1970 RR Auto with a 4Spd pedal bracket ???? #1714624
12/23/14 01:54 PM
12/23/14 01:54 PM
Bristol, CT
RalphsRapidTrnst Offline OP
Bristol, CT
I am in the process of restoring a 1970 RR FM3. I noticed it has a 4Spd pedal bracket in the fire wall. It has always been my understanding this bracket was only applied to 4Spd cars. Wondering if anyone else has run accross this on an Auto car.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714625
12/23/14 01:55 PM
12/23/14 01:55 PM
Bristol, CT
Bristol, CT
pic 2
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714626
12/23/14 01:56 PM
12/23/14 01:56 PM
Bristol, CT
Bristol, CT
Original floor pedal and column pic1
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714627
12/23/14 01:56 PM
12/23/14 01:56 PM
Bristol, CT
Bristol, CT
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714628
12/23/14 01:57 PM
12/23/14 01:57 PM
Bristol, CT
Bristol, CT
pic5
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714629
12/23/14 01:58 PM
12/23/14 01:58 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
They all have the firewall reinforcement plate behind the master cylinder. Auto and 4sp alike.
...FAFO...
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714630
12/23/14 02:02 PM
12/23/14 02:02 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
Did someone's body do that to the steering wheel?
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: skicker] #1714631
12/23/14 02:03 PM
12/23/14 02:03 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
70 Auto firewall...
...FAFO...
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: skicker] #1714632
12/23/14 02:07 PM
12/23/14 02:07 PM
Bristol, CT
Bristol, CT
The bracket to the right of the master that supports the 4spd pedal is the question.
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: BMChrysler68] #1714633
12/23/14 02:15 PM
12/23/14 02:15 PM
Bristol, CT
Bristol, CT
It had to of been damaged when the car spent time in Texas Acres. There is no frame damage that supports a crash that would cause the wheel to collapse like that.
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714634
12/23/14 02:37 PM
12/23/14 02:37 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I attached the pic below just so everyone understands which piece you are asking about.
Is there a fender tag to confirm codes?
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: moparfan53] #1714635
12/23/14 02:46 PM
12/23/14 02:46 PM
Central Ohio
Central Ohio
Rust is a weird thing. The heavy gauge stuff looks ultra-crusty with deep pits and corrosion; but the sheetmetal looks to be in decent shape. It's almost like it chose to go after the meatier stuff first. Science.
360-4v, automatic
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714636
12/23/14 02:46 PM
12/23/14 02:46 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I think that some got it regardless of transmission. I've converted several auto trans. cars to 4 spds. and only had to hang the clutch pedal and swap the brake pedal.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: I_bleed_MOPAR] #1714637
12/23/14 02:49 PM
12/23/14 02:49 PM
Central Ohio
Central Ohio
Maybe they realized later in production that they could accomplish the same thing with one part #. Or, because the manual trans was standard in the B-body, they had more of them laying around.
This is all assuming that the manual trans assembly is all one piece with two extra bolts in the firewall, of course. I'm not familiar with the B-body assemblies.
360-4v, automatic
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: BMChrysler68] #1714638
12/23/14 02:52 PM
12/23/14 02:52 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I haven't seen them on auto cars for 68 and 69. I would think that the factory wouldn't use the part unless needed. If they could save a few cents by not having that bracket there, they would. Most likely a mistake. Its hard to tell, but is the a bracket welded to the top of the frame rail down under the master cylinder?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RoadRunner] #1714639
12/23/14 03:01 PM
12/23/14 03:01 PM
Up a holler, down a crick
booger Offline
booger  Offline
I had a 70 gTx converted auto to 4-speed and it had the reinforcement. Based on the rest of the work involved in the conversion, I'd bet good money the bracket was there before it was changed to a manual trans.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RoadRunner] #1714640
12/23/14 03:15 PM
12/23/14 03:15 PM
Bristol, CT
Bristol, CT
Clean with no signs of ever having the z-bar pivot bracket installed. All of the original auto linkage is still there.
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: moparfan53] #1714641
12/23/14 03:49 PM
12/23/14 03:49 PM
Bristol, CT
Bristol, CT
When I saw the bracket it excited me to think this was a manual trans RR. When I looked for more evidence and found none, because all of the auto peices are in place with no chance of this being a manual shift RR other than the bracket. I now questioned my beliefs regarding other B-Bodies that I have seen with the bracket.
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: RalphsRapidTrnst] #1714642
12/24/14 11:50 AM
12/24/14 11:50 AM
okla.
O
okie Offline
okie  Offline
O
okla.
I will look at mine later but I'm thinking it doesn't have that bracket on it
Re: 1970 RR Auto with a 4Spd pedal bracket ???? [Re: okie] #1714643
12/24/14 12:38 PM
12/24/14 12:38 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I think it was just an assembly line goof up.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
