Re: Cost to go roller
[Re: Stanton]
#1687122
10/18/14 01:30 AM
10/18/14 01:30 AM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you don't get SUCKED IN with the nay sayers saying solid lifters won't hold up and are more trouble than they are worth there are a lot of VERY good solid lift cams available. ![](/ubbthreads/images/graemlins/Twocents.gif) Breaking in another solid lift cam tomorrow morning in a new build and Brad Penn oil is in the oil pan and for now the inner springs are sitting on my work bench.
[Re: pittsburghracer]
#1687123
10/18/14 04:37 AM
10/18/14 04:37 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I stayed with a solid flat tappet for a few reasons and price was one of them. I put a good bit of miles on my 63 street/strip car as I would guess I put well over 3000 miles on it this year. Its nice not having to run the spring pressures of a good solid roller but many guys are doing it. To me you just have to weigh it all out. Is it worth the money to you to pick up a little et ?? But how much et will it get you ? Are you at a point that you really want the et gain ? Whats your combo and how does it run now ? Ron
[Re: Quicktree]
#1687125
10/18/14 05:39 AM
10/18/14 05:39 AM
Posts: 4,647 aotearoa
rebel
aotearoa
whatever the cost, it's worth it. went from a flat tappet cam that was 284@050 650 lift to a roller that was 272@050 660 lift & gained half a second & an engine that had manners. sure parts maintenance is more but the midrange power really gets the adrenilan going. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: rebel]
#1687126
10/18/14 10:05 AM
10/18/14 10:05 AM
Posts: 184 Bad Axe,MI
EDDIEB
Bad Axe,MI
My combo is 471 12 to 1 Indy SR's MW ported by D.Porter Indy single plane with 850 Comp solid flat tappet .615 270ish@.50 spec'd by Porter Car is 69 roadrunner street /strip,more street, ran a best last week 10.40@129Just kicking around winter ideas LOL
[Re: Quicktree]
#1687132
10/18/14 04:41 PM
10/18/14 04:41 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
good parts somewhere around $3K
3K is extreme. That would be with the absolute best of everything which would be overkill in anything other than an all-out race motor. I'm in around $1600. with a Lunati Voodoo roller, Crane lifters, Smith's pushrods, MP bronze gear, K Motion springs, Comp retainers and locks.
[Re: Stanton]
#1687133
10/18/14 04:48 PM
10/18/14 04:48 PM
Quicktree
where's your rockers? they can be almost that by themselves
[Re: Stanton]
#1687135
10/18/14 05:54 PM
10/18/14 05:54 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
And you don't want to skimp ........ANYWHERE. If you do not have quality rockers , add them to the bill. FWIW , I had exactly three choices with my W-9 and I think two are made by the same company. T&D here. Harlands are a great choice too , but they start around six bills.
[Re: tubtar]
#1687136
10/18/14 06:34 PM
10/18/14 06:34 PM
Quicktree
exactly especially if you are wanting to run a high pressure cam. cheap stuff wont cut it. my street roller i can get away with indy rockers increase pressure and they will break
[Re: EDDIEB]
#1687138
10/18/14 10:03 PM
10/18/14 10:03 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I reckon a dominator would pick the motor up a bit, that's a small carb for your setup. Mick ![](/ubbthreads/images/graemlins/thumbs.gif)
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
