1974 charger headlight problem #1693789
11/03/14 03:48 AM
11/03/14 03:48 AM
Albuquerque, new mexico
moparvinson Offline OP
my son took out his charger for its first run, after about 10 min . the headlights turn off? all other lights stay on and are working normal. if you turn them off for a few minutes and turn them back on they work for a few min. then shut off again. I did a search for headlight relay but all that comes up is the headlight switch which is new (from autozone).is the relay in the switch or somewhere else? Thanks for any help.
Re: 1974 charger headlight problem [Re: moparvinson] #1693790
11/03/14 04:17 AM
11/03/14 04:17 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
There are NO fuses or relays on headlight circuits, bad connection and/or bad switch.
Re: 1974 charger headlight problem [Re: 6bblgt] #1693791
11/03/14 12:48 PM
11/03/14 12:48 PM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
Yup and I would also consider a headlight relay kit to take the load off.
http://www.ebay.com/itm/Dapper-Lighting-...f78&vxp=mtr
Re: 1974 charger headlight problem [Re: moparvinson] #1693792
11/03/14 02:58 PM
11/03/14 02:58 PM
Classic symptoms of a bad HL switch (even tho its new) Murphys Law. Unfortunately no return (usually) with electrical parts. I'd purchase another one & likely you will be fine.
Re: 1974 charger headlight problem [Re: moparvinson] #1693793
11/03/14 06:59 PM
11/03/14 06:59 PM
Creedmoor, NC, USA
74Charger Offline
74Charger  Offline
Creedmoor, NC, USA
Check the headlamp harness ground wire. It bonds to ground close to negative battery terminal, and on the battery side of the radiator support. I have seen these cause lots of headaches, and often get broken due to multiple battery replacements over the years. Good luck!
Re: 1974 charger headlight problem [Re: 74Charger] #1693794
11/03/14 08:55 PM
11/03/14 08:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The headlights have a self resetting circuit breaker. That is what's causing the lights to go off, then after a while work.
Now the question is what is tripping the breaker.
I'd check for loose and dirty connections.
Don't be the exception.
Re: 1974 charger headlight problem [Re: Supercuda] #1693795
11/04/14 12:11 AM
11/04/14 12:11 AM
moparx Online content
moparx  Online Content
the dimmer switch also can cause this symptom.check the connections for proper contact/corrosion.
Re: 1974 charger headlight problem [Re: moparx] #1693796
11/04/14 12:55 PM
11/04/14 12:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree check the dimmer.My Dart did the same thing.The dimmer was bad.Rocky
Chrysler Firepower
Re: 1974 charger headlight problem [Re: therocks] #1693797
11/05/14 07:44 PM
11/05/14 07:44 PM
I bought a new american made headlight switch and a new dimmer switch. not sure which one it was but lights are working great now. Thanks for all of the help
Re: 1974 charger headlight problem [Re: moparvinson] #1693798
11/05/14 09:56 PM
11/05/14 09:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Glad to hear you got it. I would see the headlite switch cause that problem most of the time as some times the contacts in the circuit breaker in the switch get corroded and it cause some heat in the switch which can trip the breaker in the switch. Ron
