Hemi with a shaker...
#1690656
10/26/14 08:57 AM
10/26/14 08:57 AM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
I've seen previous posts on here, but can anyone with real world experience school me on putting a hemi in an E body using a B/RB k frame using Schumacher or Aruzza mounts? I've seen mixed reviews with both... Just wanna know if they'll really work with no issues??? TIA
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Hemi with a shaker...
[Re: MoparJunkie]
#1690658
10/26/14 11:03 AM
10/26/14 11:03 AM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Bought mounts off ebay. Not sure the brand. Put hemi in our 74 challenger with orignal k frame. Turned out pretty nice
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: RUNCHARGER]
#1690664
10/26/14 11:21 PM
10/26/14 11:21 PM
Posts: 2,676 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I put a Hemi in a 1970 B body using the Schumacher mounts. Everything fit perfect. They give almost none when revving the engine.
2011 Drag Pak Challenger
[Re: MoparJunkie]
#1690666
12/17/14 06:14 AM
12/17/14 06:14 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
schaumacker make drop hemi mounts...you must specify to him..i have them..i also have the shim kit too.you will need shims with alum covers..especially with drop mounts...your bubble will not work with reg mounts
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: sublimehemi]
#1690667
12/17/14 10:27 AM
12/17/14 10:27 AM
MoparJunkie
I have spoken with him. He said that everyone's case seems to be different. So, he told me to install the engine and whatever kind of adjustments I'd need he would offset new brackets and provide them for me. He never mentioned anything about shims for the shaker??? Can you elaborate some?
[Re: MoparJunkie]
#1690668
12/17/14 03:12 PM
12/17/14 03:12 PM
sublimehemi
sandwich IL
ok the reason why he puts motor up higher is cause to clear pass valve cover on shock tower now when you drop mount so your shaker fits...that alum cover will come so close or kiss tower...then if that happens you will need shims...they go in between block and mount...good luck...i got mine sitting money...every car is different so good luck.
[Re: sublimehemi]
#1690669
12/17/14 03:28 PM
12/17/14 03:28 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've done several B/E B/RB K frames using the Schumacher drop mounts, the valve cover will be within 1/4" to 1/2" of the passenger tower (stock covers) some cars required a shim, some didn't, all fresh air hood cars too....you see many posts on this subject, and many complaints of hood interference on fresh air cars, I think the problem is lack of communication/information from both the customer and supplier in regards to the entire application, to simply ask for swap mounts, that's what you get, take the time to parlay more info on your swap to the vendor, this will/should yield the right parts
[Re: DAYCLONA]
#1690670
12/17/14 04:15 PM
12/17/14 04:15 PM
MoparJunkie
Reading previous posts/problems is what prompted me to call Schumacher before even ordering the swap mounts. I told him my application and expressed my concern over the issues. He reassured me that any issues I had after installing, he would work dilligently to resolve. As stated earlier, he said that he handles each on a case by case basis. Too many variables to be able to say one set fits all....
[Re: MoparJunkie]
#1690671
12/18/14 02:35 AM
12/18/14 02:35 AM
Posts: 147 Alberta, Canada eh!
70Cudha
Alberta, Canada eh!
gg70
I have one of Gary's 426 hemis (MP crate) in my cuda up here in Alberta CA and it is running just fine. Its making lots of power. I'm using the original v8 k member with Schumacher mounts. All fit well with zero installation problems. I haven't picked up the shaker kit for it yet so don't know if I'll have any height issues.
1970 EV2 Barracuda Hardtop 1970 FE5 Barracuda Gran Coupe Convertible 1969 B5 Dart GTS 383 1968 TT1 Barracuda Convertible 1997 Ram SS/T 2008 3500 Ram Diesel
