SuperCar AAR Cuda build. Mufflers ??? #1716941
12/28/14 03:17 PM
12/28/14 03:17 PM
Bristol, CT
RalphsRapidTrnst Offline OP
Bristol, CT
I am in the process of putting together an AAR Cuda build for SuperCars. Any recomendations on mufflers would be appreciated
Link- http://www.supercarraces.com/phpBB3/viewtopic.php?f=5&t=1434&start=0
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716942
12/28/14 06:05 PM
12/28/14 06:05 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Dynomax 17676
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: scatpacktom] #1716943
12/28/14 06:49 PM
12/28/14 06:49 PM
Bristol, CT
Bristol, CT
Thanks Tom. Do you have any flo numbers on the Dynomax? I found these but have no idea on how good they flo.
http://www.summitracing.com/parts/mpe-14210
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716944
12/28/14 07:08 PM
12/28/14 07:08 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Hooker Aerochambers. Best sounding mufflers I have had.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716945
12/28/14 08:51 PM
12/28/14 08:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That Cuda is gorgeous!
If that is a stock sounding class you may have to find something that's fairly quiet and still flows well.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716946
12/28/14 09:35 PM
12/28/14 09:35 PM
Locomotion Offline
Locomotion  Offline
They are a little on the loud side, especially when you get on it. But as far as performance, Dynomax UltraFlo's work great. I put them on my race car with a 3" TTI X-pipe and and the car actually picked up a little - at least .05, over open TTI 1 5/8" - 1 3/4" headers. Only down side was that I had to find 60+ lbs to take out of the car to compensate for the exhaust system weight to get the car back to minimum race weight.
Beautiful collection and garage!
After a quick search, I see that UltraFlos don't have a same side inlet/outlet configuration, if that's a class requirement.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: Locomotion] #1716947
12/28/14 09:39 PM
12/28/14 09:39 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
most of the F.A.S.T class race guys run the dynomax ultra flows with pypes brand tubing. I like the sound of the hooker maximum flows personally
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: upnover] #1716948
12/28/14 09:59 PM
12/28/14 09:59 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
These are a straight through design, basicly shaped like a U inside. The nice thing is these mufflers fit into a reproduction hanger. They are 4 inches shorter than the stock trans am muffler so you do have to make a little extension to the tip.
These mufflers won't hinder performance in this application I assure you.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: scatpacktom] #1716949
12/28/14 11:21 PM
12/28/14 11:21 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Tom did you make the tail pipe an did you used 2.5 pipe. or dose any one make 2.5 aar exaust pipes.or are you useing 2.25 pipes
thanks
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: 1969gtx] #1716950
12/28/14 11:35 PM
12/28/14 11:35 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
weldtechstainless
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: scatpacktom] #1716951
12/29/14 11:44 AM
12/29/14 11:44 AM
Bristol, CT
Bristol, CT
Thanks. Dynomax it is .
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: scatpacktom] #1716952
12/29/14 01:36 PM
12/29/14 01:36 PM
Bristol, CT
Bristol, CT
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716953
12/29/14 08:34 PM
12/29/14 08:34 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Thank you for this post and all the replies as I am also building a stock looking AAR with stroker and I was looking for the muffler that works.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: joes68340s] #1716954
12/30/14 02:41 PM
12/30/14 02:41 PM
Bristol, CT
Bristol, CT
The complete build will be featured on SuperCars- http://www.supercarraces.com/phpBB3/viewforum.php?f=5
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716955
12/30/14 05:49 PM
12/30/14 05:49 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Is Super Car racing a different version of FAST racing or a competitor. I always get worked up about this as there is nothing like it out here on the West coast, which surprises me as there are so many cars and people with money out here.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: joes68340s] #1716956
12/30/14 09:51 PM
12/30/14 09:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wish they made those mufflers in a 3".
Mopar to the bone!!!
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: joes68340s] #1716957
12/31/14 12:48 AM
12/31/14 12:48 AM
Bristol, CT
Bristol, CT
SuperCars is similar to the original intent of F.A.S.T. A good amount of the current F.A.S.T. cars are close if not ready to go SuperCar Racing.
To be exact, SuperCars is grounded to the original intent of F.A.S.T. racing. 100% stock appearing thru out the cars, interior, undercariage, trunk and engine bay. Cars in SuperCars run from 10.50's to 15's. We tech the cars very heavily once they reach 11.99.
Dave Dudek, Tom Cannon, Ken Viet, Scott McKenzie and many others have run both classes thru out the years.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: scatpacktom] #1716958
01/28/15 05:58 PM
01/28/15 05:58 PM
Bristol, CT
Bristol, CT
weldtechstainless
I went to order a complete system today and they are out of the exhaust system business.
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: RalphsRapidTrnst] #1716959
01/28/15 11:11 PM
01/28/15 11:11 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
That Sucks... The tips were artwork
Re: SuperCar AAR Cuda build. Mufflers ??? [Re: scatpacktom] #1716960
01/28/15 11:31 PM
01/28/15 11:31 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Ralphsrapid in the photo you posted of the full exhaust what brand was that. Whos mufflers were those they didn't look like a standard Dynamax they almost look like an Ultraflow from the rear.
