Page 1 of 3 1 2 3
What causes front tires to turn outwards during wheelie #1689622
10/23/14 02:39 PM
10/23/14 02:39 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
I noticed from a vid that on my truck, the tires will turn outwards at the launch. It goes straight though, but I am not comfortable with this.
I did lower the truck by just using adjustable coil overs and it is aligned. I am wondering if I need to get drop spindles to keep the geometry of the suspension correct?
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #1689623
10/23/14 02:57 PM
10/23/14 02:57 PM
AndyF Online content
AndyF  Online Content
That is called bump steer. It can be a big problem on a drag car since the car might head a different direction when it comes down from a wheelie than you're expecting.
Re: What causes front tires to turn outwards during wheelie [Re: AndyF] #1689624
10/23/14 03:04 PM
10/23/14 03:04 PM
Renton Washington
Triple Threat Offline
Renton Washington
Yep, Bumpsteer which is very common.
http://www.moparts.org/Tech/Archive/susp/27.html
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What causes front tires to turn outwards during wheelie [Re: AndyF] #1689625
10/23/14 03:06 PM
10/23/14 03:06 PM
Guitar Jones Offline
Basically an over simplified explanation is that the arc of the control arms/knuckle is not the same as the arc the tie rods swing in.
The pivot points of the control arms need to be the same as the inner tie rod pivot point. Much easier to do with a strut car since you only have the lower control arms to deal with.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: What causes front tires to turn outwards during wheelie [Re: Guitar Jones] #1689626
10/23/14 03:24 PM
10/23/14 03:24 PM
Houston, Texas
Houston, Texas
Thanks Guys! let me rephrase...I knew it was bump steer, but I wasn't 100% sure what caused it. I see now from the replies.
Do you think going to a drop spindle would put the geometry of the suspension in better shape and eliminate or drastically reduce bump steer?
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #1689627
10/23/14 03:28 PM
10/23/14 03:28 PM
No, the issue is the difference in pivot points of the control arms and inner tie rods. Drop spindles aren't going to change that.
Re: What causes front tires to turn outwards during wheelie [Re: Guitar Jones] #1689628
10/23/14 04:30 PM
10/23/14 04:30 PM
Houston, Texas
Houston, Texas
Thanks! I will check it out. I may have some questions on what to do to correct this.
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #1689629
10/23/14 04:33 PM
10/23/14 04:33 PM
On a stock chassis vehicle there isn't a lot you can do to correct this without fab work. At this point unless it is causing handling problems the effort isn't worth it.
Re: What causes front tires to turn outwards during wheelie [Re: Guitar Jones] #1689630
10/24/14 12:35 AM
10/24/14 12:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I remember my brothers tube frame Cuda with rack and pinion had bumb steer pretty bad. They ended up adding exstensions on the tie rod ends to get them right and correct it. On some with rack & pinion you can shim the rack also to help correct it. Ron
Re: What causes front tires to turn outwards during wheelie [Re: 383man] #1689631
10/24/14 01:16 AM
10/24/14 01:16 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Look for info on bump steer correction on right turn - left turn sporty car sites. Sometimes you will find that correcting bump steer is as simple as heating and bending the steering arms up or down a half inch or so.
Re: What causes front tires to turn outwards during wheelie [Re: John Brown] #1689632
10/24/14 11:22 AM
10/24/14 11:22 AM
Houston, Texas
Houston, Texas
Thanks guys. I may post some pics to get suggestions this weekend!
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #1689633
10/24/14 12:00 PM
10/24/14 12:00 PM
gregsdart Offline
gregsdart  Offline
You could plot out the bump steer and see if a travel limiter will keep it out of the worst of it. I would make sure that the limiter attach to a point that will keep everything in compression (balljoints) and try different amounts to see what you can get away with. Use some form of rubber stop also so it doesn't upset the chassis when it hits the limit. I use old shock biskets from bayonet type shocks.
Re: What causes front tires to turn outwards during wheelie [Re: TheOtherDodge] #1689634
10/24/14 01:58 PM
10/24/14 01:58 PM
Locomotion Offline
Locomotion  Offline
Front tires & suspension do a lot of things during a wheelstand that you need to be aware of. This may be an extreme example, but still one to consider when it comes to your particular vehicle.
Challenger wheelstand - front suspension issues
Re: What causes front tires to turn outwards during wheelie [Re: Locomotion] #1689635
10/24/14 02:19 PM
10/24/14 02:19 PM
Houston, Texas
Houston, Texas
Dang, that is ugly!
Re: What causes front tires to turn outwards during wheelie [Re: Locomotion] #1689636
10/24/14 04:12 PM
10/24/14 04:12 PM
South Bend
South Bend
That's not bump steer. If you could see both wheels you would see that both tires were going in the same direction. That problem likely would be solved with a steering stabilizer, but you know how weight conscious racers are. That type of wobble occurs most often on light weight front ends with low friction steering components.
Re: What causes front tires to turn outwards during wheelie [Re: John Brown] #1689637
10/24/14 05:04 PM
10/24/14 05:04 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
if the wheels are moving in and out during travel its bumpsteer.The wheels can do the same thing,they can be one towed in and the other toed out or any combo.You can do alot to fix the problem by reading the old mopar chassis book.You can shim the steering box,you can relocate the idler arm by grinding the mount and welding a washer to the frame to hold the idler arm.I got my car down to a 1\8" tow-in.Its easy to fix,but hard to understand.I read the chapter on bumpsteer several times before i understood it.You can fix it good luck!
Re: What causes front tires to turn outwards during wheelie [Re: John Brown] #1689638
10/24/14 05:10 PM
10/24/14 05:10 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Thats my car in 2010 , It does have heim joints rather than bushes on strut rods and uca's but the idler arm bush was pretty much toast there. Front suspension is doing stuff it was never really designed for, probably due to loads of upward suspension travel. It's better after the new idler arm and a set up but still does it to some extent. It also eats upper control arm ball joints. Been told to change to struts if i want to eliminate it entirely
Where would i get a steering stabiliser? is this like a steering damper on motorcycles? Weight is not really an issue on this
Re: What causes front tires to turn outwards during wheelie [Re: Tig] #1689639
10/24/14 05:41 PM
10/24/14 05:41 PM
South Bend
South Bend
Moog and most other aftermarket suspension companys offer steering stabilizers. They are factory installed on VW's, Monte Carlos and Jeeps because they need them to keep from having the front end shake just like your car, and you know manufacturers wouldn't put them on if they had any other way of doing it cheaper. Years ago (45) I put stabilizers on a 48 Anglia and 55 Chevy straight axle drag car because the front end shook like that. Only other way to make it stop was slam on the brakes, and that wasn't a logical choice on a race car. If you don't find one specifically made that fits your front suspension, it's pretty easy to adapt something made for some oem application. After all, a steering stabilizer is much the same as a shock absorber mounted sideways.
Re: What causes front tires to turn outwards during wheelie [Re: John Brown] #1689640
10/24/14 06:01 PM
10/24/14 06:01 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Thanks John and apologies to the OP for the hijack
Re: What causes front tires to turn outwards during wheelie [Re: 540DUSTER] #1689641
10/24/14 07:21 PM
10/24/14 07:21 PM
OP has a Dakota with I'm sure a rack and pinion. The way those racks are mounted, bushing with a through bolt, it's going to be a lot of work to change that. Also he is not going to be able to change the length of the rack between the inner tie rods and that is probably where most of the problem is.
Just to be clear to the OP you are asking about the wheels towing out and not the camber change where it looks like it's going negative camber correct?
Page 1 of 3 1 2 3
