SBM bottom feed oil pump pick up tube #1715661
12/26/14 04:09 AM
12/26/14 04:09 AM
jacksonville,FLORIDA
slammedR/T Offline OP
Trying to find that oil pump pick up tube that replaced the oil pump cover and fed it directly with out the 3/8" npt neck down.
Look like this;
It was mention in the book "how to build big-inch mopar small blocks" on page 40.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: SBM bottom feed oil pump pick up tube [Re: slammedR/T] #1715662
12/26/14 05:36 AM
12/26/14 05:36 AM
Australia
MisterBee Offline
MisterBee  Offline
Australia
I asked the same question a while ago.
Short answer is Milodon and Kevco. I haven't had any success in getting a response from either. Although I haven't tried that hard with Kevco. Milodon are no longer making them.
Moparts Link
Re: SBM bottom feed oil pump pick up tube [Re: MisterBee] #1715663
12/26/14 09:37 AM
12/26/14 09:37 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Charlie's oil pans made mine for me that I use with a Moroso Elimintor rear sump pan.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: SBM bottom feed oil pump pick up tube [Re: slammedR/T] #1715664
12/26/14 10:50 AM
12/26/14 10:50 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
My PIE oil pan came with one, has a 5/8" tube on it.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: SBM bottom feed oil pump pick up tube [Re: Adobedude] #1715665
12/26/14 02:09 PM
12/26/14 02:09 PM
Guitar Jones Offline
I bought one from Canton and modified it to fit my pan, 5/8 tube.
Re: SBM bottom feed oil pump pick up tube [Re: MisterBee] #1715666
12/26/14 06:24 PM
12/26/14 06:24 PM
Moparts Link
I called Kevko and they must be closed, I'll try again monday, thanks for the info.
racemagnum
Re: SBM bottom feed oil pump pick up tube [Re: 440W8 Duster] #1715667
12/26/14 06:25 PM
12/26/14 06:25 PM
I called them and they must also be closed, thanks for the info.
racemagnum
Re: SBM bottom feed oil pump pick up tube [Re: Guitar Jones] #1715668
12/26/14 06:26 PM
12/26/14 06:26 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Actually, I replied to a previous post and showed my billet pick-up. I guess everyone thought it was too much money. Here is my cast version, being machined as we speak.
Re: SBM bottom feed oil pump pick up tube [Re: Guitar Jones] #1715669
12/26/14 06:26 PM
12/26/14 06:26 PM
got a part number? canton's website doesn't show any pictures of the pick up tube. I never understand why a company would have a website but not show a picture of the part, TOTALLY STUPID!
racemagnum
Re: SBM bottom feed oil pump pick up tube [Re: slammedR/T] #1715670
12/26/14 06:31 PM
12/26/14 06:31 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Billet version.
Re: SBM bottom feed oil pump pick up tube [Re: TrWaters] #1715671
12/26/14 06:51 PM
12/26/14 06:51 PM
Billet version.
what kind of oil pump is that for??? we are looking for 318/340/360 LA and Magnum oil pump pickup tubes. Specifically the melling M72 or Mopar version.
Your pictured part doesn't seem to work with the LA and Magnum oil pumps?
racemagnum
Re: SBM bottom feed oil pump pick up tube [Re: slammedR/T] #1715672
12/26/14 07:45 PM
12/26/14 07:45 PM
Australia
MisterBee Offline
MisterBee  Offline
Australia
I must admit that I saw the billet pickup and whilst it looks good, I couldn't work out what it was for - looks like it bolts directly to the oil pump?
I must be a bit thick...dont get it!!!
Re: SBM bottom feed oil pump pick up tube [Re: slammedR/T] #1715673
12/26/14 07:48 PM
12/26/14 07:48 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: SBM bottom feed oil pump pick up tube [Re: RobX4406] #1715674
12/26/14 08:07 PM
12/26/14 08:07 PM
No part number for that pictured pick up.
racemagnum
Re: SBM bottom feed oil pump pick up tube [Re: slammedR/T] #1715675
12/26/14 10:57 PM
12/26/14 10:57 PM
Australia
MisterBee Offline
MisterBee  Offline
Australia
Their website kind of implies that they come with a pick up.
Each type of sump has its own pick up part# so I had assumed it came as a package deal.
Re: SBM bottom feed oil pump pick up tube [Re: MisterBee] #1715676
12/26/14 11:25 PM
12/26/14 11:25 PM
I'm liking the Kevko oil pans, I might just buy an oil pan and pick up tube LOL!
racemagnum
