Cost to go roller #1687120
10/18/14 12:25 AM
10/18/14 12:25 AM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
Just what it says,I have a solid flat tappet now,what would the cost be to go to a roller and is it worth it on a street/strip car,put about 1500 to 2000 miles a year.
THANKS EDDIE B
Re: Cost to go roller [Re: EDDIEB] #1687121
10/18/14 12:30 AM
10/18/14 12:30 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Cam, cam button, oil pump drive, rollers, pushrods ... Roughly $ 1600.
You can cheap out on the lifter or you can go nuts. I quoted good Cranes.
Re: Cost to go roller [Re: Stanton] #1687122
10/18/14 01:30 AM
10/18/14 01:30 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If you don't get SUCKED IN with the nay sayers saying solid lifters won't hold up and are more trouble than they are worth there are a lot of VERY good solid lift cams available.
Breaking in another solid lift cam tomorrow morning in a new build and Brad Penn oil is in the oil pan and for now the inner springs are sitting on my work bench.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cost to go roller [Re: pittsburghracer] #1687123
10/18/14 04:37 AM
10/18/14 04:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I stayed with a solid flat tappet for a few reasons and price was one of them. I put a good bit of miles on my 63 street/strip car as I would guess I put well over 3000 miles on it this year. Its nice not having to run the spring pressures of a good solid roller but many guys are doing it. To me you just have to weigh it all out. Is it worth the money to you to pick up a little et ?? But how much et will it get you ? Are you at a point that you really want the et gain ? Whats your combo and how does it run now ? Ron
Re: Cost to go roller [Re: 383man] #1687124
10/18/14 05:00 AM
10/18/14 05:00 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it's definitely worth it but it is costly.
cam around $500
springs/keepers etc
lifters
push rods
rockers could get real expensive depending how much spring pressure you go with
oil pump drive
good parts somewhere around $3K
Re: Cost to go roller [Re: Quicktree] #1687125
10/18/14 05:39 AM
10/18/14 05:39 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
whatever the cost, it's worth it. went from a flat tappet cam that was 284@050 650 lift to a roller that was 272@050 660 lift & gained half a second & an engine that had manners. sure parts maintenance is more but the midrange power really gets the adrenilan going.
Re: Cost to go roller [Re: rebel] #1687126
10/18/14 10:05 AM
10/18/14 10:05 AM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
My combo is
471
12 to 1
Indy SR's MW ported by D.Porter
Indy single plane with 850
Comp solid flat tappet .615 270ish@.50 spec'd by Porter
Car is 69 roadrunner street /strip,more street, ran a best last week 10.40@129
Just kicking around winter ideas LOL
Re: Cost to go roller [Re: EDDIEB] #1687127
10/18/14 10:52 AM
10/18/14 10:52 AM
IN
ahy Offline
ahy  Offline
IN
Since you are putting ~ 2k/year with street miles, I'd guess you want a reliable low maintenance setup. A roller with mild ramps and moderate spring requirements probably won't give you much more performance vs what you have now. Push it up to an aggressive roller and maintenance/reliability may become an issue.
Re: Cost to go roller [Re: EDDIEB] #1687128
10/18/14 10:56 AM
10/18/14 10:56 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I would ask the guy who ported your heads.
Re: Cost to go roller [Re: 67_Satellite] #1687129
10/18/14 11:49 AM
10/18/14 11:49 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
X2
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Cost to go roller [Re: EDDIEB] #1687130
10/18/14 01:27 PM
10/18/14 01:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My combo is
471
12 to 1
Comp solid flat tappet .615 [Email]270ish@.50[/Email] spec'd by Porter
Car is 69 roadrunner street /strip,more street, ran a best last week [Email]10.40@129[/Email]
You need a dominator on that combo........... FWIW, I went from an Isky .590-.605 solid and fully ported 906`s to a .680-.660 solid roller and ported rpm heads and went from 10.48 to 9.79 and I`m not done finessing it yet..........
Re: Cost to go roller [Re: Thumperdart] #1687131
10/18/14 02:28 PM
10/18/14 02:28 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
Just curious has anyone tried/experimented w/the Hughes camshafts?? Have been eyeing one, but just can't pull the plug. Don't want to/can't afford to upgrade to a roller right now. Just curious, Ken
Re: Cost to go roller [Re: Quicktree] #1687132
10/18/14 04:41 PM
10/18/14 04:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
3K is extreme. That would be with the absolute best of everything which would be overkill in anything other than an all-out race motor. I'm in around $1600. with a Lunati Voodoo roller, Crane lifters, Smith's pushrods, MP bronze gear, K Motion springs, Comp retainers and locks.
Re: Cost to go roller [Re: Stanton] #1687133
10/18/14 04:48 PM
10/18/14 04:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
where's your rockers? they can be almost that by themselves
Re: Cost to go roller [Re: Quicktree] #1687134
10/18/14 05:42 PM
10/18/14 05:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
OP has possibly already made that leap with a solid flat tappet. Besides, a roller cam doesn't necessarily need roller rockers.
FWIW mine are Harland Sharp
I can understand you trying to defend your exorbitant estimate but really, you don't need to spend 3K to go with a roller cam.
Re: Cost to go roller [Re: Stanton] #1687135
10/18/14 05:54 PM
10/18/14 05:54 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
And you don't want to skimp ........ANYWHERE.
If you do not have quality rockers , add them to the bill.
FWIW , I had exactly three choices with my W-9 and I think two are made by the same company.
T&D here.
Harlands are a great choice too , but they start around six bills.
Re: Cost to go roller [Re: tubtar] #1687136
10/18/14 06:34 PM
10/18/14 06:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
T&D here.
exactly especially if you are wanting to run a high pressure cam. cheap stuff wont cut it. my street roller i can get away with indy rockers increase pressure and they will break
Re: Cost to go roller [Re: Quicktree] #1687137
10/18/14 09:56 PM
10/18/14 09:56 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
I already have Harland Sharp roller rockers,I might look into a bigger flat tappet,but would like a roller,but is it worth the money for little gain
Re: Cost to go roller [Re: EDDIEB] #1687138
10/18/14 10:03 PM
10/18/14 10:03 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I reckon a dominator would pick the motor up a bit, that's a small carb for your setup.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Cost to go roller [Re: deaks] #1687139
10/18/14 10:34 PM
10/18/14 10:34 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
I ran a pro systems 1000 and the 850 from chuck nuyton ran a little faster and drove on the street better, Tried a dommy and it slowed it down
