68 b body amd quarter panel install help
#1665107
08/29/14 11:39 AM
08/29/14 11:39 AM
Posts: 856 1.5 hours SE of Pittsburg, Pa
geno440
I'm trying to install an amd left quarter on a 68 roadrunner. The window channel won't line up with original roof. See pic. Anyone else had this issue? Any suggestions?
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: 68 b body amd quarter panel install help
[Re: geno440]
#1665109
08/29/14 04:36 PM
08/29/14 04:36 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: Stanton]
#1665112
08/30/14 05:44 AM
08/30/14 05:44 AM
geno440
Before cropping
[Re: crlush]
#1665115
08/30/14 01:38 PM
08/30/14 01:38 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Looks like the quarter isn't bent as well as original in the window opening area. May need to cut and add some metal.
Everyone seems to thing amd is a fix all and the easiest way, but I try and keep as much original metal as I can to avoid these issues.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1665116
08/30/14 02:15 PM
08/30/14 02:15 PM
geno440
I cut about two inches of roof off to make fitment of quarter easier. I am going to put an amd roof on as well.
I just thought some had put one of these on before and had some advice.
Not only does the angle of the new quarter not match the old roof but it appears to be crooked as well.
[Re: geno440]
#1665117
08/30/14 09:25 PM
08/30/14 09:25 PM
Posts: 915 Sarnia, Ontario
restoman
Sarnia, Ontario
That's why they make body hammers and dollies... Yes, I've seen several AMD quarters like that. It's a fairly easy fix. Best that you noticed it now and not after it's welded in place.
"look Daddy! Everytime Danica leads a lap, a redneck chokes to death on a corndog!"
[Re: geno440]
#1665118
08/30/14 11:29 PM
08/30/14 11:29 PM
Silver70
Rust Belt, SW PA
You'll want to make sure your trim fits the corner and roof line before paint... and it won't fit the corners without work, been there, done that
[Re: Silver70]
#1665119
08/31/14 05:16 PM
08/31/14 05:16 PM
geno440
Thanks guys looks like a lot of work ahead.
