Re: 1974 charger headlight problem
[Re: moparvinson]
#1693792
11/03/14 02:58 PM
11/03/14 02:58 PM
RapidRobert
Classic symptoms of a bad HL switch (even tho its new) Murphys Law. Unfortunately no return (usually) with electrical parts. I'd purchase another one & likely you will be fine.
[Re: 74Charger]
#1693794
11/03/14 08:55 PM
11/03/14 08:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The headlights have a self resetting circuit breaker. That is what's causing the lights to go off, then after a while work.
Now the question is what is tripping the breaker.
I'd check for loose and dirty connections.
[Re: moparx]
#1693796
11/04/14 12:55 PM
11/04/14 12:55 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
I agree check the dimmer.My Dart did the same thing.The dimmer was bad.Rocky
Chrysler Firepower
[Re: moparvinson]
#1693798
11/05/14 09:56 PM
11/05/14 09:56 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Glad to hear you got it. I would see the headlite switch cause that problem most of the time as some times the contacts in the circuit breaker in the switch get corroded and it cause some heat in the switch which can trip the breaker in the switch. Ron
