proper PCV valve & grommet for a '67 440 #1658957
08/14/14 04:00 PM
08/14/14 04:00 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
My '67 has dealer installed chrome valve covers,but doesn't have correct PCV valve.. I don't think it would have been one of those white plastic ones ??
Anybody got a picture , or info on helping Me get correct PCV valve and rubber grommet ??
Re: proper PCV valve & grommet for a '67 440 [Re: gassy66] #1658958
08/14/14 04:49 PM
08/14/14 04:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The correct PCV is the steel one , joesixpack has them.
Re: proper PCV valve & grommet for a '67 440 [Re: JohnRR] #1658959
08/15/14 07:11 PM
08/15/14 07:11 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
How do I get in touch with joesixpack???
Re: proper PCV valve & grommet for a '67 440 [Re: JohnRR] #1658960
08/15/14 07:25 PM
08/15/14 07:25 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Correct valve is steel....However, I am under the impression that there will be no grommet, rather the valve is fitted into a steel cap that pushes onto the valve cover like the breather does.
1968 had a grommet and used the steel valve.
Correct me if I'm wrong.
Re: proper PCV valve & grommet for a '67 440 [Re: gassy66] #1658961
08/15/14 07:32 PM
08/15/14 07:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
PM him ???
Re: proper PCV valve & grommet for a '67 440 [Re: superwrench] #1658962
08/16/14 04:41 PM
08/16/14 04:41 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
My valve cvr definitely had a rubber grommet surrounding the pvc valve originally. Who has address for joesixpack???
Re: proper PCV valve & grommet for a '67 440 [Re: superwrench] #1658963
08/16/14 08:04 PM
08/16/14 08:04 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1967 is the same as 1968
pretty sure the last year for the cap style was 1965 ( except Hemi which was 1969 )
as an fyi, the 1969 and older style pcv valve are getting tougher and tougher to find. I have about a half dozen ( none are for sale )
http://www.ebay.com/dsc/6000/i.html?LH_TitleDesc=1&_nkw=2808622&_rdc=2
Re: proper PCV valve & grommet for a '67 440 [Re: gtx6970] #1658964
08/17/14 04:50 AM
08/17/14 04:50 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
I think this Dorman grommet from their Help! line might work.
I know the set up you have as my car has it too
Re: proper PCV valve & grommet for a '67 440 [Re: MowP4rsn] #1658965
08/17/14 04:57 AM
08/17/14 04:57 AM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
The PC valve itself isn't really a "wear item", so if it rattles it doesn't need replacing.
If you are going for "authenticity", then the steel PC valve is the one to get. If you're not concerned with looks, then get this Standard Motor Products V180 PCV Valve and save yourself some $
I have one on my car, it fits and works fine.
