I think your better off buying either Ductile iron main caps, if you can find a set
, or aluminum main caps instead of steel
I bought a set of the 440 Source aluminum 440 main caps this summer for a recent customers 440 motor, the machine shop said they where great to machine and install. They wanted to know the brand name as they want to start offering them to any other BB Mopar engine builder that come into there shop from now on
I've always been against using aluminum main caps on iron blocks so I use to use Mopar brand Ductile iron main caps until that source dry up after Ma Mopar stop offering them
I had to switch so I went with the aluminum ones based on what many other racers and engine builders have said on here about the aluminum main caps
