Re: carbs and the season. [Re: HotRodDave] #1708557
12/09/14 10:11 PM
12/09/14 10:11 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
I checked the timming and the dist.still no change that's actually the second thing I did after diassembling the carb and blowin out all the passages.this time ill take the air screws out and use brake cleaner not just air pressure.
Re: carbs and the season. [Re: bonefish] #1708558
12/09/14 10:14 PM
12/09/14 10:14 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Street driving,,over rich condition,,,= deposits on spark plugs that will stay hot/red hot/glow and ignite excessive fuel and cause 'run-on'. Maybe time for new/clean plugs.
If you like drag racing, support your local track.
Re: carbs and the season. [Re: bonefish] #1708559
12/09/14 11:24 PM
12/09/14 11:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I spotted the problem, the ole sv1/toilet bowl if thats what you call them.
Re: carbs and the season. [Re: Quicktree] #1708560
12/09/14 11:39 PM
12/09/14 11:39 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
cold air temps, cold manifold/carb = poor atomization. raw fuel. bring the engine up to temp, shut the engine off, throw a towel over the carb/intake and let it heat soak a little.
Re: carbs and the season. [Re: Quicktree] #1708561
12/09/14 11:42 PM
12/09/14 11:42 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
heres a question for the carb guys.if I spray brake cleaner into the iab its pluged,all 4.so I looked at the block and the gasket has no hole for that circuit.its open without the gasket.the circuit for the air screw is open and functions.
Re: carbs and the season. [Re: bonefish] #1708562
12/09/14 11:56 PM
12/09/14 11:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you tore the carb down before, did you put new
gaskets on it or did you just use them over... if you
used them over COULD you have them flipped over.. I
dont know anything about those SV-1s
Re: carbs and the season. [Re: MR_P_BODY] #1708563
12/10/14 12:01 AM
12/10/14 12:01 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its not a SV-1 its a 1050 dominater.the mertering block has dowels that are off set,the gasket can only go on one way.these are the same ones that have been on the carb all along.
Re: carbs and the season. [Re: bonefish] #1708564
12/10/14 12:10 AM
12/10/14 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt see the pic... I thought thats what Tony said
Re: carbs and the season. [Re: MR_P_BODY] #1708565
12/10/14 12:15 AM
12/10/14 12:15 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
I think Tony is up past his bed time.
Re: carbs and the season. [Re: MR_P_BODY] #1708566
12/10/14 12:16 AM
12/10/14 12:16 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
PICS.................
Re: carbs and the season. [Re: bonefish] #1708567
12/10/14 12:32 AM
12/10/14 12:32 AM
Mark Whitener Offline
I finally got my 1050 dom running perfect this summer,but now that winter is here and the air has changed it seems to be running pig rich(according to my afr guage).is that a coincidence or am I having carb or tune problems?this a street mostly car but does get to the strip at every chance.
If it's a 2 circuit the outer hole is not used, middle bleed is your idle bleed.
Re: carbs and the season. [Re: Mark Whitener] #1708568
12/10/14 04:40 PM
12/10/14 04:40 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Al.....Like Mark said......Inner/middle bleed is now your idle bleed....outside bleed is now another spare idle bleed we have in place.....If ya cant get it we will be happy to take a look at it and get it back where it belongs....Jesse
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: carbs and the season. [Re: CHAPPER] #1708569
12/10/14 05:08 PM
12/10/14 05:08 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It just happens I was looking at some old notes from the ex-Innovate forum and there had been a discussion about the opposite situation - lean run on. I'll share here in case anyone is interested. My own experience has been no run on with carbon fouled plugs. Just my experience, not saying it couldn't be.
Q. "Hi Shrinker. I find it interesting you note running a lean idle as a cause of deiseling. Can you elaborate please?"
A. "When its lean the flame speed is slow and not completed by EVO time. Once the valve opens the air volume that has to be exhausted at idle is very small and the pressure quickly drops to near zero so the reaction rate drops considerably. Once the reaction is slowed some molecules cease combustion part way through their cycle, that is they dont combust to completion but they remain in the cylinder trapped in the various places etc. They are then hot molecules and they are of a different chemistry. They are called free radicals. They are very detonation prone and they are hot from the previous burn so they detonate erratically, thats why the engines combust erratically when they Run on (or diesel) when you switch the ignition off. Their combustion on the next time around in the cylinder sets off the main charge.
Richen up the engine and set the timing to 18 for hot cams and running on goes away. BUT you have to enrich the engine correctly not just whack a big jet it, you have to have enough T-slot exposure to exhaust the volume of fuel with the air volume thats coming through the carby circuits as well, otherwise the fuel just blobs into the engine. Blobs makes some cylinders get the fuel and others miss out and then you also get lean spots in the chamber even though you have it set rich. Its about the homogenization not just the total volume of fuel."
"When large cams are used the time period of Overlap where both intake and exhaust valves are open is significant, shut down the blades at the carby and the engine draws air across the overlap phase into the inlet manifold, especially when its lean because then there is oxygen left over on the exhausting cylinder anyway. So now the engine draws in exhaust gases, hot oxygen, free radicals, and blobs of fuel from the carby. Great recipe that one. Richen it up [enough] so there is no oxygen and create a burn that blows down the cylinder rather than relying on piston pump and you stop the muck."
posted by Shrinker 11-01-2010, 08:00 PM Innovate Motorsports ex-forum
Re: carbs and the season. [Re: bonefish] #1708570
12/11/14 01:03 PM
12/11/14 01:03 PM
Az
Crizila Offline
Crizila  Offline
Az
well you should have the exact opposite problem now that the air is better. learn to give the motor what it wants and don't rely totally on your afr. if it still sounds and runs good don't worry about it. thats my opinion.
What Tony said... in the cool weather the carb tends
to lean out due to the temps... so for yours to
be going fat is strange or your getting a bogus AFR
reading... as said.. what does the engine tell you
and the plugs
I agree should be the opposite of what it is.its hard to get a reading on the plugs with in town driving.i guess ill just keep drivin it and see if the plugs foul out.it seems to run fine and I don't smell gas in the exaust.just seems weird that my cruise went from low 14,s to low twelves,assuming that this guage and sensor is working.plus it wants to run on a couple of licks every time I shut it off.
Did you check the grounds on your Inovate and recalibrate it?
Fastest 300
Re: carbs and the season. [Re: Crizila] #1708571
12/11/14 05:47 PM
12/11/14 05:47 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
ive been thru this carb several times,i don't think its a carb issue.im going to put some fresh plugs in it and go from there with some of the suggestions.i,ll let ya know what happens.
