Page 3 of 4 1 2 3 4
Re: Fuel filter? [Re: Cab_Burge] #1701820
11/26/14 10:25 PM
11/26/14 10:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Boy do I feel like a geek I think I might just switch the positions and clip my ET from 10.91 to maybe 10.50 I thought I was doing pretty good with a 3600# car and 3.54 gears I'll change it tomorrow and wait unti spring and try it out.
Gus
Gus, I will betcha you have all the ET and MPH your going to get out of the Carter pump and filter, no matter where you mount that filter All kidding aside those 90 GPH Fram filters do have two ninety degree turns inside of them Changing the location from the inlet to the outlet side of the pump may or any not make any difference to that pump I think those small Carter electric pumps, race or street version, are not rated above 6 lbs of pressure so the suction side is probally not straining real hard to keep the pump in fuel Maybe it is time for a better pump and filter combination
Yeah Cab I know I've pretty much exceeded the limits of that pump even though it's the 14 PSI race unit I'm still pulling hard at the stripe and I'm running just under 125 MPH I got a buddy that sells wires and fuel pumps so I might just upgrade this winter
Thanks Cab
Gus
64 Plymouth Savoy
Dana 60
Re: Fuel filter? [Re: Mopar_Ray] #1701821
11/27/14 12:55 AM
11/27/14 12:55 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Won't it make sense that a finer filter would create more resistance to flow per given area, but increasing the surface area of the finer filter would result in the same resistance? In other words if I have a 10 micron filter with 1 sq.in. of filter surface area, it would have the same flow restriction as a 100 micron filter with 10 sq. in of surface area? So as long as my 100 micron fliter was rated to flow as much or more than the 10 micron filter, it should result in no additional strain on the pump.
Sorry, just threw this in for thought.
I run a 10 micron "Pre filter" and a 100 micron before the regulator. And the 100 micron filter is a pretty large unit (8" long, 2" diameter).
Re: Fuel filter? [Re: ProStDodge] #1701822
11/27/14 02:25 AM
11/27/14 02:25 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Its apears you understand that filtration and flow are two seperate values...but you have your numbers backwards.
All the same, you are much further along with
understanding this some.
Re: Fuel filter? [Re: ProStDodge] #1701823
11/27/14 02:29 AM
11/27/14 02:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
News flash boys... PUMPS DONT SUCK.. atmospheric pressure
PUSHES the fuel into the pump.. the pump creates the
negative pressure(just like the piston does on the
engine).. thats why the pump companies tell you to
go larger on the inlet side..thats also why you dont
put a fine filter on the inlet side
Re: Fuel filter? [Re: MR_P_BODY] #1701824
11/27/14 03:16 AM
11/27/14 03:16 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Do what?
You are kidding I hope.
Re: Fuel filter? [Re: Jerry Kathe] #1701825
11/27/14 03:20 AM
11/27/14 03:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do what?
Are you asking me "do what"... and no I'm not kidding
Re: Fuel filter? [Re: MR_P_BODY] #1701826
11/27/14 03:24 AM
11/27/14 03:24 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Do what?
Um......ok....
Re: Fuel filter? [Re: Jerry Kathe] #1701827
11/27/14 03:32 AM
11/27/14 03:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do what?
Um......ok....
I have a few years flowing pumps... if you dont think
its atmospheric pressure try this.. get your biggest
and baddest pump and flow it.. then apply a vac to
the tank.. I'll bet you see the flow drop with the
vac... I tested pumps a long time and did all sorts
of tests... the same thing happens when you apply a
vac to the oil pan.. the pump put put drops
Re: Fuel filter? [Re: MR_P_BODY] #1701828
11/27/14 04:04 AM
11/27/14 04:04 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Your confusing the hell out of me.....
if you have tested pumps then you know high pressure pumps have low draw and high volume pumps have reasonably strong draw ( the term strong is relative with this subject)
Sure you could create a negative pressure in the reservoir - but you are simply canceling the negative pressure the pump is creating.
For clarity lets be sure we are talking one concept here....electric fuel pumps for carb and not injection systems.
