BILLETT STEEL 440 MAIN CAPS #1707935
12/07/14 09:00 PM
12/07/14 09:00 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline OP
does anybody know who makes a good set of 440 billet steel main caps and has anybody used the 440 source set
Re: BILLETT STEEL 440 MAIN CAPS [Re: BIGSTROKER] #1707936
12/07/14 09:05 PM
12/07/14 09:05 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I have used program one's.
Don't even know if the company is still around though
Re: BILLETT STEEL 440 MAIN CAPS [Re: BIGSTROKER] #1707937
12/07/14 09:09 PM
12/07/14 09:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had them on my 500 inch build and they worked out fine except I bought them when they first came out and I had to machine #5 cap. It sat to high and wouldn't let the oil pan sit flush. That was many years ago so I'm sure they addressed that issue. That engine ran 8.60's and lasted 275 passes before the block cracked. They are still being used on an engine to this day.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: BILLETT STEEL 440 MAIN CAPS [Re: pittsburghracer] #1707938
12/07/14 09:30 PM
12/07/14 09:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have the 440Source steel billet main caps on my 493 in my 63 now. I put this eng in the car and on the road in June 2011 and still going strong. I have only raced it once a year the past 3 years as its a 99% driver street car. Ron
Re: BILLETT STEEL 440 MAIN CAPS [Re: BIGSTROKER] #1707939
12/07/14 10:51 PM
12/07/14 10:51 PM
I think your better off buying either Ductile iron main caps, if you can find a set , or aluminum main caps instead of steel I bought a set of the 440 Source aluminum 440 main caps this summer for a recent customers 440 motor, the machine shop said they where great to machine and install. They wanted to know the brand name as they want to start offering them to any other BB Mopar engine builder that come into there shop from now on I've always been against using aluminum main caps on iron blocks so I use to use Mopar brand Ductile iron main caps until that source dry up after Ma Mopar stop offering them I had to switch so I went with the aluminum ones based on what many other racers and engine builders have said on here about the aluminum main caps
Re: BILLETT STEEL 440 MAIN CAPS [Re: Cab_Burge] #1707940
12/07/14 11:11 PM
12/07/14 11:11 PM
gregsdart Offline
gregsdart  Offline
The one low deck 499 (about 730 hp)motor I built with aluminum caps took a lot of beating, then was sold to be used with nitrous. It still is in one piece after a lot of passes! I like aluminum caps because it absorbs the stress by flexing, where a steel cap won't as much, forcing the stress back into the block.
Re: BILLETT STEEL 440 MAIN CAPS [Re: gregsdart] #1707941
12/08/14 12:02 AM
12/08/14 12:02 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
and if your going to be making any serious power don't forget to add a girdle. take a look at our bcr girdle kits which include main caps.
www.bcrproducts.com
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: BILLETT STEEL 440 MAIN CAPS [Re: Jerry] #1707942
12/08/14 11:41 AM
12/08/14 11:41 AM
thanks for all the replys i think i will go with the 440 source steel
Re: BILLETT STEEL 440 MAIN CAPS [Re: BIGSTROKER] #1707943
12/08/14 11:51 AM
12/08/14 11:51 AM
Colorado
funnycar65 Offline
funnycar65  Offline
Colorado
how do you all feel about aluminum main caps in a limited use street motor?
Re: BILLETT STEEL 440 MAIN CAPS [Re: funnycar65] #1707944
12/08/14 12:03 PM
12/08/14 12:03 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
no problems running aluminum main caps on the street or track or both.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: BILLETT STEEL 440 MAIN CAPS [Re: Jerry] #1707945
12/08/14 03:04 PM
12/08/14 03:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I much prefer aluminum caps on any stock block motor that is going to make substantial power.
Monte
Re: BILLETT STEEL 440 MAIN CAPS [Re: Monte_Smith] #1707946
12/09/14 10:02 PM
12/09/14 10:02 PM
Granger,Indiana
badmojocuda Offline
badmojocuda  Offline
Granger,Indiana
HEY FUNNYCAR65... HOW DO YOU FEEL ABOUT SENDING ME THE BLOWER INTAKE I PAID YOU $250.00 BEFORE THANKSGIVING????? badmojocuda. you are starting to look like a thief and a scammer
