Dyno vs. Dragstrip Tuning
#1710733
12/14/14 10:04 PM
12/14/14 10:04 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Hi! Hypothetically speaking , If you receive an engine from the builder and have all the numbers after the dyno testing and tuning. All set up for max torque and HP. At aprox. the same altitude and weather conditions. What further tuning would be needed as far as timing , jetting , etc. would be needed at the track? I`d appreciate your input. Thanks !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Dyno vs. Dragstrip Tuning
[Re: chryco]
#1710734
12/14/14 10:10 PM
12/14/14 10:10 PM
Thumperdart
State of confusion
When I did dyno my stuff it was just to check for leaks, get a base tune then tweek it so I can put it in the car then hit the track which is where the REAL tuning starts.
[Re: racerx]
#1710744
12/15/14 04:15 PM
12/15/14 04:15 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
It all depends on the dyno, the operator, the environment, and ultimately the differences between those and the real-world environment of the chassis it's going in. Most street cars generally display a drop of some sort when comparing mph numbers vs a dyno slip. I've always attributed these to shops that use the tricks noted already, test at 160° water temp, run sprint car type dyno headers, no parasitic losses, etc. While a purpose built race car might not show much of a change the tune should not be identical when you go from the bell and airflow meter to an under-hood drop base aircleaner, and from large tube, equal length sprint chassis headers to a set set of smaller tube, unequal length, small collector chassis headers with a full exhaust.
[Re: quickd100]
#1710752
12/15/14 08:34 PM
12/15/14 08:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I always try and use the headers that are going in the chassis and weld in the EGT bungs and O2 bung. After tuning for best timing, A/F ratio, spacers and whatnot I'll put the airflow meter on to see what the engine is actually using. Also try the aircleaner assembly they want to use, fan and alt. I've opened a few eyes by showing how bad or good some of their stuff is. My 605 LOST 117hp bolting up my 3-1/2" dual exhaust with X-pipe and 3-1/2 Ultra-Flows over open headers and collectors. A friends resto 440 mag lost 22hp using a factory dual snorkel aircleaner assembly over an open style element.Dave
There is nothing out there for exhaust on a engine of that size unless you start looking at diesel exhaust (a pair of them).. even with dyno testing I have always had to tweak it in on the track for each day if the weather is way different... the dyno tweaks it in for that day
