Page 1 of 3 1 2 3
Performer RPM intake or not? #1696101
11/08/14 03:28 PM
11/08/14 03:28 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I've been tossing around the idea of sliding a Performer RPM intake on the Imperial. I found a cheap intake locally.
The car is my 72 Imperial with a stock 440. I will be adding my Edelbrock heads and a 261* .463" cam with a 114 LSA. It is topped with a 600 cfm AFB on a stock intake.
I want torque between 1500 and 2500 rpm and don't care about power above 4500 rpm.
The engine has the stock air cleaner on it. I'm not sure if it would clear the hood or if I would need a drop base air cleaner.
It would seem a bit out of place to drop a stock iron intake on top of a set of iron heads.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696102
11/08/14 03:38 PM
11/08/14 03:38 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I ran this intake on my first and last 440.I still use it on my 440/493. The last 440 had '452 heads, a MP 284/484 cam and a Holley 750 and 1 7/8 headers. Lots of fun in that one. I've used that intake exclusively since 2002. It seals great and makes great power at all levels.
Re: Performer RPM intake or not? [Re: Kern Dog] #1696103
11/08/14 03:44 PM
11/08/14 03:44 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm tempted but don't know if it will clear the hood.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696104
11/08/14 03:45 PM
11/08/14 03:45 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Not even a question with the mods you are doing, GET IT. You should be able to fit it with a drop base and shorter air filter.
Re: Performer RPM intake or not? [Re: Azzkikrcuda] #1696105
11/08/14 03:49 PM
11/08/14 03:49 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It'll be kinda funny popping the hood on the faded old Imperial and seeing all that aluminum on the engine.
I was really tempted to go with the HP style exhaust manifolds but I don't want to get into messing with the exhaust pipes. Mine may be a bit too old to survive welding and I don't need to drop the coin on new exhaust.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696106
11/08/14 04:07 PM
11/08/14 04:07 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
440's really like headers.....
Re: Performer RPM intake or not? [Re: feets] #1696107
11/08/14 04:33 PM
11/08/14 04:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It should fit w/ a drop base. I had one on my old 67 coronet. Good intake. I ran a 488 summit cam. Seemed to like it. I also ran a CH4B and a 1/2" 4 hole spacer.
Coming soon!!!!
Re: Performer RPM intake or not? [Re: 70blackfish] #1696108
11/08/14 04:46 PM
11/08/14 04:46 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
No.
I am not getting into the exhaust at this time.
If my devious little plot holds true I'd have to replace it all again anyway.
Besides, this car is meant to be QUIET while cruising. Headers are much louder than iron manifolds.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696109
11/08/14 05:01 PM
11/08/14 05:01 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Certainly nothing wrong with trying it. But at this power level, it will likely have nothing over the CH4B.
Re: Performer RPM intake or not? [Re: BSB67] #1696110
11/08/14 05:13 PM
11/08/14 05:13 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I can't find a CH4B on the cheap. I'd stuff an old Performer on it if I had one.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696111
11/08/14 05:45 PM
11/08/14 05:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Mine fits under the stock hood with a Summit drop base and a 4"element.
You might be able to see it with this picture.
Gus
64 Plymouth Savoy
Dana 60
Re: Performer RPM intake or not? [Re: fourgearsavoy] #1696112
11/08/14 06:07 PM
11/08/14 06:07 PM
Europe
rory73 Offline
rory73  Offline
Europe
I went for a Weiand Action+ (8009) dual plane which is about the same size as the stock intake. Nice on a street car too. Since you've already got the RPM it won't hurt bolting it on.
Re: Performer RPM intake or not? [Re: rory73] #1696113
11/08/14 06:21 PM
11/08/14 06:21 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I don't have the RPM intake.
Another concern is the transmission, throttle, and cruise control linkages. If I buy an intake I need to spend more money on that stuff.
Most annoying.
All I want is good torque from idle up through the cruising range.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696114
11/08/14 06:39 PM
11/08/14 06:39 PM
OK so what ex is on there now, the low perf logs/restricted muffs/non mandrel bends? I know you said you dont want to mess with the ex but that's the most restricted part of the overall air pump (eng) plus I would mod the dist subsystems (last). EDIT I ain't a cam guy but make the right choice there especially for the low RPM torque you are after
Re: Performer RPM intake or not? [Re: feets] #1696115
11/08/14 06:42 PM
11/08/14 06:42 PM
Europe
rory73 Offline
rory73  Offline
Europe
You've probably seen these already but have a look here:
http://www.hotrod.com/how-to/engine/hrdp-0712-mopar-intake-manifold-comparo/
http://www.hotrod.com/how-to/engine/mopp-0207-intake-manifold-engine-and-rpm-range-test/
Of course it's only an indication and should be taken with a pinch of salt.
Personally I like the 8009, it fits well and is an improvement over the stock design. Easily available s/h too. YMMV.
Re: Performer RPM intake or not? [Re: RapidRobert] #1696116
11/08/14 06:48 PM
11/08/14 06:48 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm not touching the exhaust.
Period.
End of sentence.
Why, you ask?
First, what is under the car now is a fairly nice 2-1/2" setup with nice bends, H-pipe, decent mufflers, and resonators to help quiet the sound.
Second, future mods would mean throwing it all away.
- Stu Harmon
Re: Performer RPM intake or not? [Re: rory73] #1696117
11/08/14 06:51 PM
11/08/14 06:51 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I was actually reading those when you made that post.
I, too, like the 8009 and was just digging around online for one.
- Stu Harmon
Re: Performer RPM intake or not? [Re: feets] #1696118
11/08/14 06:52 PM
11/08/14 06:52 PM
alright, that makes good sense to me
Re: Performer RPM intake or not? [Re: RapidRobert] #1696119
11/08/14 07:51 PM
11/08/14 07:51 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My R+D buddy flowed a stock 440 spreadbore intake and came to the conclusion CFM wise that it wouldn't give up anything up to about 5500 rpm.
Whether there is a lot of runner velocity difference between the stock one and an RPM that might affect low and midrange power .
He figured there wasn't enough difference up to that engine speed between a stock one and any of the standard rise intakes ie Performer, C4B, Weiand 360 deg etc to bother changing one unless you wanted to save the weight difference.
Another respected builder in my area has found the same thing dyno testing the regular rise intakes. He told a buddy of mine "pile them all on the floor, there isn't 10 hp between the lot of them". Again this is with the standard rise type intake which an RPM clearly is not.
For your intended purpose I would paint those heads engine color, stick with the stock intake (plug the air injector and EGR if it has it) and spend the Performer RPM money on building and tuning a Thermoquad. 850 CFM when you need it and fuel mileage when you want it. Win win.
Kevin
Re: Performer RPM intake or not? [Re: Twostick] #1696120
11/08/14 08:17 PM
11/08/14 08:17 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Thanks for the input.
I'd rather spend the money on an updated EFI system. I'd install what I have but that would be replacing the A/C compressor. I'm not into making new lines and all that stuff at this tine.
My system is currently charged with 84 ounces of R12 and I'd hate to see it get away. It blows colder than my 2012 Chrysler 200.
- Stu Harmon
Page 1 of 3 1 2 3