Re: Fuel filter? [Re: Mopar_Ray] #1701829
11/27/14 04:17 AM
11/27/14 04:17 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
On the Coronet, I have a 100 micron stainless screen filter from KRC Racing as a pre-pump filter on my EFI system with a 10 micron EFI filter after the pump.
http://www.summitracing.com/parts/krc-4706r/overview/
On the Charger I have a Mallory Comp 500 (40 micron) pre-pump filter and the Mallory 250 fuel pump, no problems.
http://www.summitracing.com/parts/maa-3500m/overview/
Re: Fuel filter? [Re: ProStDodge] #1701830
11/27/14 04:38 AM
11/27/14 04:38 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Yes, the size of a filter will of coarse increase the numbers of holes which will keep the speed( velocity) of the fuel down and equals in lower pressure over the filter.
If you have a wire mesh filter in SS steel, the diameter of the wire will change how much of the filter area that is open and how much area that are lost with the actual wire material, so the exact same tube of wire mesh can have the same 10 microns( 10 my millimeters) and still have different flow/ pressure numbers.
Inlet size and outlet size and also placement of those will also effect this.
Re: Fuel filter? [Re: MR_P_BODY] #1701831
11/27/14 12:34 PM
11/27/14 12:34 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Welcome back...put some venison in the freezer?
Re: Fuel filter? [Re: Challenger 1] #1701832
11/27/14 12:46 PM
11/27/14 12:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks.. yeah the wife and I both took a 6 point...
I passed on some others.. we have a 12 point running
around but it never came out during the day
Re: Fuel filter? [Re: Jerry Kathe] #1701833
11/27/14 01:55 PM
11/27/14 01:55 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Do what?
Um......ok....
How about doing a little research before you start blasting someone who has lots of fuel system experience. Mr P is EXACTLY right. Electric pumps are made to PUSH fuel and every company suggests they be gravity fed, but they WILL pull fuel from a dip tube once the siphon effect takes over
Monte
Re: Fuel filter? [Re: MR_P_BODY] #1701834
11/27/14 02:01 PM
11/27/14 02:01 PM
jersey
Spaceman Spiff Offline
jersey
So if I mount the pump on top of the tank...it should never push fuel, since atmospheric pressure isn't feeding it right?
Or am I not understanding what you mean?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Fuel filter? [Re: MR_P_BODY] #1701835
11/27/14 02:04 PM
11/27/14 02:04 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Years ago we discovered the flow limits of the HPG1 fram filter while running our engine fuel, and nitrous system fuel from the same source.
Now we run the Mallory Comp500. Cannister type dual -8 inlet and outlet which works great with my favorite pump, the Dominator series Volumax 250 georotor which features a dual inlet and single outlet. The Mallory filter is 40 micron. It's an excellent upgrade from the HPG1.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Fuel filter? [Re: Spaceman Spiff] #1701836
11/27/14 02:06 PM
11/27/14 02:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No... you have 14.7 psi pushing on the fuel.. thats
a lot of vertical height
EDIT
when doing fine testing we like to use a measurement
of water(app. 30" of water is 1 psi) so if you turn the
psi into inch of water you an get a idea of the
vertical height... but understand the more you go
vertical the less pressure you have to push in the
fuel.. so it reduces the output
Re: Fuel filter? [Re: MR_P_BODY] #1701837
11/27/14 02:18 PM
11/27/14 02:18 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
27.71" of head pressure = 1 psi of water, gas is almost the same in a car situation. SO if your tank is 14" below the tank, it will need to pull .5 psi to get it to the pump. More math makes the brain hurt....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Fuel filter? [Re: astjp2] #1701838
11/27/14 02:20 PM
11/27/14 02:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use 30" as a quick number so its easy to figure
in my head... most dont give a damn about it
Re: Fuel filter? [Re: Spaceman Spiff] #1701839
11/27/14 02:44 PM
11/27/14 02:44 PM
Jerry Kathe Offline
Jerry Kathe  Offline
As I said prior....not going to debate...so I will sign out with a few comments on this, as it has been twisted into a complete fuster cluck.
I didnt blast anyone one......thicken up.
my inputs were based on flow vs filtration aspects.
if you read the comment about pumps dont suck....you will see it contradicts itself.
atmospheric pressure and barometric pressure is the same.......so unless its at the nominal 29.92......it isn't 14.7
But I wouldnt know this since I have never done any research would I Monte?
Page 3 of 4 1 2 3 4
