carbs and the season.
#1708537
12/09/14 10:32 AM
12/09/14 10:32 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I finally got my 1050 dom running perfect this summer,but now that winter is here and the air has changed it seems to be running pig rich(according to my afr guage).is that a coincidence or am I having carb or tune problems?this a street mostly car but does get to the strip at every chance.
Re: carbs and the season.
[Re: Quicktree]
#1708540
12/09/14 02:32 PM
12/09/14 02:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
well you should have the exact opposite problem now that the air is better. learn to give the motor what it wants and don't rely totally on your afr. if it still sounds and runs good don't worry about it. thats my opinion.
What Tony said... in the cool weather the carb tends to lean out due to the temps... so for yours to be going fat is strange or your getting a bogus AFR reading... as said.. what does the engine tell you and the plugs ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1708541
12/09/14 03:49 PM
12/09/14 03:49 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I agree should be the opposite of what it is.its hard to get a reading on the plugs with in town driving.i guess ill just keep drivin it and see if the plugs foul out.it seems to run fine and I don't smell gas in the exaust.just seems weird that my cruise went from low 14,s to low twelves,assuming that this guage and sensor is working.plus it wants to run on a couple of licks every time I shut it off.
[Re: Airwoofer]
#1708543
12/09/14 04:04 PM
12/09/14 04:04 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Running on is hell on a motor. Maybe shut it down in gear to stop it as a bandaid.
it don't sound good that's for sure.its not like its diesiling it just cough,s thru the card a couple of licks like theres to much gas in the cylenders.
[Re: bonefish]
#1708544
12/09/14 04:11 PM
12/09/14 04:11 PM
MR_P_BODY
Run on is a sign of being fat on the idle.. assuming that the engine isnt still decelling.. but if your at idle for a few seconds then its fat ![](/ubbthreads/images/graemlins/wave.gif)
[Re: bonefish]
#1708546
12/09/14 04:15 PM
12/09/14 04:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Not saying this "is" the case but I have found when something changes for no apparent reason like your describing I tend to look for a partially blocked air bleed first. Then dig into the carb making sure the power valve (s) and or block off's are tight. Gaskets can and will cause the same issues your describing. Metering block gaskets can cross feed circuits and power valve gaskets can take a set causing torque loss adding unwanted fuel to the power enrichment circuit. If you need new gaskets just ask around here on the board who has the best ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Thumperdart]
#1708549
12/09/14 04:48 PM
12/09/14 04:48 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Post pics cos I`m sure we can help ya easier plus I`d like to see the body,idle hi speed bleeds and blocks(both sides)to see what`s up w/the tune also..........
ill see if I can take some pics for ya.Jesse built this carb for me.he converted my 8896 to a two circuit and all I had to do was adjust my idle a little bit and it was perfect.ive been runnin for 1,200 miles then suddenly something changed.
[Re: Thumperdart]
#1708555
12/09/14 07:55 PM
12/09/14 07:55 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
First thing I would try is pull the carb, blast the heck out of the air bleeds venturies... with a big can of carb cleaner, re-install and see if that helps. I have seen where "these bleeds" get a light coat of build up dried fuel additive and a slight restriction that richens it up.
