spark plug options for Gen3
#1728493
01/12/15 10:48 PM
01/12/15 10:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What are they?
Im running ngk LZTR5A
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: spark plug options for Gen3
[Re: 440Jim]
#1728495
01/13/15 12:38 AM
01/13/15 12:38 AM
sixpackgut
Charleston
426 with 5.7 heads. Will the msd hemi 6 be ok with iridium plugs?
[Re: 440Jim]
#1728496
01/13/15 12:55 AM
01/13/15 12:55 AM
Posts: 154 Plano, TX
StricNine
Plano, TX
Those plugs shown above are stock heat range 09+ 5.7 (Eagle). The Eagle heads use a gasket type plug, the 08 and older 5.7 don't use a gasket and have a bevel that seals the plug to the head.
A 1 step colder plug for an Eagle head (copper) is LFR6C-11 (NGK).
StricNine
79 Li'l Red Express, 15.04 @ 89.57 09 Challenger R/T, 11.95 @ 115.92
[Re: 72Swinger]
#1728499
01/13/15 01:15 AM
01/13/15 01:15 AM
sixpackgut
Charleston
So because I'm a super genius, I came up with this super idea. I'll just yank the plugs out of my Apache heads and they are the same style as 6.1 plugs so only the Eagles are different
[Re: sixpackgut]
#1728504
01/13/15 01:28 AM
01/13/15 01:28 AM
StricNine
Plano, TX
Just to be clear, the LFR5C-11 are stock 09+ 5.7 plugs and are the same heat range as the stock 6.1 plugs. They are not interchangeable as the 6.1 head uses a tapered seat plug and Eagle head uses a gasket type plug.
The LZTR5A are stock heat range 6.1 plugs, and 1 heat range colder 08 and older 5.7 plugs.
If a tapered seat plug is installed in an Eagle head it's probably best to keep using a tapered seat plug from that point forward. The tapered seat plug will deform the area around the "seat" of the plug in the head and will probably make sealing a gasket type plug problematic in the future.
StricNine
[Re: slammedR/T]
#1728505
01/13/15 01:29 AM
01/13/15 01:29 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
But then your Apache heat range would need tweaked anyway......
Mopar to the bone!!!
[Re: sixpackgut]
#1728507
01/13/15 01:40 AM
01/13/15 01:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Hey idiot, it may be cheaper to change the springs and run the Apache head than change spark plugs
You will have to port them first
Your talking to yourself
Duuuhh.... LOL
