68 b body amd quarter panel install help #1665107
08/29/14 11:39 AM
08/29/14 11:39 AM
1.5 hours SE of Pittsburg, Pa
geno440 Offline OP
geno440  Offline OP
I'm trying to install an amd left quarter on a 68 roadrunner. The window channel won't line up with original roof. See pic. Anyone else had this issue? Any suggestions?
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: 68 b body amd quarter panel install help [Re: geno440] #1665108
08/29/14 11:41 AM
08/29/14 11:41 AM
geno440 Offline OP
geno440  Offline OP
Pic
Re: 68 b body amd quarter panel install help [Re: geno440] #1665109
08/29/14 04:36 PM
08/29/14 04:36 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Need a bigger picture!
Re: 68 b body amd quarter panel install help [Re: moparpollack] #1665110
08/29/14 11:15 PM
08/29/14 11:15 PM
Sarnia, Ontario
restoman Offline
restoman  Offline
Sarnia, Ontario
Need a bigger and better picture!
Fixed.
"look Daddy! Everytime Danica leads a lap, a redneck chokes to death on a corndog!"
Re: 68 b body amd quarter panel install help [Re: restoman] #1665111
08/30/14 12:48 AM
08/30/14 12:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not bigger as in BIGGER ... another shot from further back. I have no idea what this area in the photo is !!!
Re: 68 b body amd quarter panel install help [Re: Stanton] #1665112
08/30/14 05:44 AM
08/30/14 05:44 AM
geno440 Offline OP
geno440  Offline OP
Before cropping
Re: 68 b body amd quarter panel install help [Re: geno440] #1665113
08/30/14 11:47 AM
08/30/14 11:47 AM
Canada
demon Offline
demon  Offline
Canada
The only problem I see is 2 inches of the roof is cut off.....
Re: 68 b body amd quarter panel install help [Re: demon] #1665114
08/30/14 01:21 PM
08/30/14 01:21 PM
crlush Offline
crlush  Offline
Better find the piece you cut off to short
Re: 68 b body amd quarter panel install help [Re: crlush] #1665115
08/30/14 01:38 PM
08/30/14 01:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Looks like the quarter isn't bent as well as original in the window opening area. May need to cut and add some metal.
Everyone seems to thing amd is a fix all and the easiest way, but I try and keep as much original metal as I can to avoid these issues.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 68 b body amd quarter panel install help [Re: Silver70] #1665116
08/30/14 02:15 PM
08/30/14 02:15 PM
geno440 Offline OP
geno440  Offline OP
I cut about two inches of roof off to make fitment of quarter easier. I am going to put an amd roof on as well.
I just thought some had put one of these on before and had some advice.
Not only does the angle of the new quarter not match the old roof but it appears to be crooked as well.
Re: 68 b body amd quarter panel install help [Re: geno440] #1665117
08/30/14 09:25 PM
08/30/14 09:25 PM
Sarnia, Ontario
restoman Offline
restoman  Offline
Sarnia, Ontario
That's why they make body hammers and dollies...
Yes, I've seen several AMD quarters like that. It's a fairly easy fix.
Best that you noticed it now and not after it's welded in place.
Re: 68 b body amd quarter panel install help [Re: geno440] #1665118
08/30/14 11:29 PM
08/30/14 11:29 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You'll want to make sure your trim fits the corner and roof line before paint... and it won't fit the corners without work, been there, done that
Re: 68 b body amd quarter panel install help [Re: Silver70] #1665119
08/31/14 05:16 PM
08/31/14 05:16 PM
geno440 Offline OP
geno440  Offline OP
Thanks guys looks like a lot of work ahead.
