spark plug options for Gen3 #1728493
01/12/15 10:48 PM
01/12/15 10:48 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
What are they?
Im running ngk LZTR5A
Re: spark plug options for Gen3 [Re: sixpackgut] #1728494
01/13/15 12:13 AM
01/13/15 12:13 AM
NC
440Jim Offline
440Jim  Offline
NC
Is this for a stock 5.7, 6.1, etc?
Re: spark plug options for Gen3 [Re: 440Jim] #1728495
01/13/15 12:38 AM
01/13/15 12:38 AM
Charleston
Charleston
426 with 5.7 heads. Will the msd hemi 6 be ok with iridium plugs?
Re: spark plug options for Gen3 [Re: 440Jim] #1728496
01/13/15 12:55 AM
01/13/15 12:55 AM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
Those plugs shown above are stock heat range 09+ 5.7 (Eagle). The Eagle heads use a gasket type plug, the 08 and older 5.7 don't use a gasket and have a bevel that seals the plug to the head.
A 1 step colder plug for an Eagle head (copper) is LFR6C-11 (NGK).
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: spark plug options for Gen3 [Re: StricNine] #1728497
01/13/15 01:02 AM
01/13/15 01:02 AM
Charleston
Charleston
That is what prompted the question, i have had 6.1 plugs in there for over a year. What is the stock number for that plug
Re: spark plug options for Gen3 [Re: sixpackgut] #1728498
01/13/15 01:09 AM
01/13/15 01:09 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar to the bone!!!
Re: spark plug options for Gen3 [Re: 72Swinger] #1728499
01/13/15 01:15 AM
01/13/15 01:15 AM
Charleston
Charleston
So because I'm a super genius, I came up with this super idea. I'll just yank the plugs out of my Apache heads and they are the same style as 6.1 plugs so only the Eagles are different
Re: spark plug options for Gen3 [Re: sixpackgut] #1728500
01/13/15 01:18 AM
01/13/15 01:18 AM
Charleston
Charleston
Hey idiot, it may be cheaper to change the springs and run the Apache head than change spark plugs
Re: spark plug options for Gen3 [Re: sixpackgut] #1728501
01/13/15 01:19 AM
01/13/15 01:19 AM
Charleston
Charleston
You will have to port them first
Re: spark plug options for Gen3 [Re: sixpackgut] #1728502
01/13/15 01:22 AM
01/13/15 01:22 AM
Charleston
Charleston
Your talking to yourself
Re: spark plug options for Gen3 [Re: sixpackgut] #1728503
01/13/15 01:27 AM
01/13/15 01:27 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: spark plug options for Gen3 [Re: sixpackgut] #1728504
01/13/15 01:28 AM
01/13/15 01:28 AM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
Just to be clear, the LFR5C-11 are stock 09+ 5.7 plugs and are the same heat range as the stock 6.1 plugs. They are not interchangeable as the 6.1 head uses a tapered seat plug and Eagle head uses a gasket type plug.
The LZTR5A are stock heat range 6.1 plugs, and 1 heat range colder 08 and older 5.7 plugs.
If a tapered seat plug is installed in an Eagle head it's probably best to keep using a tapered seat plug from that point forward. The tapered seat plug will deform the area around the "seat" of the plug in the head and will probably make sealing a gasket type plug problematic in the future.
StricNine
Re: spark plug options for Gen3 [Re: slammedR/T] #1728505
01/13/15 01:29 AM
01/13/15 01:29 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
But then your Apache heat range would need tweaked anyway......
Re: spark plug options for Gen3 [Re: 72Swinger] #1728506
01/13/15 01:33 AM
01/13/15 01:33 AM
Charleston
Charleston
Comp will go down with the Apache head, 9.80s on 87 octane
Re: spark plug options for Gen3 [Re: sixpackgut] #1728507
01/13/15 01:40 AM
01/13/15 01:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Duuuhh.... LOL
Re: spark plug options for Gen3 [Re: sixpackgut] #1728508
01/13/15 02:26 AM
01/13/15 02:26 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Now your talking all crazy....
