Re: valve adjustment what's better
[Re: Mr.Yuck]
#1704914
11/30/14 02:58 PM
11/30/14 02:58 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
EOI Exhaust opening adjust Intake ICE Intake closing adjust Exhaust
Works on EVERYTHING, much simpler way to do it as well.
[Re: Monte_Smith]
#1704916
11/30/14 03:03 PM
11/30/14 03:03 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
^^^^^^^^^^^^^^^^THIS.........forget the damn 40 year old charts..........LOL!!!
Monte
Thanks, it is WAY easier that way.
[Re: Mr.Yuck]
#1704917
11/30/14 03:12 PM
11/30/14 03:12 PM
Posts: 3,518 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I got this response from a guy at Comp Cams that many would know, the question also covered setting valves with an aluminum head:
Do the cold valve lash settings .006”-.008” TIGHTER than the spec card says. When the motor gets hot, the heads grow and opens up the lash.
Don’t use that chart. Do it like this: Look at one cylinder…rotate the motor by hand….set intake lash when exhaust rocker starts to move. Continue to rotate and set the exhaust when the intake rocker goes all the way down and is about ¾ of the way back up. You can do anything from your Chrysler to a Subaru to Ferrari that way and always be right.
I was at the national event in Columbus one year with a very famous Chrysler Super Stock racer (to remain un-named) and was sitting on his trailer door shooting the breeze as he was running the valves before dinner. I watched as he did the Chrysler chart thing. When he was done, we ran through them again using the approved method I listed above. Some of the settings were .004”-.006” different. The next morning he went about .03 faster than the prediction. The ones in error made the settings too loose and not only lost performance, but if the desired settings were on the loose side anyway, for performance, the risk was there to fail a valve or lifter by making too severe.
[Re: Monte_Smith]
#1704919
11/30/14 04:35 PM
11/30/14 04:35 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
As mentioned forget the charts,set the intake as soon as the exhust starts to open and set the exhaust when the intake is 1/2+ closing.As far as cold setting listen to Monte,it depends on if its iron or aluminium componants or a combination of both and the operating temperture.Generally for a first time cold startup with an iron block/aluminium head combo set the cold setting .004 tighter,all iron componants,.002 tighter,aluminium block/aluminium heads .010/.015 tighter but always leave at least .005 clearence.Warm the engine to operating temperture and set to specs,let it cool and check the clearence,this will be your cold setting.Listen to Monte.
[Re: Al_Alguire]
#1704920
11/30/14 04:36 PM
11/30/14 04:36 PM
Quicktree
only way to do it right
[Re: Al_Alguire]
#1704921
11/30/14 06:20 PM
11/30/14 06:20 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
....but it requires an attention span! I'm guilty.... been a chart guy all my mechanical cam lash adjusting life.
[Re: J_BODY]
#1704922
11/30/14 07:51 PM
11/30/14 07:51 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Don't forget to mark the ones that are done with a sharpie.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Al_Alguire]
#1704924
11/30/14 09:22 PM
11/30/14 09:22 PM
Posts: 685 SW Ohio
AAR-B4
SW Ohio
and quicker if you use the firing order...... set all the intakes 1 then 8 then 4-3............. set all the exhaust 1 then 8 then 4-3............. a lot less cranking this way
[Re: John_Kunkel]
#1704926
11/30/14 10:03 PM
11/30/14 10:03 PM
Jerry Kathe
Monte
The laws of physics have changed in the last 40 years?
No, but cam shaft profiles have changed alot since then, almost every body was using LSA numbers in the 108 range. I checked the chart years ago using the "OLD" tried and true 750 crane roller with 108 LSA and the chart would have been fine. Started messing around with some comp eliminator stuff and the chart went into the trash can - lol.
Like stated prior, stick with the IC, EO method and you can't go wrong.
[Re: Jerry Kathe]
#1704927
11/30/14 10:30 PM
11/30/14 10:30 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
But, IF one has the lobes that work with the chart, why not use the chart...it is easier and faster.
[Re: John_Kunkel]
#1704928
11/30/14 10:37 PM
11/30/14 10:37 PM
Jerry Kathe
Agreed, keep in mind, alot of reinventing the wheel goes on around here, filter through the comments carefully -
