Big Block Dual Feed Line #1674206
09/19/14 02:02 PM
09/19/14 02:02 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
Hey…..need some real help here.
Jegs has no clue and I can’t wait on hold with Holley for hours on end…..
1970 roadrunner 383. DP4B intake. I have a 670 Street Avenger carb and the
dual feed line clashes with the distributor. Is there a dual feed line or something
that I get to make this work? I thought there was something available but
I can’t find nor remember what it was. Any suggestions? Thanks!!
1970 road runner Convertible
1 of 179
Re: Big Block Dual Feed Line [Re: njdevil2] #1674207
09/19/14 02:13 PM
09/19/14 02:13 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
You either have to bend the end or do like I did and make your own out of brake line and a t block
I fit mine real closse to the valve cover and under the dist following the block down to fuel pump
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Big Block Dual Feed Line [Re: toplescuda] #1674208
09/19/14 02:54 PM
09/19/14 02:54 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I turned mine around backwards and ran the fuel line up on the RH inner fender well where it connects to the filter housing and then down to the fuel pump.
A friend of mine has one on a 440 that has a braided line in the center which lets you bend the front down a little to clear the dizzy. Both ideas work well.
...FAFO...
Re: Big Block Dual Feed Line [Re: skicker] #1674209
09/19/14 05:15 PM
09/19/14 05:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought this dual feed at a local speed shop and it works perfect. Gets the fuel line away from the dist and solved the problem. Ron
Re: Big Block Dual Feed Line [Re: njdevil2] #1674210
09/19/14 05:29 PM
09/19/14 05:29 PM
scratchnfotraction Offline
could do it like a ferd cobra jet holley 4-v duel feed line.
feed it from driver side. or fab up your own with some brass JIC fittings and some alum line/tube nuts with an-6 carb bowl fittings.
Re: Big Block Dual Feed Line [Re: scratchnfotraction] #1674211
09/19/14 05:34 PM
09/19/14 05:34 PM
build your own with alum line tube nuts tee fitting.
put the tee in the center and run fuel line by VC rail then 90* over to tee fitting.
with some thought you can come up with some nice looking lines that work.
Re: Big Block Dual Feed Line [Re: scratchnfotraction] #1674212
09/19/14 08:29 PM
09/19/14 08:29 PM
could always plumb and solder a set of ridged copper lines for it.
Re: Big Block Dual Feed Line [Re: scratchnfotraction] #1674213
09/19/14 10:51 PM
09/19/14 10:51 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Turn it around and feed from the rear..
Re: Big Block Dual Feed Line [Re: njdevil2] #1674214
09/19/14 11:21 PM
09/19/14 11:21 PM
tucson az
frank Offline
frank  Offline
tucson az
This is what I have on my 670 SA. Metal line and hardware store brass blocks. Just bend some tube and flair.
Re: Big Block Dual Feed Line [Re: njdevil2] #1674215
09/19/14 11:22 PM
09/19/14 11:22 PM
tucson az
frank Offline
frank  Offline
tucson az
with the feed line attached
Re: Big Block Dual Feed Line [Re: frank] #1674216
09/20/14 12:34 AM
09/20/14 12:34 AM
Atlanta,Ga.
rcgtx Offline
rcgtx  Offline
Atlanta,Ga.
There used to be a company called Fine Lines. They made factory style dual feed fuel lines. I had one on my 440 challenger. It fit great.
Re: Big Block Dual Feed Line [Re: rcgtx] #1674217
09/20/14 10:38 AM
09/20/14 10:38 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I used two of his sets.
I take it he's no longer around?
Re: Big Block Dual Feed Line [Re: Commando1] #1674218
09/20/14 10:51 AM
09/20/14 10:51 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I got a 3 piece set of fuel lines from them in about 24 hours about 2 years ago. They fit great too BTW.
Re: Big Block Dual Feed Line [Re: Challenger 1] #1674219
09/20/14 11:19 AM
09/20/14 11:19 AM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
Looks like FinLines is still there.....checking out the web site right now. Looks like there are some kits and parts/pieces. My brother in law is checking on something so if he doesn't come up with ideas local, this is most likely the way to go.
1 of 179
Re: Big Block Dual Feed Line [Re: njdevil2] #1674220
09/20/14 03:34 PM
09/20/14 03:34 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Greg from Fabulous Fabrications made mine long ago. IIRC he still makes them.
303-666-9882 or sixpackbee@AOL.com
1MYTGTX
Re: Big Block Dual Feed Line [Re: 1MYTGTX] #1674221
09/20/14 04:11 PM
09/20/14 04:11 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Heres mine. I used a Holley fuel pressure limiter as the splitter because I have an electric pump and If left unchecked provided to much fuel pressure for my carbs. [image][/image]
Re: Big Block Dual Feed Line [Re: Cudajon] #1674222
09/20/14 08:25 PM
09/20/14 08:25 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Got mine from Greg at Fabulous Fabrications years ago too. Fuel pump to carb set fit great.
