01/14/15 04:26 PM
01/14/15 04:26 PM
quickd100
nielsville, minn.
Space is my big issue, I need to put up a new shop of my own. Mike once you get a dyno you'll wonder why you didn't 40 years ago. You'll also lay awake at nite dreaming up crazy stuff to try on it.Dave
[Re: RMCHRGR]
#1729686
01/14/15 04:27 PM
01/14/15 04:27 PM
Posts: 11,682 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Some people write the check, drive away in the car and are satisfied.
For others, having the knowledge and ability to envision, design, fabricate, and put all the pieces needed together is the object of the exercise.
Nothing brightens up a shop like a new piece of equipment.
[Re: CMcAllister]
#1729687
01/14/15 04:48 PM
01/14/15 04:48 PM
BradH
Too bad the pic below doesn't show the associated laptop w/ the digital readouts...
[Re: RMCHRGR]
#1729691
01/14/15 05:23 PM
01/14/15 05:23 PM
BradH
I know you said 'professional level' but have you looked into building one yourself?
I don't know what you have now, is it something like this?
http://performancetrends.com/ez_flow_system.htm
A PTS flowbench is actually a build-it-yourself bench (see flowbenchtech.com for more info).
What I have now is a SuperFlow SF-110:
[Re: BradH]
#1729692
01/14/15 07:36 PM
01/14/15 07:36 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Every tool i have now is the result of not having to beg, borrow or steal from someone else. Its was always "I'll get to it next week maybe" or X number of dollars and would they do it right. Don't skimp on quality tools, human error is enough the tool doesn't need to add too, they are an investment. After almost 50 years of owning a cabinet shop you can never have enough tools.I have 4200 ft for my work and 3300 for the cars and can hardly move around in either, you can NEVER have too big a building.
[Re: MR_P_BODY]
#1729694
01/14/15 09:50 PM
01/14/15 09:50 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I bought my dyno after realizing that no one around here had one or they would not dyno Mopars. I bought a top of the line Superflow. I will never be able to make the money back that i have in it, one reason, like Dave said i keep adding "stuff" to get more information. it adds up quick, Blowby sensor 2k, 8 O2 sensors 3k, getting BSFC number for mechanical fuel injection (worth it's weight in gold)$1500. here's a cheap deal to check on different ign boxes magnetic hysteresis.
My next purchase will be a in cylinder pressure tester in order to know when peak cylinder pressure occurs.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Stanton]
#1729695
01/14/15 10:12 PM
01/14/15 10:12 PM
MR_P_BODY
I weigh the amount of use I'll get out of something and budget accordingly. Buying "used" can save you a bundle. I see a lot of guys with huge loaded tool chests and they don't do any more with their stuff than I do with much less. Maybe they can get at a nut or bolt a little easier but the end result is the same. Big expenditures need a return on the investment - my welders and metal working equipment make me money so they're easily justified. Sometimes I just treat myself. A hoist would be a "treat"!
I have a hoist now but I'm looking at a new one.. the new one goes up 8" higher.. that way I can walk or drive under it... I bang my head on this one
