Dyno vs. Dragstrip Tuning #1710733
12/14/14 10:04 PM
12/14/14 10:04 PM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Hi! Hypothetically speaking , If you receive an engine from the builder and have all the numbers after the dyno testing and tuning. All set up for max torque and HP. At aprox. the same altitude and weather conditions. What further tuning would be needed as far as timing , jetting , etc. would be needed at the track? I`d appreciate your input.
Thanks !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Dyno vs. Dragstrip Tuning [Re: chryco] #1710734
12/14/14 10:10 PM
12/14/14 10:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I did dyno my stuff it was just to check for leaks, get a base tune then tweek it so I can put it in the car then hit the track which is where the REAL tuning starts.
Re: Dyno vs. Dragstrip Tuning [Re: chryco] #1710735
12/14/14 10:22 PM
12/14/14 10:22 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Depending on who and where it is dyno tuned by it can be spot on or way off.
Some shops have dyno setups that don't have an adjustable acceleration rate and that doesn't help as much. I adjust the acceleration rate on mine to match the expectations of the car it is going in
My customers are normally as good on the tune up as they can get. Typically they find 0 gains by changing things
Keith
Re: Dyno vs. Dragstrip Tuning [Re: Dunnuck Racing] #1710736
12/14/14 10:26 PM
12/14/14 10:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sounds interesting.............
Re: Dyno vs. Dragstrip Tuning [Re: Dunnuck Racing] #1710737
12/14/14 10:48 PM
12/14/14 10:48 PM
SoCal
Brian Hafliger Offline
SoCal
Keith
I have found the same thing.
Brian Hafliger
Re: Dyno vs. Dragstrip Tuning [Re: Brian Hafliger] #1710738
12/14/14 11:26 PM
12/14/14 11:26 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
X2
Re: Dyno vs. Dragstrip Tuning [Re: Brian Hafliger] #1710739
12/14/14 11:28 PM
12/14/14 11:28 PM
Northern Indiana
Northern Indiana
Some dynos on the market let the engine accelerate at whatever speed it wants to and the computer converts the information into an estimated value of what the engine should put out at a certain acceleration rate.
Those aren't very accurate and from the couple of engine builds I helped guys tune at the track that came from them, they liked a couple of degrees more timing and a couple of jet sizes more fun we like at the track.
Keith
Re: Dyno vs. Dragstrip Tuning [Re: Dunnuck Racing] #1710740
12/15/14 12:22 AM
12/15/14 12:22 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Keith
That`s what I`ve seen............
Re: Dyno vs. Dragstrip Tuning [Re: chryco] #1710741
12/15/14 01:21 AM
12/15/14 01:21 AM
Cab_Burge Online work
Cab_Burge  Online Work
Make sure the tune up is safe and then take it to the track, look at the time slips and spark plugs and go from there Some of the dyno I have used have big pusher and puller fans feeding them(the dyno room) fresh air. If your dyno had postitve pressure in the dyno room during the testing your motor had some artificial boost Been there, done that I ended up opening the dyno room doors, turned off the pusher fans and left the exhaut fans on and redid the pulls to see how much differences I found. Test, test and test some more Another thing to keep in mind is not only the weather on the day of the dyno tuning but the altitude as well as the density altitude at the dyno and race tracks Sometimes more power spins the tires worst also
Re: Dyno vs. Dragstrip Tuning [Re: Dunnuck Racing] #1710742
12/15/14 01:55 AM
12/15/14 01:55 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Keith
X2
I also like them to bring their own ignition box with them, especially if it's a 7al3
Joe
Without Data, you’re just another guy with an opinion.
Re: Dyno vs. Dragstrip Tuning [Re: Cab_Burge] #1710743
12/15/14 01:44 PM
12/15/14 01:44 PM
Mo.
racerx Offline
racerx  Offline
Mo.
So Cab.......did you see any difference in HP #s?
