Page 1 of 5 1 2 3 4 5
valve adjustment what's better #1704913
11/30/14 02:55 PM
11/30/14 02:55 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
So I'm getting ready to adjust my valves w/ my new Smith Bros adjusters.. I have been using the adjuster intake when Ex opens and adjust ex when intake starts to shut method. BUT I have it at TDC and could use the mopar method adjust, turn 1/4 adjust turn 1/4... It's a 588 solid roller w/ stage VI heads if it matters....
Coming soon!!!!
Re: valve adjustment what's better [Re: Mr.Yuck] #1704914
11/30/14 02:58 PM
11/30/14 02:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
EOI Exhaust opening adjust Intake
ICE Intake closing adjust Exhaust
Works on EVERYTHING, much simpler way to do it as well.
Re: valve adjustment what's better [Re: Al_Alguire] #1704915
11/30/14 03:01 PM
11/30/14 03:01 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
^^^^^^^^^^^^^^^^THIS.........forget the damn 40 year old charts..........LOL!!!
Monte
Re: valve adjustment what's better [Re: Monte_Smith] #1704916
11/30/14 03:03 PM
11/30/14 03:03 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Monte
Thanks, it is WAY easier that way.
Re: valve adjustment what's better [Re: Mr.Yuck] #1704917
11/30/14 03:12 PM
11/30/14 03:12 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I got this response from a guy at Comp Cams that many would know, the question also covered setting valves with an aluminum head:
Do the cold valve lash settings .006”-.008” TIGHTER than the spec card says. When the motor gets hot, the heads grow and opens up the lash.
Don’t use that chart. Do it like this: Look at one cylinder…rotate the motor by hand….set intake lash when exhaust rocker starts to move. Continue to rotate and set the exhaust when the intake rocker goes all the way down and is about ¾ of the way back up. You can do anything from your Chrysler to a Subaru to Ferrari that way and always be right.
I was at the national event in Columbus one year with a very famous Chrysler Super Stock racer (to remain un-named) and was sitting on his trailer door shooting the breeze as he was running the valves before dinner. I watched as he did the Chrysler chart thing. When he was done, we ran through them again using the approved method I listed above. Some of the settings were .004”-.006” different. The next morning he went about .03 faster than the prediction. The ones in error made the settings too loose and not only lost performance, but if the desired settings were on the loose side anyway, for performance, the risk was there to fail a valve or lifter by making too severe.
Re: valve adjustment what's better [Re: 340Cuda] #1704918
11/30/14 04:10 PM
11/30/14 04:10 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You really never know what your cold to hot numbers will be....UNTIL YOU CHECK IT. So on a new install or ANY install for that matter, if you want to lash them .008-.010 tight, that's fine. But after that, warm the motor to the temp where you intend to run it and then lash them HOT. Now when it cools off, check them and see how tight they are. THIS is your cold number and you will never have to lash hot valves again.
A motors block and head configurations vary as to how much stuff grows. We race our all aluminum motor at around 100* of water temp. To have the lash at .024 at 100*, I have to lash them at .011 cold. When we get back from a run and it has heat soaked on the tow back to the 150* range, the valves will be at .030...........SO, CHECK IT WHERE YOU RUN IT temp wise.
Monte
Re: valve adjustment what's better [Re: Monte_Smith] #1704919
11/30/14 04:35 PM
11/30/14 04:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
As mentioned forget the charts,set the intake as soon as the exhust starts to open and set the exhaust when the intake is 1/2+ closing.As far as cold setting listen to Monte,it depends on if its iron or aluminium componants or a combination of both and the operating temperture.Generally for a first time cold startup with an iron block/aluminium head combo set the cold setting .004 tighter,all iron componants,.002 tighter,aluminium block/aluminium heads .010/.015 tighter but always leave at least .005 clearence.Warm the engine to operating temperture and set to specs,let it cool and check the clearence,this will be your cold setting.Listen to Monte.
