Power steering valve on steering box #1691513
10/28/14 02:18 AM
10/28/14 02:18 AM
fredericksburg virginia
mopwrd340 Offline OP
Im working on a 69 RR hook up P/S pump fire up steering wheel goes right ok i look it up on i adjust the valve still no go .I pull the valve take it apart it was stuck rusted but not bad clean it up get the spool moving inside like its supposed to now it turns right on its own our i can get it to stay straight but it feels locked . Should i go look for another valve at the J/Y or grab the whole box with the valve on it
Re: Power steering valve on steering box [Re: mopwrd340] #1691514
10/28/14 02:47 AM
10/28/14 02:47 AM
it might be fubared. I would get the front wheels off the ground/eng idling/just barely loosen the 2 bolts/tap it slightly either way & see if you can get it to keep the wheels straight ahead/move st wheel thru it's travel both ways & see if it is now normal (dont stick arm thru st wheel spokes) and from your descrip you may have just done this (& it dont feel right)
Re: Power steering valve on steering box [Re: RapidRobert] #1691515
10/28/14 04:47 AM
10/28/14 04:47 AM
Thats what I've been doing to it it has been jacked up the whole time the guy that is painting it took it off and it sat outside for a couple weeks .
Re: Power steering valve on steering box [Re: mopwrd340] #1691516
10/28/14 04:52 AM
10/28/14 04:52 AM
md
mopars4ever Offline
mopars4ever  Offline
md
if your talking about the valve on top of the steering box, those valves are tough to position properly once they are moved. maybe someone here can guide you though it as i don`t know enough to help.
Re: Power steering valve on steering box [Re: mopars4ever] #1691517
10/28/14 05:09 AM
10/28/14 05:09 AM
I was talking to a guy that works at this shop where the car is at and he was working on a 71 challenger when they were taking the car apart they took the valve off with the P/S pump and turned it in as a core . They got another one at the J/Y he just stuck it on there and it worked fine .I will just get another one for it and give it a shot i tried adjusting this thing for a hour today .
