SBM bottom feed oil pump pick up tube
#1715661
12/26/14 04:09 AM
12/26/14 04:09 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Trying to find that oil pump pick up tube that replaced the oil pump cover and fed it directly with out the 3/8" npt neck down. Look like this; It was mention in the book "how to build big-inch mopar small blocks" on page 40.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: SBM bottom feed oil pump pick up tube
[Re: slammedR/T]
#1715662
12/26/14 05:36 AM
12/26/14 05:36 AM
Posts: 89 Australia
MisterBee
Australia
I asked the same question a while ago. Short answer is Milodon and Kevco. I haven't had any success in getting a response from either. Although I haven't tried that hard with Kevco. Milodon are no longer making them. Moparts Link
[Re: MisterBee]
#1715663
12/26/14 09:37 AM
12/26/14 09:37 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Charlie's oil pans made mine for me that I use with a Moroso Elimintor rear sump pan.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: slammedR/T]
#1715664
12/26/14 10:50 AM
12/26/14 10:50 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
My PIE oil pan came with one, has a 5/8" tube on it.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1715665
12/26/14 02:09 PM
12/26/14 02:09 PM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
I bought one from Canton and modified it to fit my pan, 5/8 tube.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: MisterBee]
#1715666
12/26/14 06:24 PM
12/26/14 06:24 PM
slammedR/T
Moparts Link
I called Kevko and they must be closed, I'll try again monday, thanks for the info.
[Re: 440W8 Duster]
#1715667
12/26/14 06:25 PM
12/26/14 06:25 PM
slammedR/T
I called them and they must also be closed, thanks for the info.
[Re: Guitar Jones]
#1715669
12/26/14 06:26 PM
12/26/14 06:26 PM
slammedR/T
got a part number? canton's website doesn't show any pictures of the pick up tube. I never understand why a company would have a website but not show a picture of the part, TOTALLY STUPID!
[Re: TrWaters]
#1715671
12/26/14 06:51 PM
12/26/14 06:51 PM
slammedR/T
Billet version.
what kind of oil pump is that for??? we are looking for 318/340/360 LA and Magnum oil pump pickup tubes. Specifically the melling M72 or Mopar version.
Your pictured part doesn't seem to work with the LA and Magnum oil pumps?
[Re: RobX4406]
#1715674
12/26/14 08:07 PM
12/26/14 08:07 PM
slammedR/T
No part number for that pictured pick up.
[Re: MisterBee]
#1715676
12/26/14 11:25 PM
12/26/14 11:25 PM
slammedR/T
Their website kind of implies that they come with a pick up.
Each type of sump has its own pick up part# so I had assumed it came as a package deal.
I'm liking the Kevko oil pans, I might just buy an oil pan and pick up tube LOL!
