A727 Torque convertor lockup #1665549
08/30/14 04:07 PM
08/30/14 04:07 PM
70GTXer Offline OP
70GTXer  Offline OP
I have a 70 440 with 727 and 3.23 gears. have heard of a Aftermarket torque convertor that acts almost like a 4th gear at highway speeds but is not an overdrive or lockup unit. has anyone heard of this or used one?
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665550
08/30/14 08:05 PM
08/30/14 08:05 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
?? the converter ?? I think you mean the trans.
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665551
08/30/14 09:23 PM
08/30/14 09:23 PM
dogdays Offline
dogdays  Offline
Nope.
"I have heard" are the three most dangerous words.
A stock converter is probably closest to a lockup converter that you'd find in a 727 and nobody ever thought those had a fourth gear.
R.
Re: A727 Torque convertor lockup [Re: dogdays] #1665552
08/30/14 11:34 PM
08/30/14 11:34 PM
70GTXer Offline OP
70GTXer  Offline OP
That is what I have in there now, so you are saying I should keep what I have and it will help to reduce rpm's at highway speeds?
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665553
08/30/14 11:44 PM
08/30/14 11:44 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
when you say stock converter what 'stall' are you considering stock? if you are referring to your gear ratio a 3.23 is not really a cruising ratio but it is far from a killer either. what car do you have, and is it stock as far as you know? are you trying to reduce your engine speed when on the highway?
Re: A727 Torque convertor lockup [Re: mikemee1331] #1665554
08/31/14 12:12 AM
08/31/14 12:12 AM
70GTXer Offline OP
70GTXer  Offline OP
I am using a stock trans with only a shift kit for upgrades. I want to reduce engine rpm to put less strain on engine at highway speeds. 440 has 11.5 to 1 with 906 heads, 509 purple and hooker 3" out the back.
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665555
08/31/14 12:24 AM
08/31/14 12:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With 3.23 gears you shouldn't be running very high RPM. What size are your rear tires?
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665556
08/31/14 12:27 AM
08/31/14 12:27 AM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Then you need to add an overdrive of some sort, or change the rear end gearing. No big secrets here.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: A727 Torque convertor lockup [Re: zzyzxpat] #1665557
08/31/14 01:07 AM
08/31/14 01:07 AM
70GTXer Offline OP
70GTXer  Offline OP
yes zzpat the secret is the convertor I am looking for!! had you read my original post I do not want to install an overdrive unit but have heard about a convertor that acts as a lockup or overdrive to reduce rpm and increase mileage.
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665558
08/31/14 10:45 AM
08/31/14 10:45 AM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
BM used to make a convertor with a gearset in it but now I can't recall what they called it. Maybe John K does?
Tom
Re: A727 Torque convertor lockup [Re: Tom Hand] #1665559
08/31/14 05:15 PM
08/31/14 05:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The B&M Superdrive Converter from the early eighties had an internal overdrive, it didn't stay around too long so I imagine it wasn't a great success.
Re: A727 Torque convertor lockup [Re: John_Kunkel] #1665560
08/31/14 06:16 PM
08/31/14 06:16 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
http://papers.sae.org/820742/
"A torque converter has been developed for aftermarket use in older, heavier, large engined cars and light trucks to improve fuel economy, particularly at highway speeds. This torque converter includes an output coupled overdrive and torque split within the converter itself. This torque converter has shown gains in highway fuel economy of 9 to 21 percent. The converter changes that give the improved fuel economy result in a lower acceleration level for the vehicle"
Re: A727 Torque convertor lockup [Re: Dan Halen] #1665561
08/31/14 06:43 PM
08/31/14 06:43 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
John and StreetVanDan!
This is it, thank you. I googled for hours but found nothing as I was using the wrong name.
Tom
Re: A727 Torque convertor lockup [Re: Tom Hand] #1665562
08/31/14 06:56 PM
08/31/14 06:56 PM
70GTXer Offline OP
70GTXer  Offline OP
Tom, John and Streetvandan thanks that was what I had heard about just hoped they were still being made. was talking to a guy at a show last week who got one for his Buick GS. he just couldn't remember the name, maybe I will run into him again soon to find where he got his and will post the info for other members with b-bodies. Again I appreciate all your info.
Re: A727 Torque convertor lockup [Re: 70GTXer] #1665563
08/31/14 07:04 PM
08/31/14 07:04 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
The Buick guy may have been referencing the GM Switch-Pitch converter that was used in the late'60's which gives two different stall characteristics. I think they are available from an aftermarket source.
