Big Block Dual Feed Line
#1674206
09/19/14 02:02 PM
09/19/14 02:02 PM
Posts: 457 Hightstown, NJ
njdevil2
Hightstown, NJ
Hey…..need some real help here. Jegs has no clue and I can’t wait on hold with Holley for hours on end….. 1970 roadrunner 383. DP4B intake. I have a 670 Street Avenger carb and the dual feed line clashes with the distributor. Is there a dual feed line or something that I get to make this work? I thought there was something available but I can’t find nor remember what it was. Any suggestions? Thanks!!
1970 road runner Convertible 1 of 179
Re: Big Block Dual Feed Line
[Re: njdevil2]
#1674207
09/19/14 02:13 PM
09/19/14 02:13 PM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
You either have to bend the end or do like I did and make your own out of brake line and a t block I fit mine real closse to the valve cover and under the dist following the block down to fuel pump
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: Challenger 1]
#1674219
09/20/14 11:19 AM
09/20/14 11:19 AM
njdevil2
Hightstown, NJ
Looks like FinLines is still there.....checking out the web site right now. Looks like there are some kits and parts/pieces. My brother in law is checking on something so if he doesn't come up with ideas local, this is most likely the way to go.