Re: Dyno vs. Dragstrip Tuning [Re: racerx] #1710744
12/15/14 04:15 PM
12/15/14 04:15 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It all depends on the dyno, the operator, the environment, and ultimately the differences between those and the real-world environment of the chassis it's going in. Most street cars generally display a drop of some sort when comparing mph numbers vs a dyno slip. I've always attributed these to shops that use the tricks noted already, test at 160° water temp, run sprint car type dyno headers, no parasitic losses, etc. While a purpose built race car might not show much of a change the tune should not be identical when you go from the bell and airflow meter to an under-hood drop base aircleaner, and from large tube, equal length sprint chassis headers to a set set of smaller tube, unequal length, small collector chassis headers with a full exhaust.
Re: Dyno vs. Dragstrip Tuning [Re: racerx] #1710745
12/15/14 04:38 PM
12/15/14 04:38 PM
To be real truthful I don't remember exactly how much less it made, that was one of the first pump gas engines I built and dyno tested a long time ago(1991-93 or so). It was a pump gas 426 C.I. M.W. with stock cross ram and carbs. with a true 9.46 to 1 compression ratio. I got a best of 499.6 HP at 5600 RPM and a little more torque than HP IHTHs
Re: Dyno vs. Dragstrip Tuning [Re: moper] #1710746
12/15/14 04:58 PM
12/15/14 04:58 PM
Northern Indiana
Northern Indiana
That's why I try to run the same components as used in the car. I keep several sets of headers around and none are dyno or spent car type. The airflow meter on top of the carburetor gets used for some measurements as nd figures but it actually costs a few horsepower
Keith
Re: Dyno vs. Dragstrip Tuning [Re: Cab_Burge] #1710747
12/15/14 05:04 PM
12/15/14 05:04 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Newer dynos log the weather conditions during the run. I typically see .3 of a degree temperature rise during a pull. Also I run my fan with a .01 hg negative pressure in the test cell. The dyno will change the correction factor in response to changing conditions during the pull.
Joe
Re: Dyno vs. Dragstrip Tuning [Re: Dunnuck Racing] #1710748
12/15/14 05:07 PM
12/15/14 05:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I dynoed my 470 w/906`s and a solid Isky cam, we used my headers and even mounted the alt. but it wasn`t charging.......... It made 614.9 hp and 580+ tq...........
Re: Dyno vs. Dragstrip Tuning [Re: Thumperdart] #1710749
12/15/14 05:43 PM
12/15/14 05:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Sonny Leonard to me to jet richer two sizes from the dyno to the strip.
2011 Drag Pak Challenger
Re: Dyno vs. Dragstrip Tuning [Re: rickseeman] #1710750
12/15/14 06:18 PM
12/15/14 06:18 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
All good info.
I realize the OP is talking about an engine dyno....
But after tuning mine on a chassis dyno - I found I needed a bunch more fuel at the track due to additional load of moving actual weight, barn-door aerodynamics/wind and the turbo liking that load.
Re: Dyno vs. Dragstrip Tuning [Re: Duner] #1710751
12/15/14 08:23 PM
12/15/14 08:23 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I always try and use the headers that are going in the chassis and weld in the EGT bungs and O2 bung. After tuning for best timing, A/F ratio, spacers and whatnot I'll put the airflow meter on to see what the engine is actually using. Also try the aircleaner assembly they want to use, fan and alt. I've opened a few eyes by showing how bad or good some of their stuff is.
My 605 LOST 117hp bolting up my 3-1/2" dual exhaust with X-pipe and 3-1/2 Ultra-Flows over open headers and collectors. A friends resto 440 mag lost 22hp using a factory dual snorkel aircleaner assembly over an open style element.Dave
Re: Dyno vs. Dragstrip Tuning [Re: quickd100] #1710752
12/15/14 08:34 PM
12/15/14 08:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is nothing out there for exhaust on a engine
of that size unless you start looking at diesel exhaust
(a pair of them).. even with dyno testing I have
always had to tweak it in on the track for each day
if the weather is way different... the dyno tweaks
it in for that day
