Re: A727 Torque convertor lockup
[Re: 70GTXer]
#1665550
08/30/14 08:05 PM
08/30/14 08:05 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I have a 70 440 with 727 and 3.23 gears. have heard of a Aftermarket torque convertor that acts almost like a 4th gear at highway speeds but is not an overdrive or lockup unit. has anyone heard of this or used one?
?? the converter ?? I think you mean the trans.
[Re: 70GTXer]
#1665553
08/30/14 11:44 PM
08/30/14 11:44 PM
mikemee1331
bethlehem pa
That is what I have in there now, so you are saying I should keep what I have and it will help to reduce rpm's at highway speeds?
when you say stock converter what 'stall' are you considering stock? if you are referring to your gear ratio a 3.23 is not really a cruising ratio but it is far from a killer either. what car do you have, and is it stock as far as you know? are you trying to reduce your engine speed when on the highway?
[Re: 70GTXer]
#1665556
08/31/14 12:27 AM
08/31/14 12:27 AM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Then you need to add an overdrive of some sort, or change the rear end gearing. No big secrets here.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: Tom Hand]
#1665559
08/31/14 05:15 PM
08/31/14 05:15 PM
Posts: 25,806 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The B&M Superdrive Converter from the early eighties had an internal overdrive, it didn't stay around too long so I imagine it wasn't a great success.
[Re: John_Kunkel]
#1665560
08/31/14 06:16 PM
08/31/14 06:16 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
http://papers.sae.org/820742/"A torque converter has been developed for aftermarket use in older, heavier, large engined cars and light trucks to improve fuel economy, particularly at highway speeds. This torque converter includes an output coupled overdrive and torque split within the converter itself. This torque converter has shown gains in highway fuel economy of 9 to 21 percent. The converter changes that give the improved fuel economy result in a lower acceleration level for the vehicle"
