2x4 Hemi intake #1688157
10/20/14 10:46 AM
10/20/14 10:46 AM
Toronto,Canada
W
wkeggenhoff Offline OP
W
Toronto,Canada
Looking for intake (2x4) for a 528 Hemi street driven, 5spd Charger
What is everyoine using ? Choices are Stage V, Indy or MP 2x4 from what I can research
Currently have a singe MP low rise intake as I had to take the singe 4 (Edelbrock/Ray Barton) off due to hood clearance issues.
Want to run Edelbrock 750 cfm carbs as well.
Will be upgrading to a solid roller or a flat tappet cam as well in the low 600" lift range
Does everyone use progressive linkage ?
Am I dreaming if I think this will put me in 750
hp range?
Motor stock is suppose to be 610-650 hp
Thanks Werner
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: 2x4 Hemi intake [Re: wkeggenhoff] #1688158
10/20/14 11:42 AM
10/20/14 11:42 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Why do you post this in the race only section?
Re: 2x4 Hemi intake [Re: Dragula] #1688159
10/20/14 12:47 PM
10/20/14 12:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Engine Tech forum. I would run the Stage V intake with dual AVS carbs, that seems to work for everyone that uses them. I prefer progressive linkage. The AFB carbs don`t have air doors that are easily tuneable.
Sheldon
Re: 2x4 Hemi intake [Re: RUNCHARGER] #1688160
10/20/14 12:53 PM
10/20/14 12:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sheldon
Sheldo the sesign of the stage 5 intake really needs to have 1 to 1 linkage to feed the engine properly , it's 2 single plane plenum with a small pass tube between them , trying to run the engine on 1 carb at low speed wouldn't be very efficent .
But I'll add another vote for the stage 5 unless it's an all out race motor.
Re: 2x4 Hemi intake [Re: wkeggenhoff] #1688161
10/20/14 01:02 PM
10/20/14 01:02 PM
central il.
second 70 Offline
second 70  Offline
central il.
I run a stage v on mine. Carbs must be set at 1 to 1 on that manifold. The other choice is the Barton marine manifold. It is a dual plane you can run progressive linkage on and even holley carbs if you want.
I have a new in the box marine manifold that I would sell. PM me if you're interested. Mike
Re: 2x4 Hemi intake [Re: second 70] #1688162
10/20/14 01:07 PM
10/20/14 01:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the marine manifold a dual plane ?
Re: 2x4 Hemi intake [Re: JohnRR] #1688163
10/20/14 01:14 PM
10/20/14 01:14 PM
central il.
second 70 Offline
second 70  Offline
central il.
Yes It also accepts the larger carbs.
Re: 2x4 Hemi intake [Re: wkeggenhoff] #1688164
10/20/14 02:22 PM
10/20/14 02:22 PM
I've used the stock Mopar OEM manifolds on many hemi strokers with Eddy 600 and the larger 750 CFM carbs. by drilling the AFB pattern into the Eddy bases The Eddy smog carbs with the electric chokes don't make as much power on the dyno as the Hi Po with mechanical chokes do If you deicde to use the 750 CFM carbs, either sets, you will need to enlarge the front holes on the intake also I used the Eddy progressive linkage on them also One to one linkage works great on them on the street also Your choice, let us know what you do
Re: 2x4 Hemi intake [Re: Cab_Burge] #1688165
10/20/14 06:07 PM
10/20/14 06:07 PM
Toronto,Canada
W
W
Toronto,Canada
Thanks for all the info guys. Think it will be Stage V. Will probably get package from Tim @ FHO for this mod. He sell air filter to fit this as well. Just need to find a good cam.
Ray Barton sell a flat tappet mech cam package(cam, springs,retainers lifters etc for $1000) a supposed 100hp increase
Tim at FHO says he would use a mech roller in the 630" range for a streetable hp increase.
Anyoone have any feedback on these 2 choices
I posted here because it said it was race only and Engine Tech
Re: 2x4 Hemi intake [Re: wkeggenhoff] #1688166
10/20/14 09:47 PM
10/20/14 09:47 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
You posted in the right place Name been changed a while back to add engine tech.Did't use to say that.
Re: 2x4 Hemi intake [Re: second 70] #1688167
10/21/14 12:02 AM
10/21/14 12:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Unlike the stock intake ... trade ya ...
Re: 2x4 Hemi intake [Re: wkeggenhoff] #1688168
10/21/14 10:29 AM
10/21/14 10:29 AM
an8sec70cuda Offline
w/ pretty much what everyone has said so far. The Stage V manifold w/ a pair of 750 carbs at 1:1 would be my choice.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 2x4 Hemi intake [Re: JohnRR] #1688169
10/21/14 12:04 PM
10/21/14 12:04 PM
central il.
second 70 Offline
second 70  Offline
central il.
Thanks for the offer John but for now I think I'll keep it in case I try it to increase low end torque on my 3800# cuda. The carb spacing is the same as the stage V manifold so the shaker base I have will work with either manifold. Mike
