Im working on a 69 RR hook up P/S pump fire up steering wheel goes right ok i look it up on i adjust the valve still no go .I pull the valve take it apart it was stuck rusted but not bad clean it up get the spool moving inside like its supposed to now it turns right on its own our i can get it to stay straight but it feels locked . Should i go look for another valve at the J/Y or grab the whole box with the valve on it
