Hemi with a shaker... #1690656
10/26/14 08:57 AM
10/26/14 08:57 AM
Home of the Bluegrass
MoparJunkie Offline OP
I've seen previous posts on here, but can anyone with real world experience school me on putting a hemi in an E body using a B/RB k frame using Schumacher or Aruzza mounts? I've seen mixed reviews with both... Just wanna know if they'll really work with no issues???
TIA
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Hemi with a shaker... [Re: MoparJunkie] #1690657
10/26/14 10:59 AM
10/26/14 10:59 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
in the real world.
hemi and "NO ISSUES" is only a dream.
perception is 90% of reality
Re: Hemi with a shaker... [Re: MoparJunkie] #1690658
10/26/14 11:03 AM
10/26/14 11:03 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Bought mounts off ebay. Not sure the brand. Put hemi in our 74 challenger with orignal k frame. Turned out pretty nice
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Hemi with a shaker... [Re: toplescuda] #1690659
10/26/14 12:05 PM
10/26/14 12:05 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I put my 426 hemi in a 70 Challenger vert using Arruza mounts. NO issues.
It wasn't a shaker. So I don't know how that would have been as far as bubble height.
Re: Hemi with a shaker... [Re: Finoke] #1690660
10/26/14 01:03 PM
10/26/14 01:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I dunno, maybe.
Sheldon
Re: Hemi with a shaker... [Re: MoparJunkie] #1690661
10/26/14 01:06 PM
10/26/14 01:06 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Hemi with Shumacher polyloc mounts in my Challenger fit fine. Never
busted a motor mount after that. John milled the Stage 5 intake &
the bubble height was only about 1/4"higher than with the factory
intake.
Re: Hemi with a shaker... [Re: RUNCHARGER] #1690662
10/26/14 01:07 PM
10/26/14 01:07 PM
RUNCHARGER Offline
RUNCHARGER  Offline
What I did was build my own "Mickey Mouse Mount" This is what Arruza sells but I reinforced mine more than what he does. You modify a wedge mount and use a stock insulator on the right side. On the left it is a solid mount that bolts to the stock wedge K-member mount. My engine is in the exact stock location. As soon as I get a few friends over to bolt on the hood I'll fab up the shaker base but I'm using a Stage V intake so it will have more of a drop than a stock shaker base along with the wider carb spread. I have a hunch my shaker will still have to stick up a shiver higher than stock but that's due to the manifold not the mounts.
Sheldon
Re: Hemi with a shaker... [Re: RUNCHARGER] #1690663
10/26/14 01:14 PM
10/26/14 01:14 PM
RUNCHARGER Offline
RUNCHARGER  Offline
BTW: If you use the Arruza mount keep an eye on the right side. My friend had one in his little 426 powered Charger and I noted the thin metal was tearing apart, that's why I built my own with thicker metal and I triangulated it in two spots so it would stand up. Not dissing his product but I'm just saying what I witnessed with that mount. I wouldn't want that problem with my 4 speed 528.
This is just sitting there from about a month ago.
Sheldon
Re: Hemi with a shaker... [Re: RUNCHARGER] #1690664
10/26/14 11:21 PM
10/26/14 11:21 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I put a Hemi in a 1970 B body using the Schumacher mounts. Everything fit perfect. They give almost none when revving the engine.
2011 Drag Pak Challenger
Re: Hemi with a shaker... [Re: rickseeman] #1690665
12/16/14 11:38 PM
12/16/14 11:38 PM
Update...
Been gathering parts to start this project. Stopped and chatted with Gary Stanton yesterday and my 472 Hemi is almost ready!!!!
Re: Hemi with a shaker... [Re: MoparJunkie] #1690666
12/17/14 06:14 AM
12/17/14 06:14 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
schaumacker make drop hemi mounts...you must specify to him..i have them..i also have the shim kit too.you will need shims with alum covers..especially with drop mounts...your bubble will not work with reg mounts
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Hemi with a shaker... [Re: sublimehemi] #1690667
12/17/14 10:27 AM
12/17/14 10:27 AM
I have spoken with him. He said that everyone's case seems to be different. So, he told me to install the engine and whatever kind of adjustments I'd need he would offset new brackets and provide them for me. He never mentioned anything about shims for the shaker??? Can you elaborate some?
Re: Hemi with a shaker... [Re: MoparJunkie] #1690668
12/17/14 03:12 PM
12/17/14 03:12 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
ok the reason why he puts motor up higher is cause to clear pass valve cover on shock tower now when you drop mount so your shaker fits...that alum cover will come so close or kiss tower...then if that happens you will need shims...they go in between block and mount...good luck...i got mine sitting money...every car is different so good luck.
Re: Hemi with a shaker... [Re: sublimehemi] #1690669
12/17/14 03:28 PM
12/17/14 03:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done several B/E B/RB K frames using the Schumacher drop mounts, the valve cover will be within 1/4" to 1/2" of the passenger tower (stock covers) some cars required a shim, some didn't, all fresh air hood cars too....you see many posts on this subject, and many complaints of hood interference on fresh air cars, I think the problem is lack of communication/information from both the customer and supplier in regards to the entire application, to simply ask for swap mounts, that's what you get, take the time to parlay more info on your swap to the vendor, this will/should yield the right parts
Re: Hemi with a shaker... [Re: DAYCLONA] #1690670
12/17/14 04:15 PM
12/17/14 04:15 PM
Reading previous posts/problems is what prompted me to call Schumacher before even ordering the swap mounts. I told him my application and expressed my concern over the issues. He reassured me that any issues I had after installing, he would work dilligently to resolve. As stated earlier, he said that he handles each on a case by case basis. Too many variables to be able to say one set fits all....
Re: Hemi with a shaker... [Re: MoparJunkie] #1690671
12/18/14 02:35 AM
12/18/14 02:35 AM
Alberta, Canada eh!
70Cudha Offline
70Cudha  Offline
Alberta, Canada eh!
gg70
I have one of Gary's 426 hemis (MP crate) in my cuda up here in Alberta CA and it is running just fine. Its making lots of power. I'm using the original v8 k member with Schumacher mounts. All fit well with zero installation problems. I haven't picked up the shaker kit for it yet so don't know if I'll have any height issues.
1970 EV2 Barracuda Hardtop
1970 FE5 Barracuda Gran Coupe Convertible
1969 B5 Dart GTS 383
1968 TT1 Barracuda Convertible
1997 Ram SS/T
2008 3500 Ram Diesel
Re: Hemi with a shaker... [Re: 70Cudha] #1690672
12/18/14 06:58 AM
12/18/14 06:58 AM
Good to know. Maybe I'll get that lucky????
