SBM bottom feed oil pump pick up tube
#1715661
12/26/14 04:09 AM
12/26/14 04:09 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Trying to find that oil pump pick up tube that replaced the oil pump cover and fed it directly with out the 3/8" npt neck down. Look like this; It was mention in the book "how to build big-inch mopar small blocks" on page 40.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: SBM bottom feed oil pump pick up tube
[Re: slammedR/T]
#1715662
12/26/14 05:36 AM
12/26/14 05:36 AM
Posts: 89 Australia
MisterBee
Australia
I asked the same question a while ago. Short answer is Milodon and Kevco. I haven't had any success in getting a response from either. Although I haven't tried that hard with Kevco. Milodon are no longer making them. Moparts Link
[Re: MisterBee]
#1715663
12/26/14 09:37 AM
12/26/14 09:37 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Charlie's oil pans made mine for me that I use with a Moroso Elimintor rear sump pan.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: slammedR/T]
#1715664
12/26/14 10:50 AM
12/26/14 10:50 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
My PIE oil pan came with one, has a 5/8" tube on it.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1715665
12/26/14 02:09 PM
12/26/14 02:09 PM
Guitar Jones
I bought one from Canton and modified it to fit my pan, 5/8 tube.
[Re: MisterBee]
#1715666
12/26/14 06:24 PM
12/26/14 06:24 PM
slammedR/T
Moparts Link
I called Kevko and they must be closed, I'll try again monday, thanks for the info.
[Re: 440W8 Duster]
#1715667
12/26/14 06:25 PM
12/26/14 06:25 PM
slammedR/T
I called them and they must also be closed, thanks for the info.
[Re: Guitar Jones]
#1715669
12/26/14 06:26 PM
12/26/14 06:26 PM
slammedR/T
got a part number? canton's website doesn't show any pictures of the pick up tube. I never understand why a company would have a website but not show a picture of the part, TOTALLY STUPID!
[Re: TrWaters]
#1715671
12/26/14 06:51 PM
12/26/14 06:51 PM
slammedR/T
Billet version.
what kind of oil pump is that for??? we are looking for 318/340/360 LA and Magnum oil pump pickup tubes. Specifically the melling M72 or Mopar version.
Your pictured part doesn't seem to work with the LA and Magnum oil pumps?
[Re: RobX4406]
#1715674
12/26/14 08:07 PM
12/26/14 08:07 PM
slammedR/T
No part number for that pictured pick up.
[Re: MisterBee]
#1715676
12/26/14 11:25 PM
12/26/14 11:25 PM
slammedR/T
Their website kind of implies that they come with a pick up.
Each type of sump has its own pick up part# so I had assumed it came as a package deal.
I'm liking the Kevko oil pans, I might just buy an oil pan and pick up tube LOL!