Re: valve adjustment what's better [Re: Al_Alguire] #1704920
11/30/14 04:36 PM
11/30/14 04:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
only way to do it right
Re: valve adjustment what's better [Re: Al_Alguire] #1704921
11/30/14 06:20 PM
11/30/14 06:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....but it requires an attention span! I'm guilty.... been a chart guy all my mechanical cam lash adjusting life.
Re: valve adjustment what's better [Re: J_BODY] #1704922
11/30/14 07:51 PM
11/30/14 07:51 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Don't forget to mark the ones that are done with a sharpie.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: valve adjustment what's better [Re: Savoy1964] #1704923
11/30/14 08:32 PM
11/30/14 08:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I loosen ALL the nuts when I start that way when I make my final check if I find a loose nut then I know I missed one. I been doing it this way for over 30 years working on Imports in flat rate shops so it's automatic for me and I don't have to think about it.When you do 16 valves on one head as fast as you can you think of creative ways to save time and improve accuracy
Gus
64 Plymouth Savoy
Dana 60
Re: valve adjustment what's better [Re: Al_Alguire] #1704924
11/30/14 09:22 PM
11/30/14 09:22 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
and quicker if you use the firing order......
set all the intakes 1 then 8 then 4-3.............
set all the exhaust 1 then 8 then 4-3.............
a lot less cranking this way
Re: valve adjustment what's better [Re: Monte_Smith] #1704925
11/30/14 09:55 PM
11/30/14 09:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Monte
The laws of physics have changed in the last 40 years?
Re: valve adjustment what's better [Re: John_Kunkel] #1704926
11/30/14 10:03 PM
11/30/14 10:03 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Monte
No, but cam shaft profiles have changed alot since then, almost every body was using LSA numbers in the 108 range. I checked the chart years ago using the "OLD" tried and true 750 crane roller with 108 LSA and the chart would have been fine. Started messing around with some comp eliminator stuff and the chart went into the trash can - lol.
Like stated prior, stick with the IC, EO method and you can't go wrong.
Re: valve adjustment what's better [Re: Jerry Kathe] #1704927
11/30/14 10:30 PM
11/30/14 10:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
But, IF one has the lobes that work with the chart, why not use the chart...it is easier and faster.
Re: valve adjustment what's better [Re: John_Kunkel] #1704928
11/30/14 10:37 PM
11/30/14 10:37 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Agreed, keep in mind, alot of reinventing the wheel goes on around here, filter through the comments carefully -
Re: valve adjustment what's better [Re: Jerry Kathe] #1704929
11/30/14 11:06 PM
11/30/14 11:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve always set the in. when the ex. just starts to open and the ex. when the in. fully openes then just starts to close. I`ve measured every inch of my lobe and this is the loosest point on the lobe. Some have stated it`s from shaft flex etc. but I don`t buy it.
Re: valve adjustment what's better [Re: AAR-B4] #1704930
11/30/14 11:13 PM
11/30/14 11:13 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I do mine straight across the firing order...EOIC
5.53 @ 125 1/8th on the launch control..more left in her!
Re: valve adjustment what's better [Re: Eric] #1704931
12/01/14 12:16 AM
12/01/14 12:16 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've always used the MP 1/4 turn method, 1 revolution and I'm done.
Re: valve adjustment what's better [Re: Savoy1964] #1704932
12/01/14 01:04 AM
12/01/14 01:04 AM
I always start at the front of the motor, left or right side doesn't matter. I take that valve cover off and bump the starter over until the front exhaust valve opens and set the intake lash, bump the starter over until the intake valve opens all the way and starts to close and set the exhaust lash. Go to the second set of valves and work my way to the back of the head , one at a time, front to back and then button that side up and do the other side the same way On the drivers side you can do the #5 intake valve first and then do the #7 intake valve second and then do the #5 exhaust and finish with the #7 exhaust valve, there just 90 degrees apart in firing so why not take advantage of that I haven't figure out how to do any other valves like that yet
