Torque numbers per CID? #1679503
09/28/14 08:33 PM
09/28/14 08:33 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Is this an accurate statement for torque values per CID?
Normally aspirated on pump gas,,, real numbers,,
1.2 is a pretty good number for a decent engine
1.25 is very good
1.3 is outstanding
Race engines,,,
1.4 & above gets very very expensive,,,,
1.6+ is in the Pro stock area & expensive
Thx Matt
Re: Torque numbers per CID? [Re: MattW] #1679504
09/28/14 08:40 PM
09/28/14 08:40 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
My pump gas motor is 1.27tq/CID. I never looked at TQ/cube or HP/cube. I just get try to get a good package together that I will be happy with.
Re: Torque numbers per CID? [Re: Bigcube] #1679505
09/28/14 09:36 PM
09/28/14 09:36 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
It will be I interesting to see what everyone says.... My pump gas street/strip 440 is at 1.3tq/cube.....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Torque numbers per CID? [Re: QTR MILR] #1679506
09/28/14 09:49 PM
09/28/14 09:49 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
Pump has small block 387ci 1.39 tq per cid
Re: Torque numbers per CID? [Re: kotacars] #1679507
09/28/14 10:05 PM
09/28/14 10:05 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My pumpgas 605 makes 1.35, runs on 89.5 octane.Dave
Re: Torque numbers per CID? [Re: quickd100] #1679508
09/30/14 09:27 PM
09/30/14 09:27 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Would anyone know if by going from Sunoco 98 to 94 would result in a loss of torque?
Re: Torque numbers per CID? [Re: MattW] #1679509
09/30/14 10:20 PM
09/30/14 10:20 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
That would depend on the combo.... too many variables to say.
Scott
Re: Torque numbers per CID? [Re: MattW] #1679510
09/30/14 11:16 PM
09/30/14 11:16 PM
Washington
madscientist Offline
Washington
Seems to me guys are too worried about torque. I suppose if you are running a 2 speed torque is more important that if you are using a 3 speed. If you have 4 or 5 gears, total torque and the shape of the curve are less important than if you have 2 or 3 gears.
If I know that my minimum engine speed is ( for example) is 4500 rpm (stall speed or on the chip) I can see no reason to care about torque (or horsepower) at a lower speed (say 3000 rpm).
All that said, your numbers posted are a fairly loose rule of thumb.
Re: Torque numbers per CID? [Re: madscientist] #1679511
09/30/14 11:22 PM
09/30/14 11:22 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
What's the consensus about having your stall speed well beyond your peak torque rpm?
(turbo application)
Re: Torque numbers per CID? [Re: MattW] #1679512
10/02/14 07:27 PM
10/02/14 07:27 PM
N. Of Detroit, Mi
733404spdCuda Offline
N. Of Detroit, Mi
378Ci 340 Pump Gas 9.5 compression - 490 tq 1.29 - 520hp 1.37
Nice street motor
Re: Torque numbers per CID? [Re: Duner] #1679513
10/02/14 11:50 PM
10/02/14 11:50 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
(turbo application)
It means you're turbo motor makes a ton on you're like mine, but if you tighten it up you can't spool... Lol
Re: Torque numbers per CID? [Re: MattW] #1679514
10/03/14 10:09 AM
10/03/14 10:09 AM
BPE Offline
BPE  Offline
Rod
Re: Torque numbers per CID? [Re: BPE] #1679515
10/03/14 12:18 PM
10/03/14 12:18 PM
P
Porter67 Offline
Porter67  Offline
P
I know why the above poster gave the .
Ive seen numbers near the 1.4/1.5 mark on small block stroker builds and there is where at times if the chassis isn't set up for it, its a hard to hook situation.
If only the small blocks could get past the 4.100 bore max (yes some get a hair more) and get over squared.
Re: Torque numbers per CID? [Re: Porter67] #1679516
10/03/14 12:54 PM
10/03/14 12:54 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Numbers from around year 2K, 451 1.36, 528 1.33. Pump gas wedges
Plynouth VIP '67 TT IC EFI
Re: Torque numbers per CID? [Re: MattW] #1679517
10/03/14 02:27 PM
10/03/14 02:27 PM
I've built and dyno tested a bunch of different Mopar motors, race and street, N/A and roots blown with similar combinations. I have noticed that the compression ratio can and will make the difference when the motor makes more torque than HP on the N/A motors It seems like on the pump gas big blocks with aluminum heads around 10.25 to 1 to 10.75 to 1 the motor will go from more torque than HP to more HP than torque On the N/A race motors I've noticed that when peak HP occurs at a higher RPM the peak torque follows it also
Re: Torque numbers per CID? [Re: Cab_Burge] #1679518
10/03/14 09:56 PM
10/03/14 09:56 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mine was 1.35 per CI. It is 10.9 to 1 pump gas small block.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Torque numbers per CID? [Re: D-50] #1679519
10/04/14 10:13 AM
10/04/14 10:13 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Pump gas N/A 11:1 655ci @ 950ft/lb = 1.45, I'm pretty sure were gonna have to work on the chassis set up next season
