Torque numbers per CID?
#1679503
09/28/14 08:33 PM
09/28/14 08:33 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Is this an accurate statement for torque values per CID?
Normally aspirated on pump gas,,, real numbers,, 1.2 is a pretty good number for a decent engine 1.25 is very good 1.3 is outstanding Race engines,,, 1.4 & above gets very very expensive,,,, 1.6+ is in the Pro stock area & expensive Thx Matt
Re: Torque numbers per CID?
[Re: MattW]
#1679504
09/28/14 08:40 PM
09/28/14 08:40 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
My pump gas motor is 1.27tq/CID. I never looked at TQ/cube or HP/cube. I just get try to get a good package together that I will be happy with.
[Re: Bigcube]
#1679505
09/28/14 09:36 PM
09/28/14 09:36 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
It will be I interesting to see what everyone says.... My pump gas street/strip 440 is at 1.3tq/cube.....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: MattW]
#1679510
09/30/14 11:16 PM
09/30/14 11:16 PM
Posts: 4,457 Washington
madscientist
Washington
Seems to me guys are too worried about torque. I suppose if you are running a 2 speed torque is more important that if you are using a 3 speed. If you have 4 or 5 gears, total torque and the shape of the curve are less important than if you have 2 or 3 gears.
If I know that my minimum engine speed is ( for example) is 4500 rpm (stall speed or on the chip) I can see no reason to care about torque (or horsepower) at a lower speed (say 3000 rpm).
All that said, your numbers posted are a fairly loose rule of thumb.
[Re: Duner]
#1679513
10/02/14 11:50 PM
10/02/14 11:50 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
What's the consensus about having your stall speed well beyond your peak torque rpm? (turbo application)
It means you're turbo motor makes a ton on you're like mine, but if you tighten it up you can't spool... Lol
[Re: BPE]
#1679515
10/03/14 12:18 PM
10/03/14 12:18 PM
Porter67
I know why the above poster gave the ![](/ubbthreads/images/graemlins/thumbs.gif) . Ive seen numbers near the 1.4/1.5 mark on small block stroker builds and there is where at times if the chassis isn't set up for it, its a hard to hook situation. If only the small blocks could get past the 4.100 bore max (yes some get a hair more) and get over squared.
[Re: Porter67]
#1679516
10/03/14 12:54 PM
10/03/14 12:54 PM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
Numbers from around year 2K, 451 1.36, 528 1.33. Pump gas wedges
Plynouth VIP '67 TT IC EFI
[Re: Cab_Burge]
#1679518
10/03/14 09:56 PM
10/03/14 09:56 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine was 1.35 per CI. It is 10.9 to 1 pump gas small block.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1679519
10/04/14 10:13 AM
10/04/14 10:13 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Pump gas N/A 11:1 655ci @ 950ft/lb = 1.45, I'm pretty sure were gonna have to work on the chassis set up next season ![](/ubbthreads/images/graemlins/grin.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
